Old 07-01-2020, 08:02 PM   #61
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Default Re: Longest in-use Falcon part
What about wiper washer hose?
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2020, 09:28 PM   #62
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
Originally Posted by GTLEGEND View Post
Actually it was BF. AFL101 came into production vehicles 6 cyl Falcon across the line 1/10/2005.
My BA runs a AFL101
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2020, 09:34 PM   #63
GTLEGEND
Originally Posted by arronm View Post
My BA runs a AFL101
If its a turbo with an oil cooler, then yes that was earlier, but as my post states it was made standard across all the 6 cyl models after that date. The non turbo still took AFL1 up to that point.
Old 07-01-2020, 09:51 PM   #64
GXA
Default Re: longest used Falcon part
Originally Posted by lance View Post
Definitely not true. I owned an xp and the front crossmember was no the same as an xy or xb.
Yep. XK-XP had a bolt-in tubular cross-member (if they had one at all...some didn't).
Our FORD Stable
2008 FG GT-E - Lightning Strike
2015 SZII Territory TS - Winter White
2007 BFII Falcon ES - Ego
GXA is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2020, 09:51 AM   #65
BA-XT
2003 BA Falcon XT
BA-XT's Avatar
Anyone know why they changed away from the Z9 filter from BF onwards?
What about the engine block?
Also did the floor pan ever change? I remember reading that every Falcon had the steering wheel issue where it was slightly off centre compared to driving position?
2003 BA Ford Falcon XT
IMPCO LPG Vapour Injection.
DETAILING
Meguiar's NXT Car Wash
Collonite #845 Insulator Wax
Bowden's Own Happy Ending & Fully Slick
Chemtech CT-18 Truck Wash (Wheels & Chassis)
Bowden's Own Wheely Clean & Tyre Sheen
Bowden's Own Three Way Paint Decontamination Spray
OILS AND FILTERS
Nulon Full Synthetic 10w-40
Nulon Long Life Coolant
Ryco Oil & Air Filters
My Instagram Account: @ba_falcon2003
BA-XT is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2020, 01:32 PM   #66
Serious one here, the live axle bump stops.
Old 08-01-2020, 02:38 PM   #67
Bossxr8
Peter Car
Bossxr8's Avatar
Possibly to commonise the filters cause the BA F6 used the new style.
Engine block changed many times. From pushrod to SOHC to DOHC required a lot of changes to it.
Old 08-01-2020, 07:33 PM   #68
TheInterceptor
Cruising...
TheInterceptor's Avatar
Leaf springs? Fairly sure theyre all interchangeable except MAYBE FG?
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2020, 09:34 PM   #69
Mowdit
The drain plug washer ?
It could be the most profitable part they've ever sold !
Ford LV2 Focus XR5
MODIFIED
Mowdit is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2020, 10:46 PM   #70
GTLEGEND
Not the same part all the years of Falcon at least, went from a nylon/plastic washer to metal one in the early 90's then changed again in AU to have the rubber as part of the plug itself till FGX.
Old 09-01-2020, 07:50 AM   #71
Dr Terry
Originally Posted by Hulsty View Post
Conrod bearings, from start to finish and US models too.
This applies only to 6-cyl engines, but I believe we have a winner.
The con rod bearings seem to be the same from the first XK 144 to the last FGX 4.0.
Dr Terry
Dr Terry is online now   Reply With Quote Multi-Quote with this Post
Old 09-01-2020, 09:50 AM   #72
roddy1960
roddy1960's Avatar
I guess there is still a market for parts made new given there is 56 years of Australia's greatest marque . Nothing else even comes close in longevity .
I also suppose that as many Falcons will still be on the road for a fair period yet , that an aftermarket parts market will remain because out sourced parts were required for the manufacture chain even when Falcon was still being built from the factory , stating the bloomin' obvious .
Nothing directly to do with the thread topic but glad that it is an interesting topic to check out and see what comes out of it ..
As for Ford in general it's pretty great that companies in the U.S. at least still manufacture new components for the Model T and Model A and so on . Snyders is one of them .
https://www.snydersantiqueauto.com/
Does anybody do that here for earlier Falcons especially with body panels or will we have cheap knock offs from Asia or somewhere ?
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2020, 11:13 AM   #73
Olbucko
Olbucko's Avatar
Dr Terry
The connecting rod journal is the same size 1960 to 2016, checked factory WSMs, amazing, considering first engine made 60 Kw and last Sprint, 325Kw.
Also I am sure that the timing case oil seal was the same part.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2020, 12:07 PM   #74
roKWiz
Cabover nut
roKWiz's Avatar
Bought a new heater tap from Auto8 this morning and they tell me the part covers quite a few models over the years.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2020, 12:14 PM   #75
roKWiz
Cabover nut
roKWiz's Avatar
Not related to Ford, but a few days ago I bought a concertina boot from Kenworth which fits around the steering shaft at the floor, this part has been used in K100 series Kenworth since 1966 imported models through to present day K200.
Old 09-01-2020, 02:19 PM   #76
Olbucko
Olbucko's Avatar
The following businesses can supply a large range of new and s/h parts for XK-XP
Early Falcon Parts & Accessories
Deon Cameron – 0429 400 520
www.earlyfalcons.com
Classic Falcon Spares
Wayne Whiting – 0418 231 950
www.classicfalconspares.net.au
Fishop Falcons
Auto parts store in Beverley, South Australia
Address: 36 Wodonga St, Beverley SA 5009
Phone: (08) 8244 0714
https://www.facebook.com/Fishop-Falc...8331167523801/
Early Bird Falcon Parts
40 Lipton Drive Thomastown VIC
(03) 9462 2180
https://www.facebook.com/pages/Early...18215881674144
Old Skool Falcon Parts & Accessories
Phone 0439 632 421
Contact for more info:
info@oldskoolfalcon.com
Ebay store: stores.shop.ebay.com.au/oldskoolfalcon.html
AMP Performance 0437 248766 (Engine parts 6 and V8s)
Old 09-01-2020, 05:55 PM   #77
roddy1960
roddy1960's Avatar
Thanks roKWiz and Olbucko , surprising (but good) to see there are parts for the old birds in Oz and Kenworth has stuff too.. that's great ..you can go only so far with wreckers and knock off parts..
OLbucko by the way , you get my vote for one of the coolest avatar pics of them all...It's a ripper..
Old 10-01-2020, 12:51 AM   #78
wackyv8
wackyv8
flange gasket
wackyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2020, 06:40 AM   #79
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Also while the 6-cyl starter motor is interchangeable between say an XK & a BF, they are totally different units to look at.
Also the 6-cyl starter motor doesn't fit any of the V8s.
Dr Terry
Works on 351C if you cut a rib out of its nose cone - had Bosch Barra starter on my F100.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 10-01-2020, 07:52 AM   #80
foxtrot3
foxtrot3's Avatar
Hi. Does the stop/tail lamp globe count as a ford part. It could be the same from the introduction of 12 volt electrics in fords (late 40's), predating the falcon and running through to at least the end of the BF and maybe the FG ute. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
