Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#91 | ||
Peter Car
#92 | |||
![]() Join Date: Oct 2006
regards Blue Last edited by aussiblue; 21-12-2020 at 03:52 PM. |
#93 | ||
Ford T3 Partsologist
G'day GT
Are you able to please do some digging to see if Ford may have some Parts Drawings on these 4 Part Numbers as i can't find anything on Micropuss TAU3-15W202-A Driving Lamp Mount Bracket TAU3-15K230-A Driving Lamp Reinforcement TAU3-15260-A Stud TAU3-15280-A Driving Lamp Mount Bracket thanx Aaarrrroooooooooo
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() Last edited by Dingo; 05-01-2021 at 04:57 PM. |
#94 | |||
#95 | ||
Giddy up.
Chasing some OEM rubber bushes on the AUII XR8 IRS rear suspension, I'm not exactly sure what part but I believe they are the outer top and lower control arms ?
#96 | ||
Have a look at the image below, ID what number you need and we can see if they are still available and go from there.
AU IRS Suspension.JPG |
#97 | ||
Giddy up.
Thanks mate, I'm trying to attach a pic but its saying my files are to big, etc..
#98 | |||
Former BTIKD
![]() Join Date: Mar 2005
https://postimages.org
2 users like this post: |
#99 | ||
Giddy up.
![]() It's the rubber either side of the "L" side control arm with the bolt going through, you can just see the rubber is perished but its the same on both sides and also both sides of the car. |
#100 | ||
Giddy up.
#101 | |||
3= ER 5B639 F 4= ER 5B639 G 5= ER 5A659 G Will look around and get back to you.. |
#102 | |||
Giddy up.
Cheers. |
#103 | |||
Do you need that as well? Will need to check later... |
#104 | |||
Which is #5 #25 is the lower Hyme joint in the LCA. #24 is a pressed rubber bush where the shock bolts too.
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum Last edited by mcfly94; 10-01-2021 at 06:02 PM. |
#105 | ||
Peter Car
FG G6E Turbo lip spoilers. Still available or NLA?
#106 | ||
Boot lip spoiler I gather you are referring to?
Yes but a around $1100 retail and you then need to paint it. I can get it for around $960 + postage if required. |
#107 | ||
Giddy up.
#108 | |||
Peter Car
Looks like repairing the original is the cheapest way. Problem is getting it off to fix it without scratching the bootlid at the same time. Thanks mate. |
#109 | |||
#110 | ||
Giddy up.
#111 | |||
I can get those bushes for $120 each plus freight to you. There are only two left then they are all gone. Let me know if you want one or both hoping they dont get bought before. Up to you know. Cheers, GT |
#112 | ||
Hoon On The Rise
Hi Mate,
Is there any alarms kits for FGX lying around? I'm pushing my luck I know.
![]() ![]() FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
#113 | ||
#114 | |||
Hoon On The Rise
Next one. Water pump kit for Coyote V8. http://www.fordforums.com.au/showthread.php?t=11405157 BR3Z-8501H-HK1T AC3Z-8527-A 7T4Z-8590-A Will follow your advice on other parts needed. Thank you
#115 | |||
#116 | ||
Are you able to source a dash matt for the fgx with the cut out around the airbag and top of the ICC, all the new ones have it covered
#117 | ||
#118 | ||
Any chance of getting drivers side outer door belt seals for a BFII?
#119 | |||
Rears are obsolete, but I did manage to find RHR on eBay. See below, suggest you get that one because they are rare to find new now. https://www.ebay.com.au/itm/Ford-AU-...oAAOSwjMteaelU |
#120 | ||
My 2016 Territory is off the road due to needing a new brake booster. The dealer can’t source one as it doesn’t appear to be any in stock anywhere.
Recommendations of where I might get a brake booster for 2016 Territory? |
