Old 17-06-2013, 07:41 AM   #31
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: new v6 holden using lots of oil
Originally Posted by turbo4me View Post
Buying a new fg xr6 soon, what is the recommendations for running it in?
If you're running in/breaking in a new motor READ THIS.
Bushbasher
MINE- AUII Forte
Old 17-06-2013, 08:02 AM   #32
Peter B - CV8
Originally Posted by BennyH View Post
I'm not disputing the fact that regular oil change is ideal, but why does the manufacturers recommend 15,000 kms intervals if what you suggest is true? Surely a bit of time and effort would be put in to reach the magic number of 15,000 km.
Easy - they just bump up the sump capacity......
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 09:42 AM   #33
turbo4me
Bushbasher
A great read and makes a lot of sense. Thanks for that
12.6 sec Turbonator
291 rwkw
turbo4me is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 10:11 AM   #34
zilo
BANNED
zilo's Avatar
Bushbasher
thanks for the link...but I reckon he is full of it.
Might work for snowmobiles....
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 10:42 AM   #35
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
My engine builders when I have had hot engines done tell me go hard from the off, just no sustained high rpm in one gear or lugging, other than that leave their workshop pulling a three geary is fine by them....
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 12:24 PM   #36
mik
mik's Avatar
i suspect they would calculate the engine longevity doing the 15000 k services will last the life of the car with doing proper log book services, now for the next question, what is the consensus on the car life span, for some it is probably 10 years, for me being a long term type owner, as long as i can reasonably get out of the old girl, for me 7000 to 10000 k's between changes trying to make it last as long as possible.
Old 17-06-2013, 01:00 PM   #37
Silver Ghia
Silver Ghia's Avatar
Bushbasher
Thanks for that Bushbasher, that is the theory behind my post before, taking particular note that the rings must get bedded in during the early stages of the engine running. Which is why the bores are carefully honed at manufacture to allow this to happen. If they are let to glaze over say by running too gently, its too late to go back:
Originally Posted by Silver Ghia View Post
Thats one thing with my FG, the oil level stays near the full mark right until the next service. But then I helped bed in the rings by not using the cruise control during the first 1000kms, also doing a few (not too hard) accelerations uphill during the first 50kms.
Also, here I go with my thoughts:
Originally Posted by jpd80
I had a good long talk to a metalurgist about this and came away with
the same question he asked me, "What exactly are you running in?"
All the piston and ring clearances are set at the factory, they're as good
as they will ever be and the hone on the bores is only to assist seating
of compression and oil control rings which these says are all low tension
jobbies. So apart from setting the carbon seal on the top ring,
there's nothing to really "run in"...
The tolerances between the running parts like the bearing surfaces, cylinder bores and rings, also the surface finishes of these surfaces in a healthy running engine after having been run for a while, would never be able to be replicated during manufacture.
Certainly, engine parts these days are manufactured to much more accurate and tighter tolerances and better surface finishes, also the bearing etc. materials used, ensuring the mating parts match each other better when assembled, than they were years ago. Despite this, the assembled parts will still be somewhat 'tighter' than after they have been run for a while, the period this happens is the 'running in' period, where the part bearing surfaces will be 'matching' each other .
Same with the rings against the cylinder bores, they need to be 'bedded in' which machining will have no hope of doing. This can only be done when running the engine and pushing the rings against the bores by accelerating (as per bushbashers link), not too hard or for too long however, so to still look after those new bearing surfaces.
So during that period, some 'running in' is therefore still necessary, however with the modern manufacturing tolerances and surface finishes as mentioned, this may only need to be to take it easy (but still doing enough to bed in those rings), and not load up the engine too much say by driving in a too higher gear, and avoiding sustained high speed running.
During the running in process, manufacturers like Ford with the Falcon advise not to use synthetic oils too early, as they work too effectively and may prevent the rings from bedding into the cylinder bores, which the mineral oils allow.
And I also don't understand the logic of manufacturers advising not to change the oil until 15,000 kms, I changed mine the first time at 7,500kms, the condition of the oil at that time was such I was glad I did. I just wonder what an oil analysis would have showed.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 02:41 PM   #38
castellan
You will not destroy a moden engine by giving it a floging !
You can buger it by pussiy footing it, that's for sure.
Cops flog the guts out of there cars from new.
Have heard of the VE 3.0L using oil.
If the rings were put in up side down it can use oil. a dud i know had 3 rings from factory in his HJ 308 up side down and this is why she use the oil you know.
If you take it easy with a new motor, you are a fool and do not know jack about what runing in is about at all.
castellan is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 06:49 PM   #39
FNQracing
RAGE Engineering
FNQracing's Avatar
I'll never forget the experience I had with company VS ute pool car. I was the first to drive it, had only 7kms on the clock. Anyway, I gave is an absolute flogging. It felt so good, brand new engine, as tight as a nuns you know what. I flogged it hard.
