#31 | |||
XR6 Beast
- Ford Falcon BA XR6 -
Current Modifications - Pod Filter, Orange Brake Calipers, Hurricane Headers & Hi-Flo Cat, Redback Cat Back Exhaust, 12" Fusion Sub & Amp, Slotted RDA's, Acron CAI & 5" Pod. Not much just yet but it's only a start. |
#32 | ||
Lukeyson
![]() Join Date: Mar 2005
I actually can't see Ecoboost V6 in Falcon myself. It's been attempted and aborted, maybe that's where the dodgy ;mate's advice' from the OP came from. Every Falcon would need a Bonnet Bulge just to fit the thing in.
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
#33 | ||
If they did it for 2016 though they could design the front end around the engine as opposed to simply making it fit.
#34 | |||
Forward of the B-Pillar, Mustang and Falcon could share power train, electrical and switch gear, maybe front suspension, definitely frame and frontal crash protection design for LHD and RHD... That's a huge part of the design and development costs and what's meant by "One Ford". what about to the rear of the B-pillar? - Maybe tack on the Falcon E8 floor pan for a powered rear end - Perhaps Mondeo sedan, Hatchback and Station wagon top hats? A plan like that would catch the eye of Dearborn because it uses One Ford and allows other Ford regions to colaborate and access the vehicle and defray costs.. and that's before we even consider what China's big car needs will be in the future.. Last edited by jpd80; 11-03-2012 at 12:43 PM. |
#35 | |||
#36 | |||
perhaps "One Ford" assistance can sort out an effective fix, maybe reducing cost along the way. |
#37 | |||
Computer Torque Control
Control Blade IRS and the excessive weight are the two aspects of the Falcon that are holding it back.
“Cookie Monster” 2018 BMW 118i M Sport 6MT Estoril Blue “Jill” 1997 Ford Falcon GLi Sapphire 5MT Regency “Sally” 1997 BMW 318i Executive 5MT Alpine White |
#38 | ||
Whilst I won't argue double wishbone vs multi link, Falcon's bane is its diff location and not necessarily the geometry.
#39 | |||
#40 | |||
Becuse i have driven many examples from BA through to FG and never had a problem with the IRS.. Unfortunately weight is part and parcel with the primary safety and structural rigidity. I know someone who worked at Ford on the IRS or more correctly on the rear axles that came out with the supercharged engines.. his calculations showed that the slight increase in track between BF and FG resulted in a lot more axle wrap and provided the calculations for the upgraded axles. The problem with the bushes was known about and lumped in with the axle changes. |
#41 | ||
XR6 Beast
Jeeez Luke bit rough "dodgy"
Obviously they would redesign the car, that's the idea of changing Fords/Falcons and OneFord. Hopefully this is the future of Fords cars, I wouldn't mind something that drove like an F6 and looked like a Mustang.
#42 | |||
Peter Car
It was never designed for a FWD/AWD transverse application, solely because Ford no longer offers these with V8's, the ecoboost V6 took that over. It would come down to size and packaging and the location of things like the exhaust manifolds, intake plumbing, hoses, wiring, sump location etc. They were all designed to fit a RWD application. The previous 4.6 could be used for FWD applications because it was designed that way from the start, they made the bores very small for that reason and had a much longer stroke, and they only ever used the smaller SOHC heads for FWD so it would all fit. Coyote is nearly square in terms of bore/stroke and only has a DOHC head, so size wise its bigger than the old 4.6. It turned out to be a much better engine without having to compromise on the design so that it would fit FWD. |
#43 | |||
As I said, the Coyote is externally the same size as the 4.6. With the new block they were able to get away with thinner walls. and for the record, the 4.6 quad cam was fitted to FWD Lincolns
Time to Make the Hippies Cry Again |
#44 | |||
#45 | |||
XR6 Beast
If they do end up offering the choice of a conversion kit, I sure wouldn't mind a Falcon running that sort of engine.
#46 | |||
#47 | ||
So apart for the I6 that the market clearly does not want any more, and the soon to be introduced I4T, what else could Ford stick into the Falcon based on the USA parts bin?
