Old 07-10-2015, 08:25 PM   #31
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Default Re: does oil break down on a really long drive?
Yea short running isnt good for anypart of the vehicle.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2015, 11:29 PM   #32
mik
mik's Avatar
Originally Posted by sprintman1 View Post
Short trips kill oil. Fuel dilution, more contaminants, oil shears to a lower viscosity etc etc.
Also, i believe the engine requires a slightly richer mixture at idle to keep the mass of rotating parts spinning over at a slow speed idling = bad, back in the old days of carby`s it would have been even worse as the old carbys where not known for precise fuel control.
Old 08-10-2015, 03:40 PM   #33
99AUXR
Brad
99AUXR's Avatar
And more fuel is injected to compensate for the stuff that condenses on the cylinders.
Old 08-10-2015, 07:07 PM   #34
So what do you use?
Penrite. Been using it for 15 years now, and the only time I saw it start to fade was after mtiple high speed runs in summer. Mildly worked 351 on gas and about 6000 ks since last change. It was hpr gas 20/60 oil, so always looked clean, but checking dipstick, oil dripped when it normally doesn't.
Old 08-10-2015, 07:10 PM   #35
sprintman1
Actually means nothing. If it sheared out of grade you might be worried but with a 60W you're pretty safe.
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2015, 09:40 PM   #36
When it was changed it was very watery, which concerned me damage may have been done. No damage and a fresh change, all was forgiven.
I was using a 25/70 in my old scorpion and old man had a few containers of mobil 25/60 older engine oil so decided to use that. Burnt a hell of a lot more, to the point I almost ran the sump dry in less than a week. Never happened with the penrite, weekly checks (about 900km) and only needed a top up once in 5000km. Same with the 351. Will never use so called name brand oils in a older car. Not saying they're bad, but once bitten.
Old 10-10-2015, 09:06 AM   #37
OLDFORDNUT
OLDFORDNUT's Avatar
Valvoline, says it all doesn't it, crap oil. always has been and no doubt always will.
Hervey Bay QLD
Great trades recently- GILMORE
BOSSYONBIKE
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2015, 09:34 AM   #38
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Would you like to share your personal experiences using Valvoline?
cheer's, Maka
Old 10-10-2015, 12:24 PM   #39
sprintman1
Got some UOA's to share with us to prove your hypothesis?
Old 10-10-2015, 02:47 PM   #40
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Dont feed the troll !!!
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2015, 07:28 PM   #41
sprintman1
Just because the subject is beyond your comprehension doesn't mean it's trolling. Maybe spend some time at BITOG or NORIA and you might learn something
Old 10-10-2015, 08:21 PM   #42
Road Games
Road Games's Avatar
Obvious troll is obvious...
Old 10-10-2015, 08:50 PM   #43
sprintman1
And you still believe ignorance is a virtue. You'll grow up one day, well maybe.................
Old 11-10-2015, 08:38 AM   #44
OLDFORDNUT
OLDFORDNUT's Avatar
how is that being a Troll , maybe there high end stuff is ok(i dont know) but after using and seeing others use the cheaper valvoline xld in the 90's and seeing a grey rubber looking buildup in head and dropping oil pressure in more than one car , its the old once burnt twice shy for me
Hervey Bay QLD
BOSSYONBIKE
Old 11-10-2015, 09:34 AM   #45
sprintman1
Ashland Inc make some fine products. And oil has come a very long way since the 90's. Better quality base stocks, better additive packages.
