#31 | ||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
And DASH do you have a pic? Did you take the entire surrounding out to fit what I assume is a Phillips et al cluster?
#32 | ||
Nah I bought these, they are called Strike R1's and look identical to the oem foglamps.
http://www.strike.com.au/products/Da.../Strike-R1-DRL Fit in the same position using the same hardware, just a different wiring harness. ![]()
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
#33 | ||
Virtuous Bogan (TM)
Nicely done! The wiring is for the change in resistance or something? A cluster like that does seem to put a bit more "light" out unless its just the photo/angle. I was expecting something like what you just just see on the LHS of the photo (drivers side).
#34 | ||
Nice bit of work there Dash.
#35 | |||
I am happy with the set up as the foglamps were useless to me. They need a new wiring harness as they have their own relay setup, when you put the headlights on they dim to a park lamp level, when you put the highbeam on they go bright again. The best part is I can transfer them to the next car, and put the original foglamps back in.
#36 | |||
BEN
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels. 331rwkw. 12.7 sec stock as a rock with a passenger. Now with 620rwhp ready to run the 10 built zf, built tailshaft, corn juice all to come. The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw. |
#37 | ||
Day light running lights are great i believe. Makes you seen in an instant.
The easyiest way to wire them up is using a change over relay. Pin 30. Supply with ignition power, usually from the wiper motor. Pin 85. Negitive from park light Pin 86. Positive from park light. Pin 87a. Output power to the day light running lamps So power is only supplied with key on. The power travel through pin 30 out of 87a to the lights. Turn park lights on and the relat changes power over to pin 87 removing power from the day light running lamps. Its that easy. I did this to a customers car the other day. Looks better in person. Last edited by XARATE; 18-04-2012 at 06:06 PM. |
#38 | ||
#39 | |||
Oo\===/oO
Its an up-hill battle to try an convince many on here that DRL are nothing more then a "ricer" addition... Apparently incresed daytime visablity isn't on their agender.
#40 | |||
BEN
#41 | |||
My car is bright orange, i put on headlights when it's foggy/dark, so why should i also need lights during the day?
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
#42 | |||
#43 | |||
That explains the giant wings, fart cannons, neons, spinners, shopping lists and murals, it is all about safety. Oh wait, I forgot the blind, I mean vision impaired, people....got to have a giant doof doof and blow off trumpet....... Things that are different are the things that tend to be noticed. In a line of cars with almost all fitted with DRL the one that was not would be the one that would be noticed. |
#44 | |||
But DRL's make dor a much better option. They have next to no disatvantage and dont impact the environment or other road users in a negitive way. Its like driving with your headlights on (canada made it law to drive with light on i believe) it make you more visible to other road users, great when approaching give way signs, roundabout, merging ect ect. But the advanage of a correctly fitted daylight running system is you cannont forget to turn them on. If your intrested theres some great info here http://www.infrastructure.gov.au/roa...ns_Lights.aspx |
#45 | ||
Sorry for the spelling im on an iphone
#46 | |||
![]() ![]() Join Date: Jun 2006
#47 | ||
How many times after a car crash does the driver say, "I didn't see him" even though it was the middle of the day.
Maybe if a car had these DRL(or any lights on) they might be noticed a bit more, which can only be a good thing. |
#48 | ||
Thailand Specials
I always drive with my headlights on, problem solved, lol.
#49 | ||
real aussies drive aussie
People buy cars with colors that blend into the surrounding like black, bitumen grey/silver and others and then want to make their cars more noticeable during the day? its like having a Lockheed F-117 Nighthawk stealth jet and then put drls on it for daytime running. Choose a color that stands out a bit if you really want to be noticed. Overall that would be the safest option i would think. Drls have been implemented because people with unsafe colors need them due to the high incidence of not seeing them without drls.
#50 | ||
Spot on ^^^^
#51 | ||
AWD Assassin
I believe the whole concept of DRL's has some merit in northern European countries where even during the day , the ambient light is quite dim. As a safety device for that particular situation I totally understand. So here in good old AU where we need sunglasses to minimize sunglare and very bright situations during most of the year and even our winters are pretty good , we are trying to justify a device intended for a completely different situation. If you can't see an oncoming car regardless of DRL'S or not......I'm kinda thinking you really shouldn't be behind the wheel in the 1st place. Either that or put down the damned phone , stop texting whilst you are driving , stop putting on the lippy and brushing your hair with one hand whilst fiddling with your iPod with the other.....start concentrating on your driving so you can keep an eye on that motorbike that his light on who is just about to lane split at 100klm/h whilst you are driving at 60....
Old RIDE 2006 BFGT Gone but not forgotten New RIDE 2018 AMG Mercedes A45 Angry AWD assassin
#52 | |||
Oo\===/oO
I Like my dark blue car very much ![]()
#53 | |||
I don't really like non factory DRLs though. Or the HSV after thought ones for that matter (latest GTR is a bit the same) but some of the Euros do look the part. Nice driveway btw Dash (and GT of course!) |
#54 | ||
Keep it civil guys.....
#55 | ||
There is a fundamental flaw in the clever plans such as "I always have my lights on" etc.
It only works when the background is darker than the vehicle. If the the background is bright as in snow, smoke, dust, setting or rising sun, desert, cloud etc. by turning on lights you actually make it harder to see the vehicle. There is no single answer to making a car more visible but in the big picture nearly everyone one on here is using DRLs as "legal daytime fog lights" as part of their "cool image". There is nothing wrong with that but proclaiming that the bling you fit is primarily for "safety" is no different to arguing that the $5000 400rwkw flash and mods is for fuel economy.........a river in Egypt springs to mind..... |
#56 | ||
Having driven many many hundreds of klms on Western QLD roads I can tell you that cars with headlights on can be seen 5klms away where as vehicles can sometimes not be seen until they are less than a klm away and it makes no difference what colour or how bright it is, the shimmer/haze will mask it completely, this includes trucks. However the headlights/DRLs ALWAYS shine through the haze and shimmer and even better is that as the vehicle drives over bumps in the road they appear to flash
Why is this important? try passing a roadtrain in a B/Double, takes a couple of klms, now imagine what happens when a car appears out of the shimmer or haze when you are only half way past. the whole "but if everyone has they lights on you don't stand out" is nonsense as you notice EVERY vehicle with lights on and the vehicle amongst them without lights will be harder to spot and at times just looks like a gap in the traffic line if it's the standard grey/silver colour The "certain times of day" is a very short period of time and your lights won't make it any harder to spot the vehicle Drive hundreds of klms on country roads every day for a living and you will know what I'm talking about. I always drive with my lights on because I want to be seen Lastly I believe it should be mandatory to have lights on(either headlights or DRL, Not parkers either as they are totally useless) this way the morons who insist on driving about at dawn and dusk without lights will be seen and not frighten the ****** out of you as you pull out to pass and almost run head on into them DRL are best set up to come on when ever the engine is running, Almost all fuel tankers now have lights on with the engine. though ours stay one with the headlights which causes dramas as every second idiot going the other way highbeams us thinking we are running fogs
03 BA XLS 6cyl Ute-Mercury Silver 04 Subaru Liberty GT Premium 99 Toyota 105 series Cruiser TD 99 5.8M Profish plate alloy carport decoration |
#57 | |||
#58 | |||
Oo\===/oO
This, and this only... Thats why DRL will be part of our ADR's...
#59 | |||
Go the Hogster!
Can't believe how often it seems to happen on these forums. Even from moderators......
Nitro XR50 - the last brand new one in OZ ![]() first registered Oct 2011. |
#60 | |||