#48 | |||
1)I-4 ecoboost for best petrol fuel economy in sedan and Ute. 2)V6 TDCI for great fuel economy and torque in sedan and Ute 3)5.0 V8 for good differentiation to XR8, G8E and XR8 S/C Heck I would even have the same line up in Territory..go out guns a blazin' |
#49 | |||
3.5 V6 3.7 V6 3.5 EcoBoost 5.0 V8 5.8 SC 6.2 V8 6.8 V10 3.0 V6 diesel 4.4 V8 diesel 6.7 V8 diesel |
#50 | |||
#51 | |||
In my the Utopia of realistic pricing: Ecoboost XR4/G4 Series - $36,990 drive away Ecoboost G4E - $42,990 drive away 5.0 V8 XR and G series - $42,990 drive away 5.0 G8E - $ 47,990 drive away 5.0 XR8 S/C - $52,990 drive away 50. G8 E S/C - $58,990 drive away. |
#52 | |||
Lukeyson
Virtual Pivot's main claim to exist seems to be the ability to relocate the power steering rack in front of the engine so you can push the engine closer to the firewall. The trailing arms on a normal car that the tie rod ends of the steering rack hook to are angled inwards to provide toe in on turns. You couldn't get that on leading arms for steering - and I know, I had an old Mazda E2200 van with forward arms and a front mounted rack, and it chewed the outside edges of the tyres like there was no tomorrow. And the reason was that the tie rod ends needed to be outside of the wheels to get the right toe in on turns. So with virtual pivot, you can have leading arms on steering AND get toe in on turns. It's pure genius. So how many vehicles in the Ford Empire other than Falcon and Territory actually have Virtual Pivot front suspension? As a sports car, Mustang would benefit from being able to position the engine and transmission a little further rearward. As well as being the birth place of TiVCT + Turbo and hence help give birth to Ecoboost, are Ford Oz the leaders within the Ford world in the application of Virtual Pivot too? Lukeyson
#53 | ||
Mustang currently has a strut front end adapted from C1/C170 Focus
#54 | |||
Lukeyson
But if it's possible, I'd still be inclined to keep a V6T Petrol variant in there, perhaps the 2.7 for bulk sales and exports, as much as I like the idea of slotting in the 3.5. Then again, if the car is codeveloped with the US, the US will want the 3.5, then you can see the opportunity for Ford to sell the 2.7 and for FPV to run with the 3.5. I have a hard time letting go of LPi though. If the fleet markets do eventually turn the big ship back towards Falcon LPi you'd want to make sure that it was available in either the V6T or I4T - preferrably both. In fact, I've even been asking local dealers to consider selling me a fully warranted V8SC with aftermarket LPi. I just wish I could do it with an XR8 badge on. Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. Last edited by Luke Plaizier; 12-03-2012 at 07:35 PM. |
#55 | |||
#56 | |||
Peter Car
You can see from the pic that packaging a FWD V8 looks like a nightmare compared to a north/south application. |
#57 | |||
you know, something for the econo freaks that want better fuel economy and an EcoLPI version.. |
#58 | ||
I'm personally a fan of the I4 and V8 only idea (I detailed the reasons why a few months ago on this forum). My ideal model mix would be:
Falcon 500 (Mondeo LX spec level): * Standard I4T manual, live axle, no cost auto (column shift available) * Optional 'GS'/'XR' pack with firmer suspension, bodykit, 6 gauges (something I really miss!), sports steering wheel, double wishbone IRS * Optional 5.0 315 V8, manual/auto Futura (Mondeo LX with a few extras, such as climate control) * I4T manual/auto Fairmont (Mondeo Zetec spec) * I4T manual/auto * Optional GS package (as described above) * Optional 315 V8 manual/auto Fairmont GXL (spec above G6E, with tech found in Mondeo Titanium) * Standard Tickford suspension and double wishbone IRS * I4T manual/auto- perhaps an optional higher-boost (think Focus ST) version? * Optional GS package (as described above) * Optional 335 V8 manual/auto Falcon GT (not FPV GT, Fairmont GXL spec) * Manual V8, go crazy here (maybe an auto can be offered to increase sales but it would go against the spirit of the car) Forget about FPV and bring back Tickford. Stick some Ticky wings on the GS/V8 variants. The V8 can be the V8 found in the GS/GT. This allows for a 4 tier engine line up, like in the good old days. As for a diesel, forget the 2.7 V6. I don't want a V6 anywhere near a Falcon. How about the Ranger's 5 cyl? It seems to deliver much better figures. It could be made optional across the range.
#59 | |||
Thailand Specials
#60 | |||
IIRC, Spark plugs have direct coils and are 160,000 km life rated.. |
