Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > ORSM Ford Cruise Car Club > Orsm Build Thread
Orsm Build Thread Only for the ORSM Club Members and their rides
Closed Thread
Old 09-04-2008, 04:00 PM   #61
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Originally Posted by ORSMEB
I had power steering problems, so got the EF Pulley pressed onto my old reco pump...all fixed. I also had an oil leak coming out from the T Intersection where the block, timing cover and head meet on the exhaust side...all fixed. I also had an oil leak coming out from the lowest of the three bolts holding the power steering pump bracket onto the front of the engine..not fixed. I also have a coolant leak..somewhere..not fixed.
So when I went to Wagga, I had oil and coolant in the boot which both came in handy in Albury on the way home..lol
Sh!T exactly the same problems I ran into! I had oil coming out of the same bolt and oil coming out of the timing case gasket from the same location you just mentioned. I ended up getting new timing case gaskets fitted and while it was all off I had the timing chain and guides all replaced too. Cost me $600 from the mechanics! I didn't have any coolant leaking issues and my power steering pump is fine, except for the bearings being a little noisy, there not too bad tho. Now I have a power steering fluid leak coming from somewhere, I don't think its the pump as its all clean around the joins, I'm guessing its leaking from the pressure switch as I've heard they can go pretty easy!
Good luck with it mate.
DEVLXR
DEVL-XR is offline
Old 09-04-2008, 10:35 PM   #62
ORSMEB
Steve
ORSMEB's Avatar
Lol at you having the same problems! I also need to get my alternator looked at. It's noisy... maybe new bearings are needed.
I have also bought a timing case gasket, but can't be bothered changing it...
Silver PJ Ranger XLT
...with goodies...
ORSMEB is offline
Old 10-04-2008, 08:22 AM   #63
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Its a huge job changing the timing case gaskets, you know theres two separate gaskets right? If you change the gaskets I recommend getting a new timing chain and guides while its all off. I had to get a mechanic to do mine, theres way too many things to stuff up doing it myself!
DEVLXR
DEVL-XR is offline
Old 10-04-2008, 09:51 PM   #64
ORSMEB
Steve
ORSMEB's Avatar
When the Wade Camshaft was installed, I got a new chain...
I'll do the gaskets when I don't need the car for a week.
**UPDATE** - New JMM Cam Installed!
...with goodies...
ORSMEB is offline
Old 11-04-2008, 09:47 AM   #65
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
Sooo how does it go??? is the JMM cam as good as they are talked up to be??
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline
Old 11-04-2008, 04:52 PM   #66
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
yeah tell us. this is a need to know basis lol.
Sick EB is offline
Old 11-04-2008, 10:39 PM   #67
ORSMEB
Steve
ORSMEB's Avatar
Lol Matt...! Well guys, as much as I'd love to tell you how it goes...truth is...I'm left speechless. Words just can't describe what it feels like when you haven't actually felt it!
I am still waiting for the rocker cover to get painted...then I will have an answer for you!
...with goodies...
ORSMEB is offline
Old 14-04-2008, 06:18 PM   #68
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Be interesting to see how it goes, what colour you getting the rocker cover painted? Are you going to rub back the logos and lines or just the logos? Cant wait to see how it comes up.
DEVLXR
DEVL-XR is offline
Old 27-04-2008, 05:05 PM   #69
ORSMEB
Steve
ORSMEB's Avatar
Well, I got impatient and purchased a stock blue rocker cover from pick-a-part on Thursday after work. I cleaned it all up and placed it on my engine.
RESULT: The new cam is pretty good. I'm happy with it. It has instant power as soon as I lift the clutch unlike the other one which had a slight lag coze it wasn't suited for my car completely.
I just have to replace my heater core now and replace my timing cover seal and all leaks will be fixed. Yay.
I just have to get it dynoed now...
...with goodies...
ORSMEB is offline
Old 28-04-2008, 07:19 PM   #70
MR_LON
ORSMT5
MR_LON's Avatar
and the dyno figure will be...........
don't worry to much if it ends up less than what you have now, the other cam may make it's power higher up where this one will have more usable power, peak power is not always the best.
how hard is it to replace the heater core, do you have to take the dash out?
EO XR5 with blacked out highlights, grilles & fog surround, black angel eye headlights, black turbo badges, eibach springs, bluepower custom tune, motorcade ic & intake piping, Xforce turbo back exhaust, lexus style rear fog/reverse lights, EBC red pads, Goodridge braided lines, Motul 5.1 fluid, custom fibreglass bonnet & slam panel cover, under bonnet bling & more soon
MR_LON is offline
Old 28-04-2008, 09:16 PM   #71
ORSMEB
Steve
ORSMEB's Avatar
Yes Ron. Dash out job. It's a pity because I already took it out to replace my air con evap unit :( So it's a bit of double handling.
Oh well. It has to be done.
...with goodies...
ORSMEB is offline
Old 30-04-2008, 08:25 AM   #72
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Yeah I've been advised that if you replace one of those then replace the other at the same time! The dash out is the easy bit, its getting the heater box out thats the pain with the nuts being behind the motor!
DEVLXR
DEVL-XR is offline
Old 02-05-2008, 07:53 PM   #73
ORSMEB
Steve
ORSMEB's Avatar
Well well. I received my car back today from EFI Dynamics in Lilydale.
Errol did some adjusting and upped the power a little from what it was!
They're interesting numbers, because I had 148.2 from another dyno, but this final reading definitely feels like more power - and more usable power.
