Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 31-07-2014, 10:59 PM   #91
Stazza_Brendan
Stazza_Brendan's Avatar
Default Re: BA-FG Monoblock 4 Pot Brake Upgrade
which wheel in particular you want to see if they will fit.
The above 2 wheels would be easier for me to find compared to a 19in g6et wheel.
Seduce BFII XR6T Ute
ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw
Stazza_Brendan is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2014, 11:58 PM   #92
FormulaFG
Lurking......
FormulaFG's Avatar
This one:
FG G6E version is 18, which I own a set of.
FG G6ET version is the same wheel but in 19. If the 18 inch version fits then the 19 should you would think.
Also these:
Found on FG XR6T MkII. They are 18 inch.
From my understanding any factory fitted Ford 18" alloy should tell me whether they are compatible or not.
FormulaFG is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2014, 06:42 PM   #93
gtxxr6
i don't understand how these rotors put up with the abuse they cop. have done a lot of 200k stops now and they still look like brand new
gtxxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2014, 06:56 PM   #94
Shockworks
Haha Thanks for the feedback gtxxr6.
I should have given more background about these discs. They have been developed over time with many race cars in Korea, using the best quality materials with a very high carbon content. They support the Korean V8 Super cars and so many other classes currently racing.
This is why we where so surprised after trying to smash them in 40 degree heat over summer.
Thanks again
Brett
Shockworks is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2014, 11:26 PM   #95
puck_lindsay
Rear kit online yet?
10 FG G6ET - Rocket-powered lounge suite.
430rwkW/950Nm.
puck_lindsay is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2014, 10:15 AM   #96
Shockworks
We have the rear discs now but still need more testing before we are happy to put on the market. The alloy hub also need a slight revision to the drawing but apart from that seems to be all good.
I would expect it to still be about two months before we have the full production version ready for sale.
Brett
Old 21-08-2014, 10:34 AM   #97
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Brett
Seriously considering a set of these rotors for front and rear. Would love to get some weight off - so the alloy hats are a go.
Are there any ADR type accreditation on these ?
Just checking.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2014, 10:57 AM   #98
Shockworks
Originally Posted by Bluey-GT View Post
Brett
Just checking.
Hey Bluey,
We exceeded all the ADR requirements during our testing and ABS performance checks. Even after continuous stops above 160kph (20 times) we observed no loss of brake performance or pedal feel/effort. The calliper we use is sourced direct from a vehicle manufacturer which is the OE part on a 2100Kg luxury car. It has been through all OE tests and not an aftermarket type calliper. We chose this calliper as it is currently used on a production car and has amazing performance and quality for the cost.
Brett
Old 22-08-2014, 01:51 PM   #99
Doogs
Doogs's Avatar
Any news on a rear caliper?
Cheers,
Matt
2010 FPV GS 5.0 manual
Shockworks adjustable coilovers, 19 x 9.5 volk racing te37 superlaps, Stainless headers, cats & Twin 3" exhaust. KPM 1500hp fuel system. Chromoly axles, Truetrac, Carbon Fibre tailshaft, ID1000s, Big Herrod cooler, Yella Terra snout, GT-P seats.
458 rwkw/1020Nm e85, 430/950 98ron 10psi
Audio:
8 Channel active setup
Clarion HX-D2 Special Edition
Crescendo Opus 9.9 A pillars + doors
Audison LRX 3.1k & LRX 4.5
Boston acoustics SPG 555
Doogs is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2014, 02:11 PM   #100
Shockworks
Cheers,
Matt
Hey Doogs,
We have the discs in test but the rear calliper is difficult. We are going to try and source the rear Terri calliper or just have the rear alloy hat disc as an upgrade for the GT.
Old 22-08-2014, 11:13 PM   #101
dl86
dl86's Avatar
Will the rotors be for the brembo 4 pot caliper or single piston PBR rears?
I couldn't believe the rotors after the track day I did, they looked brand new even with the aggressive pads I was running. I've upped the ante to full race spec pads now after I killed the set I had lmao
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits
dl86 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2014, 10:30 AM   #102
Shockworks
We want to be able to supply for both the Brembo 4 pot and the PBR callipers but just takes a little time. We now have on board the ex brake engineer from Prodrive to help get these things happening quicker now. We also will have a FG test car soon to test new brake and other chassis related parts.
