22-12-2013, 01:23 PM | #31 | ||
Cool! Thanks!
AUII XR6 VCT ute 20 years and still going strong! |
02-01-2014, 10:12 PM | #32 | ||
I recently hooked my obdII reader up to check on some readings and out of curiosity selected the camshaft position sensor status as one of the outputs in the live data streaming.
In the 'value' column of the 'table' section in the live data streaming it came up with a value of 'yes fault' for the camshaft position sensor status. There was no DTC related to the camshaft position sensor - should I be worried about it apparently picking up a fault?
Current: 2000 AUII XR8 manual ute. 1966 XP Pursuit ute. 2012 Honda Euro manual (daily drive) Past: 1984 XE Falcon sedan 4.1L. |
03-01-2014, 09:10 AM | #33 | ||
Can someone post a ebay link to an OBD reader that will work with a 1999 Falcon AU S1.
I have bought 2 from ebay and both dont work, so a confirmed link would be great. Thanks ! |
03-01-2014, 09:47 AM | #34 | |||
http://www.ebay.com.au/itm/290618613...84.m1497.l2649 I did need to update the driver from the following link though. http://www.totalcardiagnostics.com/s...-obd2-software
Toy Car Build |
03-01-2014, 09:57 AM | #35 | |||
Do you have a copy of driver ?. Regards Don dgrover@assoft.com.au |
03-01-2014, 01:10 PM | #36 | |||
Didn't work using Gmail...fingers crossed hotmail it has worked with...
Toy Car Build |
04-01-2014, 12:48 AM | #37 | ||
Hey dgrover I bought this one http://m.ebay.com.au/itm?itemId=190517488905 just over a year ago. Finally plugged it in today, connected via Bluetooth using an old Asus n10e netbook with only 2 GB of ram running Windows 7 ultimate. I did need to connect the computer to the device first via the Bluetooth and it automatically installed the drivers and then allowed me to connect in forscan.
On a side note I connected it to my dad's territory and it came up as a 2006 model although the car is an 09. And has quite a few error codes? Can someone point me in the right direction for getting more info. Sent from my Nexus 7 using Tapatalk
Bronze Wine XY GS Fairmont Resto |
04-01-2014, 10:55 AM | #38 | ||
Thanks For Everyones help, have ordered unit and have enough drivers and software to hopefully get some readings.
Will report back when I recieve it and get it going. |
04-01-2014, 02:48 PM | #39 | ||
5.6L x 2 pilot
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
05-01-2014, 07:44 PM | #40 | ||
I cant get real time codes from mine, butg it shows the KOEO codes but cant clear the codes. It keeps saying that test interrupted, any ideas.....
06-02-2014, 07:46 PM | #41 | |||
Have another laying around I will swap out and run test again to see what values I get. Would be nice if others using the reader could also check what values they get for the camshaft position sensor. Cheers Dazza |
07-02-2014, 02:29 AM | #42 | ||
my au fairmont v8 will work fine with this program i can even run the engine tests on it but the tests wont run on my friends au1 xr6
12-02-2014, 09:21 PM | #43 | ||
Hi guys i also had the cam shaft position sensor fault value of yes any more info on this
12-02-2014, 09:35 PM | #44 | |||
5.6L x 2 pilot
I hope that I am reading your poorly structured question correctly? Not sure of a value of Yes, but you may be looking for a detailed analysis of your DTC (Diagnostic Trouble Code). Look here http://fordforums.com.au/dtc/dtc.php Hint: Punctuation has a purpose and goes a long way. We are using a written media, so please utilise some of those skills you learnt at school. Stu
2 users like this post: |
12-02-2014, 09:54 PM | #45 | ||
Hi Stu, he's referring to a response to my question at post number 32.
As mentioned in my post, there was no DTC listed.
12-02-2014, 10:04 PM | #46 | ||
5.6L x 2 pilot
Thanks Strattos.
It is hard sometimes to keep track of what sometimes appears to be random posts. That is why we have the "Quote" facility to keep the thread on track. Posting 10 posts later, 10 days later without reference can get a little confusing. Thanks for clarifying. Stu
12-02-2014, 10:12 PM | #47 | ||
All good, know where you're coming from. Congrats on getting the big girl back on the road again by the way.
22-02-2014, 02:10 PM | #48 | ||
Still messing around with my scanner and came across the following site, which provides additional information relating to DTCs:
http://www.fordobdcode.com/ While the DTC tool on our forums here works a treat, this site is also a help, providing a bit more info if needed. You just enter your code in the search bar in the upper right of the main page and go from there.
