21-05-2021, 07:59 PM | #1 | ||
got an issue with the fan.
aircon and heater are working fine when the fan is running. fan generally wont run, turn it upto full and give an area under the glove box a hit and the fan kicks in, sometimes comes on if we hit a bump in the road too. once its running it seems to stay on, but does fluctuate in power to some extent. i'm assuming the fan is stuffed. has anyone here had a similar problem? |
23-05-2021, 09:18 AM | #2 | ||
Chairman & Administrator
It's possible that the bearing in the fan is stuffed but if it isn't noisy when operating (like a bearing noise) then it might just have something blocking it.
Observatio Facta Rotae
23-05-2021, 09:44 AM | #3 | ||
Is this on all speeds including hi speed
Check for power and earth on wiring also check for burnt connections If it starts working by giving it a tap with a hammer then probably fan motor is kaput |
23-05-2021, 08:29 PM | #4 | ||
yes its on all speeds.
ill have to get in behind the glove box for a closer look. from what i've read its a complete dash out job to replace the motor which i dont think i'm keen on doing. |
23-05-2021, 09:34 PM | #5 | ||
Regular...with metamusal
deleted due to wrong section .... thought i was in "B" series, instead i'm in "AU"
23-05-2021, 09:39 PM | #6 | ||
On an AU, it’s dash out. Truly.
Should’ve quoted you before you edited your post! Ah well, here’s a picture of Kim Kardashian in a bikini, just to fill out the post a little. Last edited by Citroënbender; 23-05-2021 at 09:45 PM. |
03-06-2021, 08:02 PM | #7 | ||
well i cant see anything wrong by looking at it. i'm guessing the fan motor is flogged out.
ill leave it as it is for now. |
08-01-2022, 10:14 AM | #8 | ||
the fan is not working at all now.
i can get a used replacement for $75 (nothing available new) has anyone removed the dash/replaced the blower motor before? dash out seems like quite a big job, and i cant really find any info on this. |
04-02-2023, 12:09 AM | #9 | ||
It’s be hide the glove box. 2 screws and a plug. That’s where it is in my FG Ute and same place for my TDi territory
04-02-2023, 05:22 PM | #10 | ||
Next upgraded Mk1 Leopard
Peter look at the date. Wrong forum.
Thread Tools | |
Display Modes | |
