16-04-2011, 07:54 AM | #31 | |||
I am getting old .. but ... The speed of light is relative to the observer. So if a vehicle is progressing at a good speed , the light from the headlights is traveling at the speed of light relative to the observer inside the vehicle, as well as relative to the observer on the side of the road. That having been said the "wave property of light" proponents will mention "dopler shift" in light coming from distant galaxies (this it the crazy horn thingy - prolly got a diff name for light - it is when the waves compress to give a higher frequency). but ordinary rules of physics do not really apply when an object (other than light) approaches the speed of light - IIRC, this is because the mass of the object approaches infinite, as the speed of an object approaches the speed of light - making empirical testing impossible. |
16-04-2011, 08:08 AM | #32 | ||
If we accept that a planes lift is a function of its wing contour, more area on one side, causing a pressure differential and lift, what happens when a plane flys upside down?
As the wings dont change shape, wont the aero force combine with the gravitational force and send it crashing down? We know this doesnt happen, so what goes on, or have I missed the bus entirley? |
16-04-2011, 09:34 AM | #33 | |||
[BU66OS]
If the plane is on a treadmill, they do not need to be on, because the treadmill is spining the wheels at the same speed the engines would. If the plane is on a treadmill, the air is moving no faster nor slower than it was before the plane was on the treadmill. If it did not take off before getting on, what are spinning wheels going to do? And yeah I know how an areofoil works, in theory, I did a whole term just on that shape. Please tell me we are talking about complete different scenarios Like the treadmill moves or something.
FG XR6 Turbo Nitro BA XR8 Manual
16-04-2011, 09:37 AM | #34 | |||
[BU66OS]
16-04-2011, 10:25 AM | #35 | |||
Others say that wings 'suck' ('lift'). Rubbish. If that were true, a stunt plane could not fly upside down without being 'sucked' onto the ground. Incidentally, wings' leading edges are usually pitched 'up' a bit relative to the fuselage centreline - if wings were parallel they would 'suck' more if they did actually 'suck'. |
16-04-2011, 10:27 AM | #36 | |||
The centrefolds of calculation sheets are way hotter. |
16-04-2011, 12:19 PM | #37 | |||
It would have been SPECTACULAR.... |
16-04-2011, 12:21 PM | #38 | |||
As mentioned above, lift can still be generated when upside down thanks to thrust and angle of attack, just like it can be lost by a too low angle of attack when flying the right way up. |
16-04-2011, 12:29 PM | #39 | |||
I have in fact been known to be wrong on one or two thousand occasions. |
16-04-2011, 12:32 PM | #40 | ||
i got a headache.......
16-04-2011, 12:32 PM | #41 | |||
It does not as all it does is spin the wheels, the plane moves relative to the air, the only reason it has wheels is to reduce friction with the ground. Floaty, ski and SSH aircraft doen't even need wheels. Assuming no bearing friction and indestructable treadmill and wheels the treadmill and wheels will spin at an infinite rate but the aircraft will still move forward as it pushes against the air not the ground.... If the treadmill and wheels obey the normal laws of physics it will be up to whether the treadmill or wheels fail first. Grab a pushbike and hold it on a moving walkway. From outside the walkway grab the frame and start rolling it forward. If the walkway speeds up what happens? The pushbike wheels spin faster, that is all....... |
16-04-2011, 12:35 PM | #42 | |||
16-04-2011, 12:56 PM | #43 | ||
and orange is actually blue on the inside before you cut it open...
16-04-2011, 01:16 PM | #44 | |||
Formerly XG-Panelvanman
glad im not the only one... btw...wheres Sheldon and Leonard when u need them...
My Ride: BA MK2 Wagon, dedicated LPG, white. modifications: cargo barriers, tow bar |
16-04-2011, 01:27 PM | #45 | |||
16-04-2011, 02:04 PM | #46 | |||
[BU66OS]
Or do you mean it's on a conveyor belt that moves in the same direction at the same speed as the plane? So wheels aren't moving, yet the plane itself is, in that case yeah of course it will fly.
16-04-2011, 02:20 PM | #47 | |||
Chasing a FORD project!
When I did the experiment I used a VTOL jet.
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon. |
16-04-2011, 02:44 PM | #48 | |||
ST fan
About aerofoils 'not sucking', firstly 'sucking' is absolutely rubbish terminology lol, secondly an aerofoil achieves lift by being pushed from the underside by the pressure differential from top to bottom. Greater pressure forces wing up to try and equalize pressure, not lower pressure 'sucking'.
