Old 24-01-2011, 12:37 PM   #31
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Talking Found
Well it looks like I have misplaced my keys have returned.
Now may not surprise anyone to hear my 21 year daughter and 'accidentally' knocked them in to her make-up basket when I was helping her with cables for her PS3. She had 'looked everywhere' but they weren't in her room.
My wife had a look this morning and she found them. Now I can get back to the mod.
UK
Old 24-01-2011, 12:43 PM   #32
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
have fun..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2011, 12:28 PM   #33
Uncle_Ken
Uncle_Ken's Avatar
Right blinker wires moved and tested all OK
UK
Old 25-01-2011, 02:24 PM   #34
Uncle_Ken
Uncle_Ken's Avatar
Default Update
[QUOTE=Uncle_Ken]
OK from here I have :
and added mine
I used a spare Floppy drive power cord to make the conections.
Wil take a picture tonight to show the lights working.
Fingers crossed all good
UK
Old 25-01-2011, 04:10 PM   #35
GK
Walking with God
GK's Avatar
Thumbs up
Yep, that'll do nicely UK.
Let us know if it's all working.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 25-01-2011, 04:13 PM   #36
Uncle_Ken
Uncle_Ken's Avatar
GK
Lust got back from a quick drive. All good. Right blinker works, Lights up and up on the dimmer. Didn't rewire the ABS cause I don't have it.
GK took your advice and made it easy to reverse if I want to.
Will probbaly write this up later tonight.
UK
Old 25-01-2011, 05:20 PM   #37
Uncle_Ken
Uncle_Ken's Avatar
I know this has been covered a million times but some of the main things have never been answered, I changed my AU3 Forte cluster to a AU3 Fairmont Ghia Cluster today, all working great, only thing is that i dont have a trip meter as the high series have it in the climate control? and havn't wired up the individual door ajar and the washer fluid senser
all the tec docs around give basic instruction on upgrading a series 1 and just say change this these pins, not very easy to understand
the instructions for series 1 are pretty much the same for 2/3 with one of the wires changing colour but all pin locations staying the same
The following wires need to be moved around, in order for the Mid/High Cluster to function correctly,
1. The Park Lamp Dial (+ Positive) Illumination needs to be moved from Pin 13 to Pin 2. - Brown
2. The Dial Negative Dimmer Illumination needs to be moved from Pin 21 to Pin 3. - Light Blue / Red
3. The ABS Warning Lamp Wire needs to be moved from Pin 8 to Pin 23 - Orange/Black
4. The R.H. Side Indicator wire needs to be moved from Pin 19 to Pin 26 - Green / Light Blue (Series 1 is White / Light Blue)
(Using the Photo Below) The Pin numbers start from bottom right and go in a U shape to the top right spread over the 2 connections, so a total of 28 pins one connection has 8 pins (that does not exist on base model wiring) and the other has 20 pins
this photos is of the back of a AU3 Fairmont Ghia Cluster with a AU3 Forte Wiring loom, with the pins removed from the connection
Added by Uncle_Ken
Cables removed from holder (1) and tag the wires (2) so they can be easliy seen.
Next use a loom from a high series to make the new connections. If you don't have a loom you can modify 2 Floopy drive power cable instead (Trim the sides to allow a smooth connection, cut and remove excess slots you don't need)
and
With the loom in place, splice with wires together.
Test and thats the lot
Old 11-01-2012, 09:07 PM   #38
BadTruck81
"Layin Frame"
BadTruck81's Avatar
Default Re: Cluster question High series
Hi guys i have just fitted an au xr cluster to my au both series one have done the wiring swaps and everything is working but the low level coolant light keeps flashing the old cluster didnt have this. How can i stop this i tried bridging the plug but no luck??????
BadTruck81 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2012, 09:20 PM   #39
Uncle_Ken
Uncle_Ken's Avatar
Not sure about this one. Mine hasn't had any issues to date.
UK
Old 11-01-2012, 09:35 PM   #40
BadTruck81
"Layin Frame"
BadTruck81's Avatar
Cheers mate its got me stuffed i think i need to track down a diagram of the pin numbers for the 20 pin plug and try bridge the wire(or maybe run one) from there
Old 03-03-2014, 10:04 PM   #41
zorba289
zorba289's Avatar
Hi,
I know this is an old post but a special thanks to everyone that placed a comment on "how to", I completed this today and it worked like a charm putting a Tickford dash in a AU2 dedicated ute.
May I ask if someone can place a picture up on the rear of a Tickford dash showing the globes as some were missing and I want to get the right colours in the right positions (grey/black)
John
zorba289 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2014, 10:11 PM   #42
Uncle_Ken
Uncle_Ken's Avatar
Hi John
I now have a tickford cluster but I don't have any pics yet. Will try to get aqucik pic tomorrow if time permits.
Gald to see this old thread is still of use
UK
Old 03-03-2014, 10:51 PM   #43
mcfly94
mcfly94's Avatar
Originally Posted by Uncle_Ken View Post
Hi John
UK
tickford cluster has trip meter dosent it?
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2014, 11:29 PM   #44
zorba289
zorba289's Avatar
hi,
Thanks that would be great and appreciated.
john
Old 03-03-2014, 11:50 PM   #45
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Interesting note, I changed the cluster on a mate's Sept 98 Futura the other day
The sticker on the back of the cluster didn't say BASE like the 99 AU1 cluster I replaced it with
it said
GLi/Futura
Old 04-03-2014, 08:15 PM   #46
Uncle_Ken
Uncle_Ken's Avatar
it said
GLi/Futura
Very interesting...
found this on the next series 3 they say
UK
Old 04-03-2014, 09:56 PM   #47
zorba289
zorba289's Avatar
ripper,
thanks heaps
john
Old 08-03-2014, 05:14 PM   #48
Uncle_Ken
Uncle_Ken's Avatar
Originally Posted by zorba289 View Post
ripper,
thanks heaps
john
No Probs, how did u go?
UK
Old 09-03-2014, 10:08 PM   #49
zorba289
zorba289's Avatar
Hi
All good had 3 blown bulbs ( 2 green ones for the LCD & 1 grey) every thing working that should be. I went to the wreckers and cut out wiring loom so I can keep it looking original and if needed pull dash in / out again.
thanks again for pics
john
Old 01-03-2024, 02:08 PM   #50
Shen Long
i know this is a very old thread, i was just wandering, I've done all the things needed to upgrade my Ford S3 Futura to a high-series Ghia cluster, but for some strange reason, i can NOT get the illumination to work [cluster lights]. Any ideas???
Shen Long is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2024, 08:36 PM   #51
Uncle_Ken
Uncle_Ken's Avatar
Not yet
Old 15-03-2024, 01:35 PM   #52
Uncle_Ken
Uncle_Ken's Avatar
This might help, https://www.fordforums.com.au/showth...1273828&page=2
