Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Coupe Restoration & Build
Old 13-11-2012, 01:45 PM   #121
Cabbage
Cabbage's Avatar
Default Re: Moffat Federation Insurance Replica
Awesome, she looks a ripper, frame that photo with the moff as well!!
Cabbage is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2013, 12:21 PM   #122
greenjgs
greenjgs's Avatar
Finally had some time to fix the teething problems from Sandown. Heres a few pics.
She overheated on the final run due to poor airflow and a cavataiting water pump. (Got the standarpump for sale if anyone needs a vertually new pump.
New Thermo's. The EL setup I had on it worked well in the pits and dummy grid but became an air restrictor when on the track
Added stone guard mesh while the rad was out.
Also made up some cover's to stop the air going around the rad.
Next job, Make the brake pedal feel more solid.
The rubber disc on the left is a standard reactionary disc out of the booster. It's there to stop the brakes grabbing when stopping on the road. Makes the pedal soggy on the track. The piece on the left is a piece of nylon I turned up, I've made 3 of them in different thicknesses to improve pedal height as well.
That's all for now. Fitting up a firewall brace and finishing the interior today.
G
greenjgs is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2013, 10:21 AM   #123
whingey
whingey's Avatar
Congrats on an amazing recreation. I had planned to do a similar thing, I finally located a 351 XC manual coupe but it was just too original to modify so the project was scrapped. Nice to see somebody take up the challenge, well done.
Cheers, Greg
whingey is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2013, 07:42 AM   #124
greenjgs
greenjgs's Avatar
Thanks Greg. When I picked picked up the body after buying it on ebay it was way worse than the pics showed so even though we believe it to be a Superbird it was really only good for the crusher the way it was. Good plan not to tear up a good original car for a racer.
I plan to give it another run at Winton next week to see if we have the overheating issue sorted, I'll post some track pics then.
Cheers Graeme
Old 16-10-2013, 08:57 AM   #125
greenjgs
greenjgs's Avatar
So an update.... Rebuilt the alternator and dropped in the new radiator before HTA. All good. Took the car to Winton last Friday and lasted 2 laps before the alt light came on and she overheated again...... Ah crap we say. So get back to the pits and of all things the Alt pulley has worked loose and fallen off. Never had that before, so after a 2 1/2hr trip to Albury to EMA, (thanks Matt!), we got it going again and did 25 mins of almost trouble free running. I am struggling to downshift to 2nd so the toploader is coming out for a rebuild.... Happy days.
Old 16-10-2013, 02:38 PM   #126
neptune blue
neptune blue's Avatar
Hey Graeme
Are you going to give it a run at sandown?
I can't believe its 12 months since the car first hit the track at this same event
Cheers Tony
neptune blue is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2013, 06:28 PM   #127
greenjgs
greenjgs's Avatar
Hi Tony
Not this year unfortunately, I'll be in the US. I'll try to do another Test and Tune day at Winton before PI Historics. It was a great day, would have had heaps of track time if not for the problems
G
Old 16-10-2013, 07:51 PM   #128
sbutler
335 kw of goodness
sbutler's Avatar
Ok so next. A Brut 33 replica please??????
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2013, 08:16 PM   #129
Bearman
Moderator Ford Coupe Club
Bearman's Avatar
There is one of those around. It's the one that was built in the USA. It came home around 6 years ago.
Mitsubishi ASX Auto, White - Daily Commuter
XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote
http://www.fordcoupeclub.org
"If you don't know where you're going, any road will take you there" George Harrison 2001.
Bearman is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2013, 08:20 PM   #130
Bearman
Bearman's Avatar
http://youtu.be/V-Q_B0F1Ur4
This one!!
Old 16-10-2013, 09:08 PM   #131
greenjgs
greenjgs's Avatar
If I was going to build another car it would be a sports sedan. Maybe Jim Richards Big M Coupe if the original is gone or a cologne capri
Old 17-10-2013, 07:31 AM   #132
JG65TE
JG65TE's Avatar
That setup of 2 thermos screwed to the radiator is a brave move. I cooked a clevo with that setup. The ef/el is a much better way. Without a shroud, it wont pull air thru the radiator very well. If it works for you, keep it but be wary.
JG65TE is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2013, 08:36 AM   #133
greenjgs
greenjgs's Avatar
Hi Doc, yes it was never to be permanent, it was to find out where the issues lay. THe EL fans I had on it were great in the pits but on the track wouldn't allow enough natural airflow so the car overheated.
I now have a custom 8.4mm centre 4 core rad in it with 1 only unshrouded fan. Even at Winton I know don't need the fan on and she sits right on the thermostat when idling in the pits.
I'm still tempted to throw an underdriven pulley on the crank to slow up the waterpump speed.
Cheers Graeme
Old 23-03-2014, 09:42 PM   #134
jamess
Coupe/interceptor adopter
What did you do for brakes Graeme? They look pretty wild.
jamess is offline   Reply With Quote Multi-Quote with this Post
