#31 | |||
XR6 Beast
- Ford Falcon BA XR6 -
Current Modifications - Pod Filter, Orange Brake Calipers, Hurricane Headers & Hi-Flo Cat, Redback Cat Back Exhaust, 12" Fusion Sub & Amp, Slotted RDA's, Acron CAI & 5" Pod. Not much just yet but it's only a start. |
#32 | ||
'69 XW
I was sucked in by the Nitrogen thing a while back when I had a car with 17" low profile tyres. I ended up just filling them with compressed air after a while because it was inconvenient to go to the tyre shop every time the tyres needed inflating. If you have a compressor at home, keep checking them yourself. The main thing for tyre life and economy is pressure, keep it consistent and you're laughing.
HIS - '69 XW Falcon - 351 with 2Vs, C4 & 9" - PB 12.88 - Now SOLD '08 CB600F Honda Hornet - stock with rear hugger, screen and rack - PB 11.97 HERS - '07 Honda CR-V Sport PB - 8.5......L/100 ![]() |
#33 | ||
XR6 Beast
Feel like I need to fill my tyres right now considering my horrible fuel usage and haven't checked them since fitting over 2 months ago >.<
#34 | |||
#35 | |||
![]() you see alot of people do alot of things, for a street car there is practically no benefit. circuit cars etc you might see a small benefit. if it's not done properly then there is no point. you need to inflate/deflate the tyres, 3 or 4 times at least to get as much of the oxygen out, get all the fluids etc out. for $30 buy the missus some flowers, there is more gain out of that as it won't just be your tyres that get ''pumped up'' that day ![]() |
#36 | ||
^^ Too funny
![]() Seems like the main benifet is holding pressure longer BUT as I'm allready in the life-long habit of checking tyre pressures every few weeks I'll save the money and take my wife out to lunch. |
#37 | |||
#38 | ||
Kawalsky
Nitrogen is more stable, it is not affected as much by temperature change that is why it is used to fill aircraft tyres
Daily: 2006 BF XR6 Magnet Ute Toy: 1978 XC Fairmont Sedan 4.1L Project: 1974 Windowless Panel van http://www.fordforums.com.au/showthread.php?t=11331735 |
#39 | |||
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
#40 | ||
Nitrogen just inflates the tyre dealer's profit margins. Outside a serious track vehicle it is won't make a difference - bit like a rear spoiler on an Excel.....
#41 | ||||
XR6 Beast
#42 | |||
#43 | ||
I have to agree with those expressing concerns about still checking tyre pressures reguarly.
I was in the habit of reguarly checking trye pressures on the wife's Subaru Liberty, until I bought new tyres and the tyre dealer talked me into filling the tyres with Nitrogen - he threw it in for free as I was buying some pricey tyres (I never skimp on rubber). As he had explained to me that I would no longer need to reuarly check pressures, only bring it in for a check/top-up in a few months - I got lazy and stopped checking the tyre pressures. Then one weekend, the wife and I decided to go for a bit of a drive down south, and as always on longer trips I checked the tyre pressures - they had dropped from 33 to 29 (kPA/PSi?). Now I check it reguarly, like before.
Quote: From www.motortrend.com "Torque is the new horsepower" |
#44 | ||
Performance moderator
![]() Join Date: Feb 2005
Ahahahah gives you a funny voice too....
#45 | |||
#46 | |||
#47 | ||
Aircraft tyres are subject to a little more change of extremes of temperature than car tyres...there's a good solid reason why plane tyres have nitrogen in them...there's literally no reason to put it in your street car apart from to lighten your wallet and fill the coffers of the guy who talked you into it...
#48 | |||
Fixing Ford's **** ups
The tyre already has air in it, as soon as it is fitted. So nitrogen ain't going to remove it is it? |
#49 | |||
Tyres by nature loose pressure. Some more than others. Not necessarily due to these other reasons. |
#50 | |||
Aircraft tyres are changed more reguarly than normal road tyres. |
#51 | |||
UUMMM, to do it properly, you need to suck the tyre hard against the rim, which is impossible. Air is ALWAYS going to exist within the enclosed tyre area, no matter if you inflate and deflate it 50 million times. |
#52 | ||
GT-P With An Ego
Fit the tyre in an pure nitrogen environment.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
#53 | ||||
Oo\===/oO
whoa...L2multiquote....
But, still meaningless, as your car tire wont be effected by the heat variables.. Quote:
What this has got to do with keeping a aircraft's tire pressure stable during one flight i dont know...
#54 | ||
rather then nitrogen in your tyres just by a plane no need to worry then get ur moneys worth.
#55 | |||
If you want to compare to heavy jets then compare it to 100-500 tonne land vehicles. Last edited by flappist; 22-03-2012 at 12:58 AM. |
#56 | ||
every 25 landings or so they re tread a tire on a 737
http://i56.tinypic.com/23hlk6p.jpg |
#57 | |||
1) Very low water levels, even light aircraft can get up to 10,000 ft when the air temp is below 0 which would cause any water to freeze and then thrash around inside the tyres during landing. 2) Nitrogen is inert and reduces degradation inside the tyre from extreme temp variations especially in heavy landings. If they tyres burst it is better to not have a lot of compressed hot oxygen available. As the tyres do not turn in flight they are only really subject to the outside air temps and outside pressure. |
#58 | |||
#59 | |||
Going back to the question, I had new tyres fitted on a van and nitrogen used, now done over 53,000km and tyre pressures have remained stable the whole time, only bothered to top up 3 times and less then 5lbs needed iirc. Tyres pumped to 40-45lbs. |
#60 | ||
Cynical Idealist
I use about 80% nitrogen in my tires (that's regular air).
Your plastic pal who's fun to be with! |
