Old 26-02-2018, 05:44 PM   #31
FTE217
T3/Sprint8
FTE217's Avatar
Default Re: The Great Spark Plug Debate
Originally Posted by arronm View Post
Maybe Ford are lying. Or maybe they are just donkeys. Do you reckon they check gaps from off the shelf plugs when their mechanics install them
"This is the genuine oem iridium spark plug set to suit the BA Mk2 Falcon with 4.0 Turbo motor including FPV models
SK20R11 spark plugs come pre-gapped to 1.1mm and are a cold range high resistance plug to suit the Turbo
motor"
Please send us your VIN to confirm application if unsure as there are so many plug variations it is VIN specific
arronm, ask them yourself mate.
Probably not but not good practice eh.
As quoted from the ngk blurb posted by Maka,
Even if the preset Gap matches that required by your engine, it is always good practice to physically check the Gap as it may have shifted during transportation (not all spark plugs are packaged in a way that protects the firing end ).
and as for your link and they ask for the vin #, should also be asking is your motor still as per OE or if modded please advise imo. Very open advertising.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2018, 06:48 PM   #32
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2018, 09:41 PM   #33
FTE217
T3/Sprint8
FTE217's Avatar
feeling is sooo mutual.
Daily Macan GTS
Old 26-02-2018, 09:50 PM   #34
arronm
arronm's Avatar
Sometimes I wonder why I even bother.
Xtreme Ford Tuning
Old 26-02-2018, 10:21 PM   #35
FTE217
T3/Sprint8
FTE217's Avatar
No one is holding you back I assure you if you depart
Daily Macan GTS
Old 27-02-2018, 08:47 AM   #36
PooDog
PooDog's Avatar
Originally Posted by FTE217 View Post
Up until recently Autolite plugs were never pre gapped, especially those in the USA.
Only recently (about 2yrs ago) have Supercheap got blister packed in Double Platinum.
Those in your link not pre gapped.
IMO any decent mechanic checks plug gaps before fitting but thats me but I know donkeys are convinced whats in the pack is gapped correctly.
Its amazing how many plugs are dropped on the way to the counter or just not gapped properly ....not so bad these days .....agree with the decent mechanic comment above
For years ive serviced my plugs filed and regapped always amazed me how workshops bin them and chuck new ones in ...guess its the labour costs ,doesnt hurt to pull the iridiums and give them a gentle clean and re-gap , at 100,000km you usually cant see the electrode for carbon
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2018, 08:58 AM   #37
PooDog
PooDog's Avatar
Originally Posted by Roostercam View Post
Excellent post. I refuse to pay the ridiculous prices for Iridium which only allow longer use, there is no power advantage I am aware of regardless. I use $5 plugs from Bosch in the 220kw Windsor & I change them every 10,000kms. I prefer new plugs more often than expensive ones less often, but I change everything before its recommended, oil, filters, pads etc
You may change your mind when youve fitted your headers
524nm torque
Old 27-02-2018, 11:15 PM   #38
au350hp
[QUOTE=muzman;6092799]You may change your mind when youve fitted your headers [/QUOTE
And that's why I change them often, so they don't become 'attached' to the motor. It is a pia but I have made up a plug removal tool out of a few different ratchet sets which helps with the tight spots. The stock headers have one pia location, the other seven are simple. I believe the Pacemaker also create the same issue, one pia, the rest easier or is this sales talk to encourage me to purchase? My intentions are to s/c so I may use the long tube model which may be easier access. Are the stock headers that bad?
au350hp is offline   Reply With Quote Multi-Quote with this Post
