04-04-2014, 08:19 PM | #31 | |||
cos dont like soggy poo poo |
05-04-2014, 09:59 AM | #32 | ||
I ran a lot of cars for a lot of years on e10 from bogas stations and none of them suffered any problems from the fuel.
http://www.fordforums.com.au/showthr...sic+xp+cruiser |
05-04-2014, 05:05 PM | #33 | ||
Very bad stuff that unleaded you know, that's why the USA has gone to E10 as it had to.
Unleaded is very poisonous the ground water so they say, it's the worst ever environmentaly and it is that bad you do not wash your hands with it or it can get into your blood causing all types of problems, so they say but with E10 that's fine to do just as the old lead was. |
05-04-2014, 05:52 PM | #34 | ||
I don't have sugar in my coffee and i'm sure as hell not putting any in my fuel tank.
05-04-2014, 06:15 PM | #35 | |||
Oops!! Sorry 'bout the harsh language
2011 FG GTP 335 S/C. Auto, tiptronic. iPV ceramic headers, stainless hi flow cats and big bore, BMC filter, X3 tune, DBA T3 rotors, Roadhouse Performance pads. From Herrod; 100lb injectors, hi flow pump, Aeroflow fuel regulator, air to water intercooler, hi boost pulley kit, JLT breather. Hub dynoed at 598fwkw, 498rwkw, 959Nm torque, boost 10.62psi at 3750rpm (warm day). All done by iPV! Other rides; '21 Jaguar F-Pace, '21 Ford Ranger FX4-MAX. |
05-04-2014, 06:22 PM | #36 | ||
Running United 100 octane which contains 10% ethanol and car runs really good. If they bring P100 to all servos then i'll be happy.
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits |
05-04-2014, 06:25 PM | #37 | |||
Bad for aircraft that climb to altitudes where this contained/absorbed water may freeze and block the maze of filters, flow dividers and injectors (aircraft for the most part run on 1950's tech mechanical injectors and carbies). Bad for boats as they already operate in very humid environments which seem to be able to draw significant amounts of moisture from the warm surrounding air. From what I understand there are issues with some older fuel injected cars fuel rails being treated or coated with a substance during mannufacture for corrosion protection that the ethanol in E10 (etc) will erode away, leaving those affected components free to corrode from any absorbed water content. I also used to fill up on Ethanol at (in particular) a Bogas servo many years ago whenever I crossed the Hexham bridge over the Hunter River in my XD Fairmont Ghia. It may be a long bow to draw but when they went bust (and I stopped getting fuel there) I stopped needing to fix/replace the accel pump plunger every few months? I wouldn't think it would be a huge issue for small engines such as lawn mowers though? Happy to be wrong. Knowing Bob Katter personally many years ago (I used to fly him around Qld when I worked out of Mt Isa in the mid/late 2000's), his heart is in the right place but some of the ideas he has may not be all that well thought through.... |
05-04-2014, 06:51 PM | #38 | ||
Thats ridiculous. Majority? Maybe in your suburb. Come back down to the real world mate. And even if 75% of the cars on the road were capable of running e10 with no problems, which I highly doubt (be lucky to be 30%), what about the other 25%? Yeah, we'll just fork out for new heads, carby's and fuel systems so that all the do gooder idiots that think up this rubbish, can sip on their stupid mocha latte and think they are doing the environment a favour.
05-04-2014, 06:59 PM | #39 | ||
I'm sick of the mocha latte bashings on this forums any coffee is a godsend and I will not see its good named drag through the mud being associated with greenies or polluters
5 users like this post: |
05-04-2014, 07:00 PM | #40 | ||
" Knowing Bob Katter personally many years ago (I used to fly him around Qld when I worked out of Mt Isa in the mid/late 2000's), his heart is in the right place but some of the ideas he has may not be all that well thought through... "
I live in his electorate and I'll agree with your statement 100%. |
05-04-2014, 07:42 PM | #41 | |||
05-04-2014, 08:30 PM | #42 | ||||
http://theconversation.com/australia...ity-issue-7749
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
05-04-2014, 08:41 PM | #43 | ||
This was one of Katters policies they wanted to refine the ethanol and generate electricity at the same time
05-04-2014, 08:43 PM | #44 | ||
another funny fred
05-04-2014, 08:54 PM | #45 | ||
ethanol fuel you need to get a bigger tank to get the same distance.
v8 supercars went to ethanol they talked about components failing in the fuel system and 40% increases in fuel usages. you wont see many pre 86 cars on the road because they got rid of leaded fuel which they were designed to run on |
05-04-2014, 08:57 PM | #46 | |||
i drive an 1983 bucket of **** every day should i sell it now |
05-04-2014, 09:08 PM | #47 | ||
This same 'panic' and associated agro happened just prior to the introduction of unleaded fuel in cars in Australia.