Brett
Old 23-08-2014, 11:14 AM   #103
graphicgoose
graphicgoose's Avatar
"Other chassis related parts" hey Brett...I like the sound of that!
graphicgoose is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2014, 05:12 PM   #104
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Will the other Chassis parts also be developed/fit B-Series?
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2014, 07:22 AM   #105
Tommie
Tommie's Avatar
Originally Posted by Shockworks View Post
Hey Bluey,
Brett
Hi Brett, sorry to labour this point but what I take from your reply is that the kit meets and has existing ADR approval as caliper (rotors and lines?) are being used on another car that is being sold in Aust. Great kit, I just want to be sure of the legal compliance of the kit if there would be an issue with insurance etc down the track.
JB
FGX XR8, auto
Vixen BA XR8, auto.
Lightning Strike FG XR6, manual.
Tommie is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2014, 12:35 AM   #106
AGS302
AGS302's Avatar
Do you sell the kits minus the rotors?
2009 FPV GS 302 #250/250
ZF And Leather
*Herrod Airbox *X-Force 2.5" Cat Back
Custom tuned by Ben at Auspeed Tuning Mackay to 270.5rwkw.
AGS302 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2014, 12:38 AM   #107
AGS302
AGS302's Avatar
Brendan, My Brother In law has a G6E Ecoboost and it has the G6E 18s on it I'm sure we could try one out over your brakes sometime.
ZF And Leather
Old 01-09-2014, 11:09 AM   #108
Shockworks
The calliper offset is designed for the rotors we use with the kit as the Ford rotor is not suitable for the calliper we supply. We have the Brembo replacement rotor if you are using those callipers though!
Brett
Old 01-09-2014, 11:15 AM   #109
Shockworks
JB
Talking to the brake engineer from FPV and now helping us, we are not required to have ADR approval. ADR approval is for selling or manufacturing a vehicle in Australia. You will find the other brake discs or kit available are also not required to have ADR approval as an aftermarket product.
While we exceed the ADR test procedures, to apply and get approval for a brake package can be a huge cost.
The calliper we supply is from the Hyundai Equus and is a 2100Kg luxury flagship in Korea and has been through all engineering requirements for OE production.
I hope this helps mate.
Brett
Old 05-10-2014, 10:32 AM   #110
Amin
Any news about the replacement rotors for the PBR rear brakes???
I would like to see a complete replacement rotor package for the Brembo/Pbr setup...
Amin is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2014, 05:50 AM   #111
puck_lindsay
Hey,
Pretty keen on the front kit, PM me when you get the rear rotors sorted, will snap them up too. Cooked mine on a track day, have cracked one of the rotors and it's eaten the pad after less than a week. If anyone tries to tell you that RDA are as good as DBA, send them my way. Definitely not.
430rwkW/950Nm.
Old 06-10-2014, 10:38 AM   #112
Shockworks
Hi Amin,
The rear PBR rotor replacement will still be a but of time away. We have been so busy with some shock development for some other models and testing overseas for a couple of weeks. The front upgrade is available but maybe a couple of months before we have the rears ready for sale. Sorry for the delays but we are still a small team:-)
Old 08-10-2014, 09:22 PM   #113
gtxxr6
garbage photo quality i know, but goes to show how beefy the 4 piston shockworks kit is. the calipers themselves are basically the same size as the 6 piston brembos. and anyone who has compared 6 piston brembos to 4 piston brembos knows how tiny the 4 piston brembos are in comparison.
Old 16-10-2014, 10:43 AM   #114
tlm1985
Can anyone confirm if these shockworks front 4 pot 355mm brakes fit under the factory 19" 50th ann. wheels?
tlm1985 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2014, 04:26 PM   #115
Wolfinsheepsclothing
preying on lions
Wolfinsheepsclothing's Avatar
what model car?
2014 FG2 Falcon XR6 luxury in Black, - New toy 2022 HD Lowrider S 124hp/136flb's
Wolfinsheepsclothing is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2014, 04:41 PM   #116
tlm1985
2010 FG XR6T ute 50th Anniversary
Old 16-10-2014, 05:14 PM   #117
tlm1985
Old 16-10-2014, 10:31 PM   #118
FormulaFG
Lurking......
FormulaFG's Avatar
Delete
Old 19-10-2014, 12:37 PM   #119
tlm1985
Does anyone have an answer on the 19" 50th Ann rims and the shockworks brakes?
Old 19-10-2014, 03:09 PM   #120
gtxxr6
dont think anyones tried. but i would almost guarantee they wont clear. they are the wrong style of wheels for big brakes
