26-03-2017, 08:41 PM | #61 | |||
Za Dom spremni
2017 red mustang GT manual XB coupe 351 4spd sunroof onyx black XBGT 4 door Sunroof apollo blue AU III XR8 red ute |
2 users like this post: |
31-03-2017, 08:00 AM | #62 | ||
Brace yourself! The latest instalment lasts a whopping 15 seconds!
https://www.youtube.com/watch?v=AcdrohVsUEo Challenger SRT Demon’s super cooled air induction system: The 2018 Dodge Challenger SRT Demon is the first-ever, factory production car with a liquid-to-air charge air cooler chiller system. This exclusive performance feature enables the Challenger SRT Demon to achieve charge air induction temperatures previously unattainable by pressure-charged street-legal production vehicles. Conventional cooling methods consist of simply using air or coolant to reduce the air induction temperature as it is passed through the charge air cooler. When in Drag Mode, the Challenger SRT Demon interior air conditioning system is diverted to chill the engine’s charge air cooling system. The result: Up to 45 degree Fahrenheit reduction in intake air temperature I can smell Methanol! |
31-03-2017, 09:29 AM | #63 | ||
Wonder whats she's like as a daily??
2016 SS-V Redline LS3 Previous Rides. BA XR8, 5M FG GT-P 315 6A FG F6 310 6A HSV Maloo LS3 6M GT 335 6A 300 SRT8 Hemi 6.4 PX Ranger XLT Commodore SS-V Redline LS3 2017 Triumph Speed Triple R Triumph Street Triple RX |
31-03-2017, 09:51 AM | #64 | ||
Depends on ones marital status and how deep their pockets are
I suspect it will be like the Hellcat and have different power modes - red/black key etc. In cruise mode the Hellcat could get upwards of 20 miles-per-gallon, and under full noise the tank could empty in about 13 minutes. Probably won't like pot-holes or speed bumps, and will protest in heavy traffic. |
31-03-2017, 03:56 PM | #65 | ||
Probably depends how often you divert the air con
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
07-04-2017, 04:59 AM | #66 | ||
https://www.youtube.com/watch?v=dm_W3ZYyMM8
Not long now, only a couple of videos to go! ''The Challenger SRT Demon is the first ever, factory production car designed to run on either track-preferred 100+ high-octane unleaded fuel or 91-octane unleaded fuel on demand. The track preferred high-octane fuel is readily available at select gas stations, specialty shops and drag strips. The keys to unleashing the SRT Demon’s full fury are in the Demon Crate shipped separate: Direct Connection Performance parts that include a new powertrain control module (PCM) calibrated for the high-octane fuel and a new switch bank for the center stack that includes a high octane button. The SRT Demon leaves the factory with a PCM configured for premium unleaded pump gasoline, which delivers top level performance. The switch to the Direct Connection controller enables the supercharged HEMI engine to extract the maximum power from the knock-resistant high-octane fuel by optimizing spark timing. Drag racers will see big changes in elapsed time (ET) with the high-octane fuel. Mixing high-octane unleaded and premium unleaded fuels in the tank won’t hurt the SRT Demon’s engine, but the high-octane function won’t activate if the combined fuel octane is too low. A message in the gauge display tells the driver the car will use the premium fuel calibration until the engine is shut off and restarted. How does the car know? The controller monitors the engine’s knock sensors. There will be plenty of fuel available: The SRT Demon carries dual fuel pumps (vs. one pump in the Challenger SRT Hellcat), and larger fuel injectors using higher rail pressure.'' Last edited by CoupeKing; 07-04-2017 at 05:16 AM. |
07-04-2017, 04:28 PM | #67 | ||
FG MkII XR6T Limited Edition Manual Bilstein shocks, SuperPro Bushes, MalWood Shifter Front tyres: Goodyear Eagle F1 A2 245-35-19 Rear tyres: Toyo R888 265-30-19 3.5inch custom exhaust with imitation stock tip, PW Stage 2 cooler (black), ID 1000, XCAL3, Plazmaman intake, Herrod Spark Booster BorgWarner EFR 9174 Autotech 420rwkw |
07-04-2017, 05:12 PM | #68 | |||
http://hennesseyperformance.com/2015...ngine-upgrade/ |
07-04-2017, 10:30 PM | #69 | ||
10-04-2017, 05:35 PM | #70 | ||
10-04-2017, 06:50 PM | #71 | ||
Leaked HP figures....
