31-01-2014, 11:33 AM | #31 | ||
Parts Interpreter
Smashing your hip into the kitchen bench or a door knob and feeling like you've just been shot.
BFMKII XR6 Turbo Sedan
6sp Manual Pedders Coilovers Short Throw Shifter |
31-01-2014, 07:13 PM | #32 | ||
GT
when I was in rehabilitation gym work , after a work accident where I cracked two vertebrae , I was doing special weights . under a rehab specialist instruction , squats with weights , anyhow . busted my A'HOLE WITH A NICE SIZED HEMHOROID .
had to report it to work and extend rehab . never mind it went away . having had to explain it to the rehab physio next time at the gym . the look on his face was priceless as I told him what happened . when I said it's ok I understand if you laugh . he broke the sound barrier with laughter . I came up with the line , I'VE DONE BACK BREAKING WORK , AND BUSTED MY *** for this job . ( wasn't funny to me at the time ) |
31-01-2014, 07:17 PM | #33 | ||
GT
a friend of mine was working under a truck , when somehow the windscreen was broken at that time , a shard of glass found its way under the truck and sliced his eyeball open . his eyeball deflated like a bag from witnesses , he was able to get it fixed and only has some vision loss . the thought is chilling .
31-01-2014, 07:54 PM | #34 | ||
As an early teen I thought I was being a hero riding a toddlers tricycle down a driveway showing off to some teeny blondes. The tricycle had worn out handlebar grips so the the ends of the bars were exposed.
I stacked it and the bars turned in on me, I ended up in hospital with a bruised and cut ***** (as if peeenis us a banned word you freakin prudes), right in the most sensitive spot... Lucky it healed up perfect without needing stitches but maximum embarrassment at the time. One of my many unexpected failures . |
03-02-2014, 11:16 AM | #35 | ||
Formerly XG-Panelvanman
using a sharp gasket scraper to clean up a part...only to be cut by the part...
My Ride: BA MK2 Wagon, dedicated LPG, white. modifications: cargo barriers, tow bar |
03-02-2014, 11:30 AM | #36 | ||
Isn't it obvious?
pizza cutting wheel and the webbing between your thumb and index finger
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
03-02-2014, 07:30 PM | #39 | ||
Ford screwed the Falcon
How did you manage that? Please do tell.
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
04-02-2014, 09:42 AM | #40 | ||
Missing a sock...
When I was 6yo I spotted a paw-paw that I couldn't reach, found some concrete reo mesh and leaned it against the tree for a ladder. Got to the top, lost my balance and fell. Damned near skewered the family jewels.
Ended up with a punctured bladder, no paw-paw and a very ****ed off old man. Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
04-02-2014, 12:31 PM | #41 | ||
Isn't it obvious?
i remember playing lacrosse in year 8 or 9 phys ed at school
put the stick thing with the net on it down on the floor when running forward to get the ball and the end of the stick got stuck on the grass and lifted me up groin first off the ground a few inches as the end of the stick wedged in my groin....much to the laughter of fellow students hurt just a tad for a few hrs
04-02-2014, 01:51 PM | #42 | ||
I see you....
Used a long strip of off cut of carpet as a tarzan swing off a tree in the garden.
I was 8 years old but learnt three things: 1 - carpet strips are not the same as rope. 2 - you don't bounce off rock gardens 3 - head wounds bleed a lot |
04-02-2014, 01:53 PM | #43 | ||
I see you....
Also can't believe no-one has mentioned the ratchet or socket breaking and smacking yourself in the face, or slicing your knuckles open.
I know a guy who cracked his cheek bone when the allen key socket he was using snapped in half...cheap tools will do that. |
04-02-2014, 04:31 PM | #44 | ||
^^^^^^hehe, also, don't use ground down files as wood lathe tools..
