Will an AU XR6 HP cam makes any gains in an AU futura without the extra stuff like ECU, regulator etc.
RIP...
No...
. Oval Everywhere... |
the hp's run a lot more compression , my old one ran 225psi cold cranking . my stock au was about 190 psi.
i was think about fitting a vct cam in my hp motor before i sold the car.. you would think it would have to gain something? dose jim moch and gnd still do cams for au's , might be worth a look.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
#4 | |||||
RIP...
In combination with the slight difference in the combustion chamber, ECU, and diff ratio, the difference is quite noticeable and measurable. Quote:
I still have an AU DEV5 cam sitting here which I'm getting a master made...
JMM made some good cams , i ran a street fighter thats what he called it in my old au 5spd lukey headers and 2.5 sport zorst it pulled 159 rwk , was chasing my tail ever since with that car...
have to disagree with the rest mate , had a series 1 stocko rbduild pumped 185 psi the original s2 pumped 190 and s1 xr6 hp 225 . this is the same gauge on all motors. theres quite a bit of diff between duration and lift on the cams , what that relates to in actual hp ??? anyone done it yet? if my old build thread is still on here it's got every thing i ever done on it.
heres the old build thread
http://www.fordforums.com.au/showthread.php?t=94360
#8 | |||||
RIP...
They are all 9.65:1 CR across the board. A compression test is dynamic, and somewhat different to the static compression ratio. Quote:
The cams on there own make no noticeable difference. Been there, done it.
no worries mate , just saying the numbers i got.
that hp motor i put in my au ran a lot harder then the original standard motor. this was with the stock ecu to .
#10 | |||
Google search came up with this comment from Wade Cams
