29-03-2007, 08:24 AM | #1 | ||
Hi guy's, mate brought over his 2002 1.8 focus over and asked me to change his petrol filter, tried to use screw drivers to release the fuel tabs but they won't budge, is there anyone who has tried to change his petrol filter, and how did you do it, thank's.
29-03-2007, 09:03 AM | #2 | ||
Mr Focus
I have and its not that easy.
You need to push on the fuel tabs like you have been doing then push down. Also try and turn the fuel filter, that'll give you a better angle for the fuel tabs as well Take off the fuel filter tab thats near the 4 fuel lines 1st then you can turn the fuel filter little bit and this should help you. On the fuel filter tabs thats near the back right door this is the 1 you'll have the problem with, you need small hands to work under there...lol There is a bolt to take off as well 12" or 7/16 bolt if I remember If you live around Brisbane I would do it for ya.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. Last edited by FRA; 29-03-2007 at 09:29 AM. |
29-03-2007, 09:44 PM | #3 | ||
Thank's FRA, the filter is in a very awkward place, I didn't have my glasses when I attempted to change the filter, did you mean squeezing the tab's down and pushing out? thank's.
30-03-2007, 09:12 AM | #4 | ||
Mr Focus
Push the tabs in by squeezing it then push down,do you have a small tool nips at all, that should help you.
Then get a small screw drivers or something so that you push tab down. Getting the tab is the hardest part. Taking off and putting on a exhaust isnt much better.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
30-03-2007, 06:24 PM | #5 | ||
Thank's again, I will have another go on the weekend, try changing the water pump, that's a interesting job.
30-03-2007, 06:30 PM | #6 | ||
Mr Focus
Well all the best man.
I'm going to change over my cats over on the w/end and see what difference it makes on the 2 Focus.