We coped and will again if and when this legislation is passed. |
06-04-2014, 12:37 AM | #48 | ||
Oo\===/oO
The Model T ford could run on pure ethanol...
...and we whinge about percentages of it in cars now?
06-04-2014, 07:14 AM | #49 | ||
Highway wanderer
anyone care to post some real world figures comparing fuel consumption of 95RON and e10 [~94RON].
06-04-2014, 07:47 AM | #51 | |||
anyway, whinging on a supposedly car enthusiest forum won't change any of those minds that seem hell bent on change whether it's worthwhile or not. my argument isn't for "mandatory" change, it is for "choice". afterall, apparently it's a democracy, isn't it? |
06-04-2014, 08:11 AM | #52 | |||
Wirlankarra yanama
E10 approx 16.5ltr/100 Straight unleaded (no ethanol) 91RON, 15.2ltr/100 Premium unleaded (no ethanol) 98RON, 14.6ltr/100 Best milage on 98RON, best bank balance 91RON E10 V's straight 91RON, I get 8% worse milage using E10 and save a poultry 4cents/ltr at the cash register. Lets see that 4cent saving is really a 1-2% saving at the cash register I get 8% fewer kilometers per ltr - does anyone else see a problem here? It shouldn't surprise anyone, the comic picture on post#4 illustrates the production costs and "green" stupidity of E10. I'm not against E10 just price it accordingly, if E10 was say 10% cheaper there be fewer reasons for people to use it. Of course Bob Katter will probably read this post and insist the price of straight petrol be increased by 10%. |
06-04-2014, 11:07 AM | #53 | ||
Thailand Specials
Who cares about E10, I use that in my EL Falcon (United 100), we should really look at bringing at least 1 E85 outlet to every station.
That stuff is good for boosted and high comp cars, who cares if you get 30% less mileage on it its cheap and it has a real high octane rating. What has to change on a modern car (such as an XR6T) to run E85? Injectors and any rubber lines and of course a tune to match? |
06-04-2014, 11:26 AM | #54 | |||
06-04-2014, 11:31 AM | #55 | ||
06-04-2014, 11:53 AM | #56 | |||
http://www.motoring.com.au/news/2010...-ethanol-20281 |
06-04-2014, 12:05 PM | #57 | |||
And I dont care if people think its good for the environment or not, personally I dont think it makes any difference, and I think its a rubbish product, so therefore I should still have a choice not to use it. Its funny how people suport these ridiculous blanket solutions when they aren't affected directly by it, but when the one of THEIR freedoms gets taken away for no reason, with no proof, by an idiot, its whinge whinge whinge. Although, being a smoker, a drinker, a v8 owner, a car enthusiast, and a blue collar tax payer, sometimes it seems its only mine that get taken away! |
06-04-2014, 12:07 PM | #58 | |||
just so you can go back to licking fence palings |
4 users like this post: |
06-04-2014, 12:12 PM | #59 | ||
06-04-2014, 12:29 PM | #60 | ||
E10 is coming regardless of what anyone says just as unleaded came.
People were complaining about unleaded when it came in but it's no big deal you just set the engine up to deal with it, the same thing with E10. I found E10 to be rubbish when it first came out as my VY SS lost power under 1800 RPM and it sits on 1450 RPM at 100 KM/H But shell made a better E10 some time down the track and it was a lot better and i have found that just crusing on the highway fuel was the same as 91 unleaded and this was tested time and time again on the same road using cruse control but when aircon was used E10 used more then 91 unleaded, so when under more load she will use more fuel. I will not use caltex or WOOLWORTHS 91 or 95 unleaded as the SS does not like it lacks power but does like caltex E10. I run a mate at times he has a SS like mine and i can always hose his off but i was using caltex 91 once and he had it all over mine that day. it splutters and backfires like when your flat to the boards, the timing must be retarting full on due to the rubbish fuel. my VS 179 kw V8 did the same and my V6 VS i could not get it over 205 KM/H but it would do 218 KM/H with BP and shell 91. I wonder how good this imported fuels is going to be when australia stops making it's own. Old mate Hitler made synthetic fuel maybe we should make that type of stuff. |
