for those with aftermarket gas which wire on the oxygen sensor does the gas system tap into for feedback
![]() Join Date: Jan 2005
Tap into it at the ECU, not at the sensor.
yeh ok fair enough would be a smarter and neater way which pin or wire color then
Just another mock-up..
yeah it'd be the same as mine mate. Tapped into the ecu. My gas gear is only 250 if you still want the whole lot!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
as tempting as that would be i ended up buying a complete impco setup just the other day which was rekitted i would have prefered yours though
fair enough mate..
thei impco system isn't bad though..
Is there a good reason for tapping into it at the ECU? Both of mine are tapped in at the sensor connector. Seen a few like that. All the other wiring for the gas goes up front through the firewall, so easy to take the sensor wire with it.
