Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
26-03-2021, 02:01 PM | #241 | |||
Apologies. Got caught up with speaker upgrades and dynamatting. I'm looking to upgrade the interior of an original 2009 FG G6ET. I've already done the main headliner. I've marked up the bits I need from your original images - On this one, I wasn't sure about the bits labelled with question marks for the centre light area - My current centre light looks like this, (and I'll re-use off that whatever I can) - To complete the job, I'd also be looking at A, B and C-pillar trims for both sides. For the B-pillar, I'd also need the coloured plastic bits that hold the seat belts on the adjusters. Hope that makes sense! Cheers, Q. |
26-03-2021, 03:39 PM | #242 | |||
Parts Fiend
Successful Sales With frenzal56, falconxr, loosecannon, lima_been, bo5ton, Mardk, Chapter Four, leakey, POELWYK, Dman4.0, rayban76, tutor, PridenJoy, Aplito Futura, sbutler, Bosko, storta1, portokatsiki, AUte, 5.8, xxxg, FTW-302, LeadFoot81, Peuty, BillM, Sox, needfordspeed, watejs06, CATXR8 |
26-03-2021, 09:37 PM | #243 | |||
From the roof console/sunglass holder: Because you need the sunglass holder door, as per image you have to buy the whole console which comes with everything in the outlined box with part ID 519A58. So you will also get the parts you dont need, but it will most probably be cheaper than buying individually and then you will have some spares. Only available in light limestone colour as the turbo shadow grey ones are obsolete. Looking at $130 for the light limestone one. From the roof lining image: RH/LH Sunvisors: Four to choose from. 1. Base model in light limestone colour. 2. G6E Light limestone. 3 XR with mirror insert Shadow Grey colour or 4 XR Shadow Grey Non Illuminated. All roughly around the $50 mark each but you need to decide which one you want. Centre sunvisor retainer: choice of 2 based on colour, Light Limestone or Shadow grey, both $12 each. Grab Handles: choice of two also based on colour, Limestone or Shadow grey, still available @ $20 each. 54310A is rear roof insulation 54310B is center roof insulation 51910B is a center foam spacer 52188 is a foam spacer 51910A is also a foam spacer. 13879 is BRACKET - INTERIOR LAMP, WITH REAR DOME LAMP (BASE SEDAN). A pillar trim choice of 4 plastic in limestone or shadow grey or cloth in either colour. Price varies pending which one from $30-$160. B pillar trim upper choice of two pending colour. $45 B pillar lower trim only 1 in shadow grey $35 C pillar trim choice of two pending colour: $50 Top B pillar trim cap choice of two pending colour $5 each. B pillar seat belt cover, choice of two pending colour: $6 each. Last edited by GTLEGEND; 26-03-2021 at 09:53 PM. |
26-03-2021, 09:54 PM | #244 | ||
Thanks GT.
I'm trying for shadow grey all around so will need to pass on the roof console. Would like to go ahead with - RH/LH sunvisors - option #3 in your list above, retainer clips in shadow grey to match plus 3 x grab handles, again in grey. Still confused about 13879. Is that just the bracket for the rear dome lamp or the assembly itself, (like the last picture I posted above)? Keen to get that in grey too, if possible. Are the A, B and C-pillar trims available in grey? Cheers, Q. |
26-03-2021, 10:05 PM | #245 | |||
13879 is just the bracket for base models that have a center light not the front console with the two lights like you already have. if you want the centre lamp, see components below. There are three types, the basic small one, the larger and then the larger with additional map lights. PM me with what you exactly want and we can organize from there. FGX Interior Lamps.JPG |
27-03-2021, 05:42 PM | #246 | ||
Hey GT,
I had a couple of questions, Do you know the part number for the plastic piece at the back of the FGX XR8 Bonnet and if it’s vin restricted like the bonnet itself? And for the G6E Turbo FGx’s, do you have the part numbers for the full roof lining? Currently wanting to convert a G6E FGx to black/shadow grey roof lining. I see you have posted previously a few different examples, just wasn’t sure if there was a comprehensive list I can take to a dealer to order it all. Thanks! |
27-03-2021, 06:34 PM | #247 | |||
Shadow grey roof lining without roof console ER2ZF51968BBSH or with roof console ER2ZF51968CBSH. The part with roof console is VIN restricted. Let me know if you need assistance getting these parts as I can get a discount for forum members. Go to you dealer, get a quote and then compare to what I can get it for, although in this case if freight is required on roof lining, the cost of freight might outweigh any savings, but worth a try. |
02-04-2021, 08:01 PM | #248 | ||
Do you have any info on the "Motorcraft" branded front wheel hub for the FG Falcon ?