Lift (N) = pressure differential (N/m^2) x aerofoil area (m^2) Where pressure differential = pressure on lower surface - pressure on upper surface About the relativity thing, say a car was travelling towards you at 1000m/s (unrealistic i know) with its headlights on, the light will still only travel at the speed of light (c = 3x10^8 m/s) towards you in your reference frame NOT at c+1000m/s which many people seem to think. The speed of light is CONSTANT, what changes is the perception of time ie. the driver will not have the same perception of the length of a second as the person standing on the side of the road. I know its quite a big mind-******* but you can get your head around the concept eventually. SPEED OF LIGHT is CONSTANT no matter what reference frame you are in. TIME is what CHANGES, or rather the perception of time. Which begs the question, what is time? Quote:
2013 Focus ST in TANGERINE SCREAM 2003 Focus Zetec in COLORADO RED
16-04-2011, 03:27 PM | #49 | ||||
Distance over speed. I stole that from wiki.
16-04-2011, 03:48 PM | #50 | ||
GT
HERES A QUESTION FOR THE SPEED OF SOUND . . when a plane is traveling at 2 times the speed of sound , is the sound always falling further behind the plane ?
eg the plane broke the speed of sound and is travelling at mach 2 . 10 seconds ago , so the sound is 20 seconds behind the plane , in 1 minute the sound is now 2 minutes behind the plane , and after 1 hour the sound is now 2hours behind the plane ? SOMEONE EXPLAIN THIS TO ME . |
16-04-2011, 04:06 PM | #51 | |||
ST fan
I asked the question from more of a philosophical perspective. What is time? Some say its just the fourth dimension (x,y,z,t) where matter lies in 'x,y,z' and events occur as it moves along 't'. Thoughts?
16-04-2011, 04:10 PM | #52 | |||
The aircraft is pushing against the air above the treadmill. If you were standing on your treadmill holding a rope that was being pulled forward then you would move forward regardless of what the treadmill did because your motion is not being provided by your feet. |
16-04-2011, 04:22 PM | #53 | |||
All that happens is that if the aircraft is travelling towards you it will get to you before you hear it coming. If it were travelling at the speed of light it would get to you before you could see it coming. It only appears to come from behind because in the time it takes for the sound to get to you the aircraft has move from the point where the sound was made. This is not just a phenomon of supersonic travel. Watch a V8 supercar race in real life standing back a few hundred metres from the track. Close your eyes. Listen for the cars and then open your eyes to look at them. They will not be where you are looking rather they will be further down the track. In your original question the sound would only appear "2 hours" the behind the aircraft if you were observing it from a point that is "1 hour" from where the aircraft was when it made the sound. |
16-04-2011, 04:39 PM | #54 | ||||
King of the Fairy's.
Been so long I cant remember G, its quite large from memory. Quote:
Hence the assumption 1=0 etc is false. As for the Airplane taking off, I dont know enough about Aerofoils to hazzard an accurate conclusion and am not involved in Aeronautics. However I would think that if you could take off in a plane on the spot someone would be using it? Would be helpful for say Aircraft carriers. This is however not going to work as planes like that use Jets and thrust to gain air speed to gain lift. The debate would be more whether a propellor passes a large enough volume of air at a large enough speed to gain lift. I wouldnt expect a Jet-turbine to do that, but again, don't know enough on the subject to say for sure, can only speculate. And sound is not relative like light. Here's one for you, is Light a particle or a wave????? No fence sitting!
16-04-2011, 04:59 PM | #55 | |||
ST fan
If they dont use this method they should lol, but im confident they do. On the light particle thing, isnt light supposedly photon's? which is a mass-less particle. The theory of it being mass-less falls apart though when u consider gravity can bend light, and to be effected by gravity you need a mass...... Im going with its a particle (photons), but unsure about the whole 'mass-less' thing.
16-04-2011, 07:54 PM | #56 | |||
Regular Schmuck
You legs are providing your forward momentum. Lets say you're on a treadmill matching the treadmill's speed. What you're basically suggesting is that if someone was to push you from behind while you were on the treadmill, they would be incapable of moving you forward. In fact, provided you match the treadmill's speed, you are an immovable object. |
16-04-2011, 10:20 PM | #57 | |||
If, however, you can find a way to reduce your mass to zero (ie, have no weight whatsoever), then I think you could achieve light speed.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
17-04-2011, 12:51 AM | #58 | ||
Hmmmmmmm!!
Ok, here's one. One of my questions that I've just thought about for a while.
Going on the speed of light stuff. If I look with a large Telescope at a star, do I gain an advantage on seeing the light before it hits earth? |
17-04-2011, 01:53 AM | #59 | |||
VFII SS UTE
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
17-04-2011, 03:06 AM | #60 | ||
If you had access to a time machine would it be possible to go back in time and kill your parents or grandparents?
