#61 | |||
Hmm...how could you fill your tyres effectively in an environment with 80% nitrogen and 18% oxygen... ![]() ...Oh wait... ![]() ![]() ![]() |
#62 | |||
Oo\===/oO
And i already mentioned that...just not as involved lol
#63 | |||
Fixing Ford's **** ups
I do know it's rather dangerous (and illegal) to drive high. I haven't seen a car 10,000 fet above my head before...have you. |
#64 | |||
No wonder I won't get on a plane. Having the tyres staying on there until they're near stuffed, with that sort of weight being put on them constantly. Just remember, plane tyres have the plane weight rammed against them, upon touch down, where other tyres have the weight placed on them. As for temp changes on planes. Cars don't fly. Only idiots behind the wheel. |
#65 | |||
XR6 Beast
- Ford Falcon BA XR6 -
Current Modifications - Pod Filter, Orange Brake Calipers, Hurricane Headers & Hi-Flo Cat, Redback Cat Back Exhaust, 12" Fusion Sub & Amp, Slotted RDA's, Acron CAI & 5" Pod. Not much just yet but it's only a start. |
#66 | |||
You have a plane tyre just "flapping in the breeze", then all of a sudden it has how many tonne placed on it, when the plane is doing 200 to 300 KPH. They also develop flat spots really quickly. As a result of these flat spots, they'd have to be replaced, because it'd be constantly hitting these spots and wouldn't take too long before it goes kerbang. A truck tyre is in constant contact with the road surface, so it's not subjected to a massive shock at some insane speed. They don't get flat spots as regular as plane tyres, because trucks don't lock the tyres up as much. (Yes trucks do lock up, but compared to a plane tyre, it's not as often) |
#67 | |||
#68 | |||
I know a few and generally they change them when they're fooked. IMA, they've done between 70,000K and 100,000K. Depending on what the truck is used for, that could be 6 months, it could be 2 years. |
#69 | ||||
XR6 Beast
#70 | |||
Oo\===/oO
What are you on about talking about????? On the first page, all the facts were had -Aircraft and Racing cars use nitrogen for its more stable/predictable behaviour. -Its use in road cars is due to the small difference in leakage (minute...really) Now you are talking about flying cars? ![]() What the hell???
#71 | ||
“Pure” Nitrogen is used in aircraft and sometimes in heavy equipment because it is relatively inert and those tyres are generally operating under extremely high pressure. At those pressures, a small amount of extra heat, or even static discharge can cause the oxygen in air to start reacting with the trace amounts of flammable material that seep out of your tyres. Do a utube search for the videos, the heat will continue to build up, and the oxygen continue to react with the tyre, until BOOM.
That’s why when a haulpak suffers a fire, or even a lightning strike, it has to be left standing for 24 hours, unless it has nitrogen in the tyres. (It’s more common not to use Nitrogen as it can be expensive unless the plant has its own oxygen enrichment system and produces the Nitrogen as a by-product.) You can do this with an ordinary car tyre, but you need to start with extreme heat such as an oxy torch. Nitrogen will NOT give you more stable air pressure, less wear, better mileage, nor better handling. At 30~40 psi, it’s a waste. |
#72 | |||
Do cars go through these massive height changes? NO, they don't. So what the hell......It's cars stay on the bloody ground, not end up 20,000 feet in the air, so these surposed benefits nitrogen have for aircraft tyres is useless for car tyres. |
#73 | ||
AFF Whore
Dragging up an old thread to prevent starting a new one but I had my tyres filled with nitrogen today after my manger at work raved on about how much smoother his BMW was with it.
Total cost was $30 for 4 tyres. Results were mixed, and I'm sure I've got some sort of placebo effect. After taking off and planting it the first thing I noticed is it actually put the majority of power down to the ground, however it was ~30degrees today so tyres were warmer than usual... interesting though. Ride seems smoother on a decent quality road, bumps don't seems quite as harsh but you still feel it. Took the car out later that night and blow me down the ride is still smooth and the power seems to get down to the road with what I would call a measurable improvement. Overall if it means I don't have to fill up the tyres except for once a year it's worth it for me. |
#74 | |||
Tyres are impervious....ie, the rubber doesn't prevent air seepage over time......Nitrogen isn't some miracle substance that prevents it. So I'd be checking as regular as you used to. Benefit is, the majority of these places "top up" the nitrogen for free to the correct tyre pressure. Downside....You have to go back to a place that sells nitrogen...Or the same place you got the filled....Not sure how they work with that side of it.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
#75 | ||
Mate i travel 6k a month back and forth to the mines for work. I have been using nitrogen for years. And yes i have proven it works. I pay $6 per wheel. Top ups r free. The bridgestone tyres on my XR did 44 -48 k per set. My last set hit 55k before i replaced them. So yes stay on the gas....
#76 | |||
#77 | |||
#78 | |||
Formally Kia Chaser
And as for getting power down, again if your tyres are inflated to the same pressures, it won't give you magic grip....
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#79 | |||
Former BTIKD
![]() Join Date: Mar 2005