All factory Hubs I've seen advertised are Ford branded with part # BG2B663A . The Motorcraft part has a different number - J2MZ1104B and a fair bit cheaper at $109 https://www.ebay.com.au/itm/Ford-Mot...T/264564146295 Cheers |
02-04-2021, 11:19 PM | #249 | |||
Have not had any experience with the Motorcraft part as such as it has only been on the market for a short time. I can get the BG2B663A for $175 + freight if required and the J2MZ1104B for $90 + freight if need be. GT |
03-04-2021, 02:02 AM | #250 | ||
Given this: https://www.youtube.com/watch?v=ntkk...nel=YepThatsIt
I am sure a few of would like to know what Ford charge approximately at least for the trans service kit (filter, gasket and mechtronic seals) for their FG and Terry with the ZF6HP both for metal and plastic pan varieties. If we want a specific let's say a FG MKII of November 2013 with a metal pan.
regards Blue |
03-04-2021, 09:28 AM | #251 | |||
Sump filter $275 Pan gasket $183 Mechtronic sealing sleeves (there are three different type but 4 in total as you need two of one) $24 each. Metal Pan/Sump $535. 2013 model does not differentiate between metal/plastic. It is only in BF series where there is a choice of metal and plastic. Plastic pan is $615. I am pretty sure Ford do not offer a filter or trans service kit from what I could find at the moment. |
03-04-2021, 06:02 PM | #252 | ||
Regular...with metamusal
05-04-2021, 12:13 PM | #253 | |||
Unfortunately long gone. You are searching for part number BA2T15C000A if that is any help. GT |
05-04-2021, 12:42 PM | #254 | ||
happen to be able to source a windscreen rain sensor and the metal clip that holds it in for a 2016 FGX XR6 Turbo.
05-04-2021, 01:06 PM | #255 | |||
Sensor I can source for $127 plus postage if required. Not sure about the metal clip, it may come with the sensor or its part of another component. I cant see it in the diagram. FGX Rain Sensor.JPG |
05-04-2021, 01:31 PM | #256 | ||
05-04-2021, 04:01 PM | #257 | |||
fgx rain sensor 2.JPG |
06-04-2021, 02:13 PM | #258 | |||
Hi GT Referring back to post #189, could you please help me with buying the upper and lower FGX grilles, with the darker metallic grey surrounds. I’ll PM you now. Thanks very much |
06-04-2021, 03:23 PM | #259 | ||
Hi @GTLEGEND,
Are you able to get the L&R side door seal that runs down the roof line and A-pillar on an '08 BF MKII ute? The rubber that is attached to the body, not the door. Thanks! |
06-04-2021, 04:17 PM | #260 | |||
Look at the image below (disregard that it is a sedan image) but are you referring to 51400 and 51401? Or the on body door seal 20596? BF Side Body Seals.JPG GT |
06-04-2021, 04:35 PM | #261 | ||
Hi,
It is, 51400A & 51401A I believe. Will check when I get home. |
06-04-2021, 08:39 PM | #262 | ||
Hi GT,
Yes it is that part number. Sent from my iPhone using Tapatalk |
06-04-2021, 08:44 PM | #263 | |||
Unfortunately those parts are no longer available from Ford or any NOS from what I can find. If it helps below are the part numbers you are searching for. BAC2P51400A: RH ute BAC2P51401A: LH ute GT |
06-04-2021, 10:31 PM | #264 | |||
Ah damn. Thank you. Are any of the runners in that diagram available at all anymore ? This does surprise me considering the number of these cars on the road. I can get full rubber sets for my charger still! Sent from my iPhone using Tapatalk |
06-04-2021, 10:56 PM | #265 | |||
I am sure like alot of older cars you can buy rubber kits but it wont be original Chrysler ones. |
07-04-2021, 08:30 AM | #266 | |||
A couple of runners are showing their age on my Ute. The ones I originally asked for but also the window runner as an example (it has nearly broken down completely. Would it be too much of an ask to know what rubbers / seals and their price are available to buy? If I’m going to change one I may invest in changing all that I can. Sent from my iPhone using Tapatalk |
08-04-2021, 12:35 AM | #267 | |||
08-04-2021, 11:49 AM | #268 | ||
Abuser of Charvels
Hi, are the FG flick keys available? Thanks.
08-04-2021, 02:21 PM | #269 | |||
Fair enough. I’ll put a list together this weekend. Cheers. Sent from my iPhone using Tapatalk |
08-04-2021, 04:50 PM | #270 | ||
