Old 04-02-2011, 09:19 AM   #31
mickyyyy
Originally Posted by SVR73
No problems with my car in low to mid 40's in Adelaide.
Just replaces coolant again with more Redline water wetter and purified water and the AU1 XR sat below the N of NORMAL all through the hot spell with air con on and off and me giving it some stick on the way home from work each time
original radiator from factory in 1998 too
Anything over R is not a good sign ur radiator working well and as it the original radiator i wouldnt be suprised if its about 20% blocked.
Invest in a knew Heavy Duty radiator as they have bigger cores and tubes and it wont go past M....................
Here is my thread
http://www.fordforums.com.au/showthread.php?t=11251573
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2011, 09:04 PM   #32
RAPID_BA
Drove about in my ba i6 today 40 degrees outside, air cond full tilt, drove about 20 mins then idled up for about 15 minutes (went through drive through and then sat with car started to eat my lunch. Temp didnt budge at all from normal operating temp
RAPID_BA is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2011, 10:12 PM   #33
Road_Warrior
Pity the fool
Road_Warrior's Avatar
All you guys in EF's, EL's AU's and BA's don't forget - when it's hot and you're hitting the air con, the high speed fan usually drops in as well, so you're getting almost double the airflow as you normally would without the aircon on.
Having 2 thermofans is kinda neat in this hot weather
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2011, 03:01 PM   #34
f1tzy
f1tzy's Avatar
Here is my thread
Needle moves the opposite direction between the cars your talking about
f1tzy is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2011, 05:10 PM   #35
mickyyyy
ops my bad
