Old 25-08-2005, 06:20 PM   #31
JC
JC's Avatar
Updated diagram, including in-line Fuse. Tried to edit the original, but I can't. So here it is again.
Ford Performance Club ACT
Old 25-08-2005, 07:34 PM   #32
sfr rob
sfr rob's Avatar
thanks mate!
so the fuse is there to prevent what exactly? incase it overloads the wires and melts, then could cause a fire?
thanks
Rob
Old 05-09-2005, 11:53 PM   #33
Steve_T
Originally Posted by sfr rob
thanks mate!
thanks
Rob
Well, bit late maybe but I'm just going through threads after having been away for a week or so - so I'll reply...
Yeah - basically just what you said. If the fuse is 20A then all the wires and relay etc. should be rated to 20amps or greater so the fuse is the weakest link and will melt/blow before anything else can. My foggies are 55watt each and I used 15amp wiring and a 10amp fuse and have never had a prob with the fuse handling the current. I used a Hella relay which has a blade fuse (holder) built into it so you just stick the fuse straight into the relay - makes install/wiring a little easier/neater.
Steve.
Steve_T is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2005, 12:37 PM   #34
Keepleft
Mot Adv-NSW
Keepleft's Avatar
SFR ROB wrote: "i want my fog lights to come on when my park lights are on, also when i swith to full lights they will still be on".
The front fog light positive 'feed' is taken from the PARK lights (Position/Sidelights). This means that IF the actual front fog light switch is ON, AND IF the HEADLIGHT SWITCH is on PARK, then the front fogs and park lights will be on.... that we understand.....
NOW, THEY (the fogs) WILL STAY ON IF YOU THEN MOVE THE HEADLIGHT SWITCH TO LOW OR HIGH-BEAM. Unless, you then switch off the actual front fog light switch! Under ADR/UNECE Regs this is the appropriate and therefore required at law - wiring method!
Why? 'Park' lights are actually 'position' lights in ADR/UNECE/FMVSS108 Regulations, and remain on EVEN when your low and high-beam are activated, they are designed to do that to show up the front of your vehicles outline should the low beam bulb filament fail.
DO use the relay. Choose a Compliant front fog light set.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf
Keepleft is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2005, 06:19 PM   #35
sfr rob
sfr rob's Avatar
wow thanks for all the info mate!
I was thinking it would be just easyer to have the fog lights come on AND stay on as soon as the parker lights are "engaged", then as you go to full lights (not high-beam) the fog lights would still be lit, and also remain on when the HIBEAM lights are "engaged".
i still havent put them in, since my front bar hasnt been repaired yet!
i have bought everything i need to set them up with a switch, so i might just do it that way!
P.S
do you work for the road traffic authority or something?
:lookedat:
cheers
Rob
Old 06-09-2005, 06:32 PM   #36
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
You want to have a fog light switch so that you can have only the parkers on if needed without the battery drain of the fogs.
What Keepleft was saying included fogs staying on with high beam, they don't go off.