04-02-2014, 04:44 PM | #45 | ||
Has anyone been chowing on good food or even chewing gum, and nipped the underside of your tongue. Try as you might to replicate the bite and you can't get your tongue into the same position for the bite
2010 FG XR6 I6 CC Ute, Nitro colour. lsd, sports suspension, Ford 18's fitted with Michelin Primacy 3 ST 245x45x18, MW Quick Shifter, Pacemaker 4500 Extractors, Carbuilders Soundproofing, KPM Street Fighter CAI |
04-02-2014, 06:54 PM | #46 | ||
A person lost an eye cutting a piece of rope. He was cutting from the underside pulling in an up direction. When he cut through the rope (which required some force) the momentum of the knife meant he smacked himself in the face and the knife went straight into his eye. Always cut in a direction away from your body!
04-02-2014, 08:35 PM | #47 | ||
GT
when i was a machinist i was milling nylon , nylon does not chip like steel does , instead one long shaving comes off the cutter , it's tricky cause if your feed speed is wrong it tangles around the cutter , with nylon you greatly increase cutter speed , and feed in speed and the shaving /offcut will throw away a couple of metres cleanly and land on the floor enabling a continual clean cut . if your game you can use a broom handle to tp keep the shaving well away from cutter , if your lazy and stupid you can use your hands , which is what i did , when the nylon shaving grabbed and pulled my hand in at lightling speed , i milled through my index fingernail and finger at lightning speed , enough for my brain to know that it was going to hurt though 1st.
04-02-2014, 08:38 PM | #48 | ||
GT
and howabout your thumb going through a cam lobe 5mm gap which is spinning it one revolution every 5 seconds , slow and steady and nothing to do but watch it go through, everybody go ahhhhhhhhhhhhhhhhhhhh , start low and end high with increasing volume .
04-02-2014, 09:17 PM | #49 | ||
What about the angle grinder bouncing off and almost hitting you in different body parts I had the grinder with a wire wheel on it almost hit my face also what about when you shear a bolt then smack your fist from the momentum.
04-02-2014, 10:11 PM | #50 | ||
Thailand Specials
^ Did you do the bolt in the vice, cutting it with a hacksaw, then punch the vice cutting the last tiny bit, trick?
05-02-2014, 10:18 AM | #51 | ||
Bolt Nerd
Uh uhh... The old Taqaandan trick eh PB?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
05-02-2014, 11:04 AM | #52 | ||
Hahaha, ^^^ Google that brought back some lols
Rocking into emergency dept at 4am I have a broken willy How do you know its broken? Mate its ******* broken ok... |
05-02-2014, 11:33 AM | #53 | ||
Man I wish I didn't google that
3 users like this post: |
05-02-2014, 12:52 PM | #54 | ||
Yeh me too wish I never did that.....
05-02-2014, 05:38 PM | #55 | ||
I was there man....
All good, bigger, badder, and no more fan belt slip now... |
2 users like this post: |
05-02-2014, 05:51 PM | #56 | ||
Adapt or perish...
I know I shouldn't but I might need to Google that later on.
Carless
05-02-2014, 09:51 PM | #57 | |||
GT4.
I thought a torn Banjo String was bad enough to warrant a mention, but you went the whole hog. Kudos |
05-02-2014, 10:59 PM | #58 | ||
I don't know if this is classed as an injury, but a few years back, my wife and I were away on a dirty weekend away, we'd been at the beach and as we walked back to the house through the bush we got a little um, you get the idea, any how a few hours late I had a pain in the scrotum and on closer inspection, I noticed a tick had jumped on the ride and was busily munching in to my money bag, we tried to remove it and it seems only some of it came away, a few hours later the pain getting worse so we went to the Emergency department of the little coastal town,
They took care of it but it as an extramly embarrassing situation
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
4 users like this post: |
05-02-2014, 11:11 PM | #59 | ||
Steel legs on the beds of 1970's & prior, those things look harmless but if one isnt careful, they are exposed metal with no protection, you could hit your pinky toe on them & they hurt like hell. Mum would find me on the floor crying 3 times a week as a toddler
Proud owner of: 1970 Fairmont XW (waiting for restoration) & my daily Venom red 2003 BA XR6T Nick. |
05-02-2014, 11:15 PM | #60 | ||
Agreed, my old house which i sold last year had sharp cornered bench tops "not rounded off" going out to rear yard & it was narrow, the amount of time ive hit those corners & the amount of bruises.........Old design & dangerous. Never got around to renovating it & make changes.
