#91 | |||
#92 | ||
Another sweet mod, and another one that I'd like to do.
But I guess that these diffs/CV's aren't even as strong as a BA control blade setup which enough people are busting already. :( Now put an AU crossmember in the front! - John |
#93 | |||
they call me Tibbo
Its an interesting mod NZ, but for the extra weight and reliablity issues its one I'd stay away from myself.
#94 | |||
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo |
#95 | ||
likes falcon's
ive heard of the diffs dieing under the 40,000, extreme testing periods at the ford testing grounds, how can they be so "weak"
www.carhubsales.com.au |
#96 | ||
They are only a crappy 2 pinion setup in the B-series.
And I know of quite a few unhappy XR6T, XR8 and FPV owners who keep killing these things in their simple driving habits. |
#97 | ||
OK Update.
Ned needed some suspension bits to get bushes pressed into so I got my backside into gear and pulled the diff out of my fairmont. I'm confident now that its going to be a straight forward job fitting the IRS, heres what needs to be changed. ![]() This is the front arm. You cant quite ses it in the pic but the AU arm has a wider bush than the EF. Looking at the next pic there is a bush welded to the rail on the right that if that was gone the AU arm would slide straight in. I could grind this out but I'm not too keen on that simply because it is most likely there to stop the blt rubbing and wearing. Instead I'll get the grinder and cut the AU bush down to fit. See the next pic The EF tailshaft bolts up to the IRS flange which is good. Providing that it is the same length as the AU I wont need to change it. ![]() You guys should know this type of thing is to be expected from me! ![]() ![]()
#98 | ||
Last warning
nice work karl.
considering the conversion has been done before, i'd imagine the tail shaft must be the same or something thats readily available. a few ppl have used AU side skirts on eseries so i guess thats a good sign in reguards to the lenght issue.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#99 | ||
Ok well I stuffed up that post. Someone edit the pic back up plese
![]() All I need now is some AU shocks and to work out the brake lines, but from the position of the caliers it looks like the EF lines might just fit.
#100 | ||
haha nice work karl. you wouldn't catch me getting under that EF though :P
#101 | ||
Two > One
Top work mate. Good conversion if your after a bit more of a supple rear end.
#102 | ||
likes falcon's
keep it up man, your car looked great inside, needs bit of tlc on the body but its nice, sounds great to....
#103 | ||
Once shy... twice bitten
You got me to thank for it! At least ИИИИed suspension helps somebody out! Good work Karl.
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11. |