Anyway, that particular car had a reputation for "going hard" amongst the regular drivers over the other half dozen identical utes in the fleet, even the fleet manager.
Never had a balls to tell him about the flogging I gave it!
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 09:04 PM   #40
deadfish2
its purely to keep fleet buyers happier with lower running cost. the clincher to the 15,000km interval is at no more then 1 year which a lot of companys now are advertising as 1 year service intervals, or at no more than 15,000km and some euro now 20,000 with synthetic oil.
most people seem to forget the 1 year part and just say oh look im upto 45,000km now....... gees I only had my 30,000km 2.5 years ago,
the lower the km's per year but only drive 10km's a day over 6 short trips and maybe 20km on a Saturday is what does the damage
deadfish2 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2013, 08:37 AM   #41
Rodge
Rodge's Avatar
Well to those who claim its all to do with the running in, my two F6's were run in exactly the same as my SC GT-P, which is exactly how FPV prescribes it in the manual and compendium which came with the cars. Neither of the F6's used a drop but my GT-P uses a litre every 4,000 km's.
I think there's more too it than meets the eye. Like FPV with their SC motor maybe the newer sidi engines are using new super low viscosity oil ?, maybe the change to the latest low emission Dexos 2 type oils with their slightly different chemical compostion are having an effect or could it be the Holden engine is a torque-less thing that you have to belt the living death out of to get decent performance...or a combination of the above factors ?
Any way you slice and dice this thing the torquey non-oil buring Ford inline six comes out smelling like roses. (see the thread I started in the pub about the Holden motor using 20% more fuel on a back to back test with the Falcon).
Rodge is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2013, 08:55 AM   #42
cobramania
FPV BFII GT Cobra No.249
cobramania's Avatar
Rodge, slightly thinner oil being used in the GT maybe part of a factor over the F6's, but I'd bet that most or all of that litre of oil you lose is from blowby, & is coming out of the crankcase through the PCV system & into the intake/blower, not going past the rings.
The GT's have higher crankcase pressures & more blowby than the F6's purely on their cylinder capacity.
Being supercharged over turbo, makes it that much worse, forced induction over NA also makes much more blowby.
Put a dual catch can setup on your GT & see how much oil you catch.
cobramania is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2013, 10:00 AM   #43
Gobes32
Gobes32's Avatar
Maybe, just maybe, the I6 is just a great engine and we are all going to miss her like hell when it's gone...............?
A G8E would be good if Ford marketed squarely at Calais V8 owners. They need to bring back the walking fingers like in the initial FG ads, but this time have the fingers crushing Calais' as they walk along, with some relaxing background Led Zeppelin music and Marcos Ambrose in stubbies and singlet driving it.
Gobes32 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2013, 12:27 PM   #44
Rodge
Rodge's Avatar
Bullseye !!
Originally Posted by cobramania
Rodge, slightly thinner oil being used in the GT maybe part of a factor over the F6's, but I'd bet that most or all of that litre of oil you lose is from blowby, & is coming out of the crankcase through the PCV system & into the intake/blower, not going past the rings. The GT's have higher crankcase pressures & more blowby than the F6's purely on their cylinder capacity. Being supercharged over turbo, makes it that much worse, forced induction over NA also makes much more blowby.
Thanks for that, I think you've hit the nail on the head too. The super thin 5W-20 oil FPV recommend for these SC engines doesn't help, that's for sure !
Old 21-06-2013, 09:57 AM   #45
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Originally Posted by music189 View Post
Lucky non of you blokes own a late VW or BMW they chew through oil between services and its classed as normal.
Plenty of talk about it with the current VW problems
Guy at work has a Golf gti. He was saying that the engine is within tolerance to go through 1L/1000k's.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2013, 02:03 PM   #46
Rodge
Rodge's Avatar
"within spec" Dodgey Shonky Gearbox's
VW can stick their "within spec" oil, gearbox's and frankly anything else where the sun don't shine as far as I'm concerned.
Old 21-06-2013, 03:33 PM   #47
OLD BALDY
Guys, When I was a boy with my 1st car at 17 (57 years ago!!!) we HAD to change the oil every 1000miles. In that time till now oil has changed an the metals in the engine components has changed. Surely it's not the guy that screws these plastic cars together that decides the oil changes!!!!?
OLD BALDY is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2013, 04:19 PM   #48
mcnews
Trev
mcnews's Avatar
The problems with the Golf DSGs are chronic, you are brave to own any VW out of warranty, particularly a high end one, but a DSG Golf...... Run a mile!