From 345.8 Nm to 366.6 Nm. It's funny when standard torque is 360 Nm!
Is that flywheel Nm? Is there such a thing as flywheel Nm?
Tell me what you think..
...with goodies...
ORSMEB is offline
Old 03-05-2008, 08:15 AM   #74
MR_LON
ORSMT5
MR_LON's Avatar
took me 8hrs to do the job in my ef start to finish at night :
MR_LON is offline
Old 14-05-2008, 06:47 AM   #75
ORSMEB
Steve
ORSMEB's Avatar
I received my newly painted rocker cover back from Low_XR and am extremely happy with the job.
It has come out a treat.
I also picked up a mini pod for the rocker cover..
It looks a bit orange in the photo's, but it's not. It's a nice rich red.
...with goodies...
ORSMEB is offline
Old 14-05-2008, 06:10 PM   #76
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Yeah seen it on the weekend and I can defiantly say the photos don't do it any justice. In real life the red is very shiny and a deep, rich red, the polished lines set it off nicely too!
Steve how'd you go with the power steering spots on the paint work of it? Did it come off ok?
Oh and I heard something about your 'so called' LSD spinning singles!! FAKER!: :
DEVLXR
DEVL-XR is offline
Old 15-05-2008, 04:35 AM   #77
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
Beautiful bay there Steve, looking very sweet.
Jeeepers is offline
Old 15-05-2008, 10:42 AM   #78
RED FGII
Formerly EL-351
RED FGII's Avatar
nice 1
FORMALLY ORSM5L
RED FGII is offline
Old 15-05-2008, 04:31 PM   #79
XXRR-50
Formerly ORSMT-2
XXRR-50's Avatar
Indeed Steve, looks very nice mate. Is the mini pod functional or is it mainly for looks?
Also have you thought about getting those Pole Position red silicon hoses? I reckon they would look nice in your engine bay.
FG XR50
Nitro, ZF 6-speed, Reversing Sensors, SSL's, Redback exhaust, J.W. Speaker LED kit
Previous cars:
'03 BA G220 Fairlane
'00 T2 TE50 #063(ORSMT-2)
'96 EFII Fairmont Ghia 5l V8(TOPGIA#2)
'03 BA Fairmont Ghia I6(TOPGIA#1)
'94 ED XR6(TKFRD-6)
'93 EB S-XR6
FOR SALE: ORSMT-2 NUMBER PLATES
XXRR-50 is offline
Old 15-05-2008, 06:17 PM   #80
ORSMEB
Steve
ORSMEB's Avatar
I thought about it, but then there was a huge demand for them and they are also very expensive...I'll put it on the 'things to waste money on' list
The mini pod actually works...the stock hose goes from the inlet manifold to the rear of the rocker cover, so replacing it with a pod does exactly the same thing!
...with goodies...
ORSMEB is offline
Old 18-05-2008, 08:28 PM   #81
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Haha you smartass steve! They do look better than the plain black hose tho, hence why I put one on too!
DEVLXR
DEVL-XR is offline
Old 29-05-2008, 03:43 PM   #82
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Hey Steve what spark plug leads have you got? Brand? Size? Length?
DEVLXR
DEVL-XR is offline
Old 29-05-2008, 08:19 PM   #83
ORSMEB
Steve
ORSMEB's Avatar
Um...length - stock, size - possibly 8mm i think and brand - NGK.
Pretty much stock leads, just off the shelf at Bursons.
...with goodies...
ORSMEB is offline
Old 28-07-2008, 06:21 PM   #84
ORSMEB
Steve
ORSMEB's Avatar
Well, after 2 months, I thought it was time to do something.
I installed an EF/EL Fuelcap to replace my EB one..
Funny thing is, I have had this cap painted black for at least 1 and a half years! 3 cheers for laziness..lol
I'll just let the photo's speak for themselves..
...with goodies...
ORSMEB is offline
Old 28-07-2008, 08:14 PM   #85
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
great stuff steve!! long time coming but great stuff!!!
BLKPHN is offline
Old 03-08-2008, 10:10 PM   #86
Bakis
XR6ED
Bakis's Avatar
just looked through entire thread and it looks the treat Steve did know bout the interior stuff either, i still got a fair way to go to get mine to the standard of ur exterior and engine bay lol, slowly ill get there hopefully . nice work man
Daily - 2006 Mazda3 MPS
Weekend Cruiser/Project -1993 ED XR6
XR6ED Thread
Bakis is offline
Old 04-08-2008, 09:08 PM   #87
orsm8
orsm8's Avatar
Nothing like black to bring out the best in your machine. This car always looks nice when Stev has it on show.
orsm8 is offline
Old 04-08-2008, 10:50 PM   #88
ORSMEB
Steve
ORSMEB's Avatar
You're biased! Lol
...with goodies...
ORSMEB is offline
Old 27-08-2008, 06:53 PM   #89
ORSMEB
Steve
ORSMEB's Avatar
Well, I got some other stuff done!
Got the front end repainted and got a new bonnet - so the inside out dint is gone! I also got the wiper holes and aerial hole filled in! Sweet
...with goodies...
ORSMEB is offline
Old 27-08-2008, 09:06 PM   #90
Bakis
XR6ED
Bakis's Avatar
OMG just keep raising the bar steve, nice work... I got some new goodies on mine i'll post them up soon or maybe just show at next meeting.
How hard is the clear repeaters under ur4.0i badge to install?
XR6ED Thread
Bakis is offline
Closed Thread