22-02-2014, 03:01 PM | #49 | ||
CNC fixer guy
Hi guys.
I posted a question about forscan and O2 sensors amplitude in the ecu section but i have no replies as yet, so i will try here Other post: http://www.fordforums.com.au/showpos...81&postcount=1 I also managed to get the engine running test to work once and it showed dtc po116 (ect) even though forscan shows 87deg and gauge is normal. I also found one table under fuelsys shows error in cmp(cam pos sensor) while the engine is running. There are no dtcs when i first connect to the car. Has anyone else come across these issues? Cheers, Andrew
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
22-02-2014, 03:48 PM | #50 | |||
CNC fixer guy
Says error. The other ones are cmp_f =yes fault, the other is cmp level=LOW. I didnt get any other faults in engine running test or dtc . I did unplug an O2 sensor while engine running with no dtc and measured with a meter. It was sitting at 0.5v unplugged from car. I still wonder why forscan displays over 2v for o2 sensors?
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. Last edited by mif73; 22-02-2014 at 04:11 PM. |
22-02-2014, 06:53 PM | #51 | ||
AU II XR8
Is there a certain part number I need for my car? It's a series 2 xr8 ute.
Thanks.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
22-02-2014, 10:17 PM | #52 | |||
CNC fixer guy
Why does this car mock me?
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. Last edited by mif73; 22-02-2014 at 10:30 PM. |
23-02-2014, 10:44 AM | #53 | |||
CNC fixer guy
In this case we are talking about an elm327 with obd2 connector or clone from ebay etc and free forscan software. The usb version is a bit more compatible.
30-04-2014, 12:54 AM | #54 | ||
FG XR50 TURBO
need help i've tried all day today to get the forscan to work it aint i have installed all types of driver's nothing seems to work i just get a pop up window saying make sure ignition is turned on. all i want to know is what driver do you guys run for it to work before i go nuts. b uy the way i brought this usb-obd2 cable, i've downloaded the driver still no luck
http://www.ebay.com.au/itm/300906920...84.m1439.l2649 cheers dean |
30-04-2014, 10:45 PM | #55 | |||
CNC fixer guy
It seems the drivers are working if it sees the obd reader as a com device and it knows if the car is on or not. Mine is similar to yours, its a usb v1.5a that i bought late last year. Mine is using the driver disc that came with it and i set it up for win xp pro. My driver is for silicon labs cp210x usb to uart bridge. Driver files: Silabenm.sys Silabser.sys Wdfcoinstaller.sys My baud rate for this port is 9600,8 data bits, no parity,1 stop bit. No flow control. Forscan is setup as auto in all fields for comms under general. Let us know how it goes.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. Last edited by mif73; 30-04-2014 at 10:56 PM. |
30-04-2014, 11:23 PM | #56 | ||
FG XR50 TURBO
yes that's drivers i have installed same as you still nothing i'm getting sick of trying it to work i spent the last 2 days trying
ps.. do you want to try and get it to work on my laptop??? |
01-05-2014, 12:15 AM | #57 | |||
CNC fixer guy
It taunts me every day. Fancy a drive over to the se suburbs on the weekend ? We can check your pc with my obd and vice versa. -Andrew.
01-05-2014, 10:44 AM | #58 | |||
FG XR50 TURBO
cheers dean |
01-05-2014, 02:02 PM | #59 | ||
Missing a sock...
I'm being a tad off topic as my question/s relate to an XH which is not OBD2 compliant - this just seems the logical place to ask.
I bought a ELM327/bluetooth without doing any homework, just assumed "she'll be right" - wrong! Worked fine on a BA, but obviously not on my XH - they're what I now believe are OBD1. More the fool me. I clicked on a link in bartsau post (#34 in this thread - http://www.fordforums.com.au/showpos...6&postcount=34) that took me to http://www.totalcardiagnostics.com/toad/ and after having a read through it appears they have software support for OBD1 via USB to laptop from the diagnostic connector for the earlier Falcons for $US97, the cable adaptor links seem a tad iffy - I'll have a closer look at them later to see if one will suit the XH/EL. Has any of you used this software or cabling before for OBD1? There's a post on the AFF about bridging the pinouts from the connector to get the fault codes to flash up on one of the idiot lights on the dash - I'm lazy and cbf going down that path if I can get around it. Just would like to read and reset fault codes, not interested in reprogramming the ECU which the TOAD software allegedly purports to do. Thanks for any input lads. Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
01-05-2014, 04:00 PM | #60 | ||
Bought one today ($10.67) on the reports given so far. Am now waiting the 4 to 6 weeks delivery......
