Old 11-10-2005, 06:33 PM   #31
xa bird
XA coupe owner
xa bird's Avatar
I knew of a bloke that used to do this years ago, But it was stuff called "Bon Ami" that was put on a teaspoon, then held over the carby, reving the motor to slowly suck it from the spoon, it seamed to stop oil consumption and smoke for a while.
xa bird is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 07:11 PM   #32
jmc-007
LOL get someone to try this on an MPI E-series and see what happens.
jmc-007 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 07:43 PM   #33
Kryton
Kryton's Avatar
Originally Posted by Bluehoon
Crossing the leads causes the engine to backfire.
The backfiring blows out all the crap in the carby and manifold.
Cross the leads (at dizzy cap), and run the engine a few times, and give ti some...
Then cross the leads back to original.
makes a big difference in performance.
DONT do it on an EFI car!!!!!!!!!!!!!!!!!!!
went out and tried it on the XF van before. only backfired once (dunno if it should have backfired more?) and it did make a noticeable difference when i took it for a drive.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 10:38 PM   #34
LOWAU
___________
LOWAU's Avatar
Won't the CAT get blocked from the ajax?
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 11:54 PM   #35
MustangNicko
MustangNicko's Avatar
Thats what i want someone to do :P
MustangNicko is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 08:31 AM   #36
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Don't do it too manyh times, or you will do damage, but give it some throttle and let it backfire two to three times....
Makes a difference yes..... Glad it worked for you.
Stomp 'n' Steer
FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com
Bluehoon is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 10:58 AM   #37
Thunder
I.B.S is a pain in d'***
Thunder's Avatar
Well ! What an interesting thread i have created. I honestly thought my mate was having a big lend of me.
My carby is poping and farting and flat spoting (carby fire i think is the correct term) im wondering if the Ajax would solve this?
As for the banana skin in the diff i think you will find it works better with the banana only without the skin.
I DONT BELIEVE IN NOS.............but if its given to you free at the hospital well then
Thunder is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 11:29 AM   #38
Kryton
Kryton's Avatar
after this thread im also contemplating the moth balls in the fuel tank. now if i could just remember the ingredient that gives the zing then id go find a moth ball product with the most of it and whack it in the tank.
anyone remember if they used moth balls or powder on myth busters?
Old 12-10-2005, 11:44 AM   #39
Thunder
Thunder's Avatar
What happened on myth busters? i didnt see this.
Old 12-10-2005, 03:18 PM   #40
Thunder
Thunder's Avatar
So do you guys think that the Ajax will also clean carbon deposits from the valves and ports etc? Or is that pushing it?
Old 12-10-2005, 03:27 PM   #41
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Between that and a few good backfires, yes.
You will notice the difference.
Stomp 'n' Steer
Old 12-10-2005, 03:30 PM   #42
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
Moth balls are made of napthalene, not sure if there are any other additives
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 03:33 PM   #43
Kryton
Kryton's Avatar
it made the engine rev harder and more smoothly. its like it was an octane boost.
there is a thread somewhere about it. search for Myth Busters on AFF.
Old 12-10-2005, 03:33 PM   #44
Thunder
Thunder's Avatar
Currently my car suffers "carby fire" it pops loudly every so often (as well as coughs and splutters when cold). Would the Ajax make that worse or not?
Old 12-10-2005, 03:35 PM   #45
XA Coupsta
XA Coupsta's Avatar
Could that also be a timing issue if your carby is doing that?
XA Coupsta is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 03:42 PM   #46
Thunder
Thunder's Avatar
Umm....Yeh....
Engines not firing on all cylinders, she can stall on take off cause of it.
Needs new plugs, points, carby overhaul and of course a check on timing! :
But i have other problems to worry about first, like getting the sound system installed :Reverend: :Reverend: :Reverend:
Old 12-10-2005, 03:45 PM   #47
XA Coupsta
XA Coupsta's Avatar
Sound system is very important!
But mate in seriousness - if it needs those things like you said - Ajax nor swapping leads is going to magically fix anything dude.
You are still gonna have plugs and points that are going to need replacing, timing to set, etc.
Old 12-10-2005, 04:06 PM   #48
Thunder
Thunder's Avatar
Yeh, true. But that means i have to prioritise! and thats NO fun :
Old 12-10-2005, 04:26 PM   #49
MustangNicko
Can someone please try this on an MPFI engine!!!
Old 12-10-2005, 04:27 PM   #50
Thunder
Thunder's Avatar
Why dont YOU try it :
Old 12-10-2005, 04:30 PM   #51
MustangNicko
I converted my EL to CFI ;) HAHA :P no chance ill try it first.
