20-07-2012, 10:40 PM | #31 | ||
here is one that didn't work
. . . . Landau Reference Booklet http://fordforums.com.au/wsm/landau/...20Booklet.html Collecting all Landau info especially photos and ID plate details for the Landau register. Please PM me anytime! --------------------------------------------------- Blue '74 Landau - 5.8L & C4 Viper '09 XR6T - 4.0L & ZF Black '08 BT50 SDX --------------------------------------------------- |
21-07-2012, 05:51 PM | #33 | ||
Off to the blasters next and that will never happen again, stretched the roof which was the only goo part of the original shell.
And into red brown. While the body was still on the rotisserie Dean and I decided to paint the interior, underneath, eng bay and boot in gloss black seeing as the next step was roll cage. At this point the car finally came off the rotisserie and back onto it's wheels, for semi assembly to allow the rollcage to be fitted. Car mocked up including race dash made earlier. Rollcage being fitted.... |
21-07-2012, 07:44 PM | #34 | ||
What stretched the roof? Blasting? Nice Goss in the shed by the way.
22-07-2012, 10:18 AM | #35 | |||
23-07-2012, 08:42 AM | #36 | ||
Found some more pics of the rollcage build
Rear seat modified and now fitting around the cage. This one took some work. Thanks to Alan at Oz Trim in Ringwood |
23-07-2012, 09:51 AM | #37 | ||
[quote=greenjgs]Found some more pics of the rollcage build
Rear seat modified and now fitting around the cage. This one took some work. Thanks to Alan at Oz Trim in Ringwood /quote] At least the passengers in the back have something to hold on to when you go around corners |
24-07-2012, 09:53 AM | #38 | ||
Todays installment. Making racer parts. 1st up I have turned up a fuel cap that looks like a dry break filler for fuel. 1979 was the 1 year these were a safety requirement.
Here's a pic of a real one It will mount under the hole in the boot lid Next up I have had to make press on spigots for the rear axles so the wheels locate correctly. This was made necessary due to the size of the front hubs. Pics of these when I have them This pic shows me holding the finished spigot against an axle. They press fit on then have a keep screw in the centre. One the diff is assembled I'll take a pic for the whole deal. Next I have made up some washers to tidy up how the front spoiler mounts. The spoiler has 4 only to hold it on and with a speed brace take less that a minute to take off the car. More soon |
24-07-2012, 05:19 PM | #39 | ||
Looking good mate.
This has got to be the best looking coupe ever. Can't wait to see the finished result. Wayne |
26-07-2012, 08:37 AM | #40 | ||
This next group of pics brings us up to today.
Spoke to Dean, the painter yesterday, car is wet sanded and ready for paint. Should be gloss black by Friday night and we'll be masking it up for final paint mid next week. I'll post more pics when I have them over the weekend. |
26-07-2012, 09:35 AM | #41 | ||
Very good progress. By the way are they all your coupes in the background? Nice collection if they are. Lucky boy.
26-07-2012, 10:03 AM | #42 | |||
07-08-2012, 09:51 AM | #43 | ||
Update. More work over the weekend. Diff 1st.
Set the diff Centre up, Eaton Tru Trac Locker, new version of Detroit Locker. Took some doing to get the pinion preload right and the Daytona Pinion support needed to be modified to fit the housing. Housing painted showing brackets for upper control arms, panhard mount, sway bar mount, temp sender and oil cooler line fittings. With the upper arms now added the Panhard rod is for display purposes only so the car looks original. I will be able to use either it or the upper arms, not both together. Also, started on engine block prep. Oil restricter kit fitted. Also, removed casting marks in the valley for the oil to flow back to the sump better and tapped out all the bolt holes The oil restrictors will sit about 5mm below the surface when finally installed. |
07-08-2012, 11:11 AM | #44 | ||
Car is looking really good. Can't wait to see the finished product.
30-08-2012, 08:40 AM | #45 | ||
Update. Can has been painted in Topcoat to check for any flaws that still need to be picked up, base coated yesterday, going to mask up colours today, home Saturday to start assembly. Woohoo!
30-08-2012, 03:53 PM | #46 | ||
WOW! that looks fantastic, you must be stoked.
By the way, what wheels are you going to use? Great job and thanks for the pics. |
30-08-2012, 04:38 PM | #47 | ||
If it ain't broke........
Great work............
Visitors welcome Relatives by appointment only |
30-08-2012, 04:59 PM | #48 | |||
30-08-2012, 05:10 PM | #49 | ||
Legend!!!
The Guards look brilliant. I reckon Ford should of made them standard like that for all coupes.
Great work there Graeme!!!
BARE BONES RACING BACK TO THE BONE YARD |
30-08-2012, 06:06 PM | #50 | |||
01-09-2012, 09:26 PM | #51 | ||
The one and only
I love the build
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
03-09-2012, 08:25 AM | #52 | |||
14-09-2012, 09:02 AM | #53 | ||
Time for an update. Masking and paint. I'll let the pics do the talking.
Car still needs to be blocked back and polished but I think you get the idea. Suspension and brakes in this weekend. |
14-09-2012, 01:15 PM | #54 | ||
Legend!!!
WoW!!! What a stand out looking coupe. Wont be hard to miss when its out on the track that's for sure!!!
14-09-2012, 03:56 PM | #55 | ||
WOw, that looks the business.
14-09-2012, 05:26 PM | #56 | ||
Thanks. Hopefully some pics over the weekend with Suspension, brakes and wheels on.
15-09-2012, 10:42 PM | #57 | ||
Awesome, just bloody awesome.
16-09-2012, 08:22 PM | #58 | |||
335 kw of goodness
CAUTION! STILL Contain's opinion's & fact's that may offend !!! : 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
16-09-2012, 09:05 PM | #59 | ||
Well done. Heaps of hard works gone into this for sure. Credit to you.
Cheer Rob. |
16-09-2012, 09:29 PM | #60 | ||
Sure going to be an awesome vehicle!
The Car - http://www.fordforums.com.au/showthread.php?t=11358570 The Engine Rebuild- http://www.fordforums.com.au/showthread.php?t=11361067 |
