Old 11-08-2006, 04:28 PM   #91
simonr
Focus Rookie
simonr's Avatar
Originally Posted by Teki04
Nope - Michelin Pilot Exaltos with 205/45R16s
Could of just said no.. 16"s
dont need to show off the tyres !!
04' Panther Black Focus Zetec
Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters
simonr is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 05:08 PM   #92
photn
AFF Post NAZI
photn's Avatar
hey teki, just pointing sumthing out, do u get the feeling that every1 is SORTA against you, i just think ppl here dont like ppl telling them faults about the dream car they may want to have, im sure you wouldnt appreciate ppl coming out and telling every1 about the faults ur clio has(whatever they may be) - Just an observation - totally impartial - unbiased. IMO.
Old 11-08-2006, 05:21 PM   #93
Ives
Ives's Avatar
Originally Posted by simonr
hahah obviously you havent been reading the thread
:hihi:
I skim-read long posts
Old 11-08-2006, 07:17 PM   #94
04RSD
shinanigans
04RSD's Avatar
did any of you take into consideration the fact that the st has a heavier nose, housing a 2l donk, while the zetec has only the 1.6.
having transplanted a rb25 into a silvia and transplanting a 1.8l mivec into a mirage i can tell you from experiance the same car with a different motor = 2 very different handling cars.
i have raced a 1.3l turbo starlet with expensive 15" race slick bridgestones on it round a track a few hundred times but when i drove it i one day on my 17" goodyear f1s i ran quicker times.
i have owned and modified a ****load of cars in my time going bigger has always been better.
04RSD is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 09:49 PM   #95
murcod
.....on a racetrack...... again.....
Get out on some real roads with ripples, potholes and mid corner bumps and then do some comparisons.
2016 Kuga Titanium 2.0l EcoBoost
murcod is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 10:30 PM   #96
Pieoter
You'll get the same results. Stupidly hard suspension will be your downfall on the road.
COLORADO RED FIESTA ZETEC
MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes.
ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001.
Pieoter is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 10:42 PM   #97
murcod
You do realise that the tyre sidewalls in effect act as part of your "suspension"? I wouldn't call a car that tramlines and transmits and reacts to every bump and lump "fun" to drive. But each to their own.
Put your $$$ into decent tyres, not huge diameter rims!!!
Old 12-08-2006, 12:40 AM   #98
Pieoter
Yes I do murcod. But on a street driven car your gonna have a relativly compliant suspension and reducing your sidewall by 19.5mm is not gonna have a negative effect on your handling.
Do you realise that your tyres work best when having an even load across its contact area? Do you realise that a smaller sidewall will reduce tyre deformation and result in a more even load across the tyre giving higher grip levels?
Im not contesting that good tyres are essental and I wouldn't exactly call 17's huge diameter rims.
Old 12-08-2006, 08:48 AM   #99
Ives
Ives's Avatar
STILL going?!?!
Old 12-08-2006, 11:19 AM   #100
murcod
Hyperkid - YES!
Pieoter, have a look here : http://www.drive.com.au/buy/new/car_...15916620050609 ; the Lotus Elise would be one of the best handling cars this side of $100000. Check out the tyre sizes used - front 175/55R16 and rear 225/45R17. Now that gives sidewall heights of 96.25mm for the front and 101.25mm for the rear. The rear rim width is 7.5".
Now compare the Fiesta Zetec sidewall height 195/45 = 87.75mm (WOW! it's LESS!!); now I think the Fiesta might be lacking in other areas than tyre sidewall height when it comes to handling..... Money would be better spent on things like shock absorbers, decent springs and swaybar upgrades (or even just bushes), that rear hub spacer kit from the UK etc. There is lot more to it than simply increasing the rim diameter.
Even a car like the HSV GTO with 245/35R19 tyres has a sidewall height of 85.75mm - only 2mm less than the standard Fiesta Zetec 16" tyres. The MY06 Subaru Imprezza STi runs 225/45R17 - sidewall height is 101.25mm
So, is the sidewall height on the Fiesta with 16" rims really the issue that is affecting the handling? I think not- money would be better spent elsewhere. ;)
Old 12-08-2006, 01:18 PM   #101
Pieoter
When did I ever say you should spend your money on rims and not suspension? NEVER.
Did I ever say the fiesta was strugling because of a large sidewall? NO
This was about 16inch vs 17inch on the fiesta. Don't put words in my mouth.
I very much agree that you should spend money on your suspension components.
P.S Lotus elise is helped alot by its very light weight.
Old 12-08-2006, 03:17 PM   #102
murcod
Where did I "put words into your mouth"? Or say you said something you didn't?
You get very defensive when faced with facts and figures.
ROTFL
The whole thread has been in regards to 16" vs 17" and you saying they are better for various reasons. I'm just presenting some views on why they possibly aren't unless you like the "pose" value, are willing to spend big $$$ to get it and make sacrifices in on road driving manners.
Anway, I've said everything I want to on the subject. It will give anyone considering the "upgrade" food for thought.
Old 12-08-2006, 05:39 PM   #103
Pieoter
You presented me with the sidewall height of various cars . This proves nothing as they all have very different suspension setups. You post implied that I claimed that sidewall height was directly related to handling. It also implied that I claimed money should be spend on rims and not suspension. It also gives the impression that I said the sidewall was limiting the fiesta.
I may have gotten defensive but you just seen to ignore anything involving the science of car handling.
I wouldn't call the cost of 17's big $$$ these days and they will still give a very acceptable ride.
Old 12-08-2006, 08:57 PM   #104
JD2004
JD2004's Avatar
is this arguement still going on?? farout how about we all agree to disagree?? done deal?? yup thats me sorted.
JD2004 is offline   Reply With Quote Multi-Quote with this Post