Trev
Old 21-06-2013, 05:26 PM   #49
RANGEREST
Same ****-Different Day
RANGEREST's Avatar
Bushbasher
I totally agree with this, have a look at a Bugatti Veyron, Maserati or pretty much any high end sports car for that matter, and every sports motorcycle I've ever seen, even Harley V rods, all get an absolute caning on a dyno before they've even left the factory and some even before the engines have been installed into the vehicle.
Bax.
Current Vehicles
RA Wildtrak V6,
UA2 Everest Trend 2.0lt
RANGEREST is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2013, 06:08 PM   #50
jpblue1000
jpblue1000's Avatar
Mercedes as an example state in the owners manual I have seen an expected acceptable oil consumption of 1/4 litre per 1000Km's. This doesn't mean the engines are poorly designed or built, it means they are designed with a different philosophy to the Japanese manufacturers and obviously some Australian 6's.
The larger design tollerances of the traditional Euros proving to aide longevity etc. The Japanese manufacture to Higher tolerances to get better specific outputs per litre, and their engines may not last as long.
As for running in, on most commuter cars driving as described earlier is enough, never holding load, never idling for too long. A performance engine is a different beast, thats why they are run in on engine dynos.
The idea is to push the rings into the bores through compression. the rings are shaped to allow combustion to expand them onto the bore walls.
Of course with consumer commuters how long has the engine idled on the production line, in the ques for the transporters and in the dealers forecourt before you get to do your 'run in'
Given most of these appliances will be turned over in 3 to 5 years why stress yourselves with these thoughts. An engine using an acceptable amount of oil as designed is nothing to worry about. Thi sis of course not suggesting the GM V6 doesnt have problems like their Gen whatever V8 or the other mentioned ford engines.
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2013, 09:05 PM   #51
Bossxr8
Peter Car
Bossxr8's Avatar
There's another one in todays Carsguide. It's starting to be an epidemic. Holden have problems on their hands here.
Old 22-06-2013, 11:54 AM   #52
Rodge
Rodge's Avatar
Gotta link ?
Old 22-06-2013, 02:26 PM   #53
zilo
BANNED
zilo's Avatar
JP
My new vito has a 30,000k supposed service interval.
Holds 6 litres of oil.
Guess that means I better carry 10 litres in the cabin...cause it will use another 4 litres just to get to 30,000 and then will still need 6L to stay full.
Old 22-06-2013, 04:40 PM   #54
uniacidz
uniacidz's Avatar
It's not only the V6 engines but also the V8
Is known of and affected persons have to do consumption tests and conclusion in affected cars is to replace the engine under warranty and cars outside warranty i have read that deals being made between owner and dealership, like 50/50
From memory, no real reason what is causing it
Sent from my HTC Aria using Tapatalk II.IV.X
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2013, 05:25 PM   #55
Silver Ghia
He should ask them to "Show me where it says that or I don't believe you".
Old 22-06-2013, 05:43 PM   #56
last fairlane
last fairlane's Avatar
Cool Re: new v6 holden using lots of oil
Like Baldy said you had a service every 1000 miles 1600Ks usually every month or so
and doing my apprentiship on VWs we were always told to run the new cars very carefully ie the running in period for 3 months
but later on I worked in a Holden dealers which obviously sold Holdens but also BMWs and Chevs
well we were told to flog them and of course being 20 years old
we did as we were told
those 307 Prem 2 speeds had a hell of a time the 327 Camaros ditto
but best of all were the BMW 2002s they would blow the Chevy powered cars away and does anyone remember the signs on cars
"Running in please pass"
just my memories John
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2013, 05:46 PM   #57
Rodge
Rodge's Avatar
VW's actions in respect of DSG, Oil Consumption and other issues, (try getting them to replace a faulty DPF filter on a diesel vehicle for instance).
Old 22-06-2013, 06:01 PM   #58
something wrong
something wrong's Avatar
I have a 2011 SV6 with 50,000km and it has just had a new engine last week due to oil consumption.
It was using 1.6ltrs every 3,000km, so far only put 300km.
something wrong is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2013, 09:02 PM   #59
Bossxr8
Peter Car
Bossxr8's Avatar
Gotta link ?
It was in the paper. Check the Carsguide website maybe?
Old 23-06-2013, 01:17 AM   #60
jpblue1000
jpblue1000's Avatar
from my reading of the manual;
'The Vito comes as standard with the multifunction ASSYST servicing system, which calculates flexible oil-change intervals based on use. ASSYST measures the dynamic oil level during operation and uses this to calculate the necessary top-up amount as well as the next maintenance date. The Vito only needs to go to the workshop approx. every 30,000 km or every two years'
suggesting to me your vito might need oil more often then every 30K however Mercedes expects the owner to add it...
Im just quoting the owners manuals I have read and I believe a common knowledge that mercedes cars use oil, becuase they are designed to use a bit of oil.
JP