Power mode 1: 757hp Power mode 2: 815hp Power mode 3: 1023hp *Mode 3 requires the following: 1. Race Fuel: 100 octane or better 2. Crate PCM (crate purchased separately from the car for approximately $3,000) 3. Drag Mode Initiated, allowing higher RPM and broader power delivery in this drag mode... |
10-04-2017, 07:36 PM | #72 | |||
I'm also hearing in full drag-mode 0-100 in under 3 seconds and 1/4 mile time is 9.5 Will come close to that I think (high 9's), if you consider what the announcer says at the end of the last video '' You will always remember our name, and what we did here today'' Sounds to me like they've broke some record. I any case it should be a mid to low 10 second car from factory, that should be under 100k and weight 2 ton. I'm hoping it starts a massive horsepower war like the old days. |
11-04-2017, 07:32 PM | #73 | ||
12-04-2017, 09:31 AM | #74 | ||
Watch it Live, press play and hit the HD in the settings if you need to.
https://www.youtube.com/embed/S904Yb...&enablejsapi=1 |
12-04-2017, 10:26 AM | #75 | ||
840 HP
2.7L Supercharger 8 lbs of boost builds in reserve 14.5 lbs boost peak boost 1.8 G launch 2.3 sec 0-60 mph 5.1 sec 0-100 mph 9.65 @ 140 mph (NHRA certified) Fastest production car in the world Certified by NHRA Looks hot too: https://www.youtube.com/watch?v=3vD6A6NxySQ Last edited by CoupeKing; 12-04-2017 at 10:34 AM. Reason: more info comn |
3 users like this post: |
12-04-2017, 12:04 PM | #76 | ||
https://www.youtube.com/watch?v=S904YbiCebs
1:10:30 for the official launch - and it does launch! It lifts the front lol |
12-04-2017, 12:29 PM | #77 | ||
The 'Stihl' Man
Jesus, guess Bugatti owners would be hugging their leather?
12-04-2017, 12:55 PM | #78 | ||
Render unto Caesar
Wonder how the "street" part of its character is; how it is to live with each day.
I like the idea of big horsepower cars but from the info supplied thus far (admittedly very limited) it seems to be a comprised car. I'll definitelty be watching youtube videos of it, but if it were my $$ being laid out, I'd likely rather a "standard" SRT or even a GT350.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
12-04-2017, 01:08 PM | #79 | ||
Some good links here if you want more info and pictures.
http://www.dodge.com/demon.html#app-bmo https://iimediaevents.com/dodgechallengerdemon/ http://www.hotrod.com/articles/meant...ages-revealed/ |
12-04-2017, 01:15 PM | #80 | |||
The 'Stihl' Man
12-04-2017, 01:21 PM | #81 | |||
Certified and Banned by NHRA |
12-04-2017, 01:26 PM | #82 | ||
12-04-2017, 02:17 PM | #83 | ||
as in chopped
Wow!
Curious what time it does with the stock fat front tyres left on
-> Reading this signature was pointless <- |
12-04-2017, 02:36 PM | #84 | |||
Peter Car
12-04-2017, 02:47 PM | #85 | ||
12-04-2017, 02:54 PM | #86 | |||
One reliable source now reveals he was part of the Dodge testing team at the track. They had 5 Demons there. For 2 days they hammered them into the ground doing non-stop burnouts and 1/4 runs, and he said 9.90 consistently - that's in street mode I assume. Comes in 14 colours and Pitch Black is one of them ) |
12-04-2017, 03:34 PM | #87 | ||
Did he say 8psi boost off the trans brake and 0-60mph at 2.3seconds? Niiiccee.....
12-04-2017, 03:57 PM | #88 | ||
What a weapon, no pussy footin around with that rig
12-04-2017, 08:52 PM | #89 | ||
Za Dom spremni
I want it. What a weapon.
12-04-2017, 09:37 PM | #90 | ||
AWD Assassin
Old RIDE 2006 BFGT Gone but not forgotten New RIDE 2018 AMG Mercedes A45 Angry AWD assassin
