Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
#31 | ||
i should probably ask this elsewhere, but...
does the std FG master cyl work fine with these brakes and is it fine to upgrade the front only then do the rears when i have some more coin? how will the bias and dsc be affected... also vs std brakes, will there be a loss of comfort eg, grinding squealing etc... or is it possible other than the occasional passenger through the windscreen that i wouldn't know unless i was braking hard or looking at them that they weren't the stock items... i ask this as im in need of brakes even though ive done just 7000km mine are shagged, scored rotors, next step is heat shots and shudder, i dont race the car at a track, but ive had the standard FG turbo brakes smoking plenty of times.. |
#32 | |||
Race Brakes Sydney
With the Brembo brakes fitted you will find your high speed braking will improve and so will the constant hard braking when towing is done.You should have no grinding or squealing but that can depend on pad choice and how you drive.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
#33 | ||
Has V8 envy
Any updates Matt??
Is there any chance whatsoever, that these 6potters with the 380m disc will fit on the 18" BA typhoon rims? There will certainly be enough spoke clearance but I'd be worried about clearance in the barrell. Especially with some wheel balance weight thrown in. Any chance at all?
2005 BA F6 Typhoon 360rwkw GTX35/82r + 82lb injectors Nizpro 4" exhaust Plazmaman 1000hp IC/piping/BOV/plenum Process West surge tank Crow springs TEIN super streets 6/4 brembos TUNED BY BLUEPOWER RACING
#34 | ||
GT-P With An Ego
Kinda interested Matt.
What rotors are being used? i.e. will they be easy to replace? As you know I go through mine a little quickly ![]()
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
#35 | |||||
Race Brakes Sydney
Not sure but i think they will need atleast 19" . The caliper will sit about 1/2in or 12.5mm out further than what it currently does if that helps. Quote:
With all the information i have shown who thinks they will be buying a kit with the current prices and before christmas ? Please put name and car model with full front kit or rotor upgrade please. 1. 2. 3. 4. 5.
MATTHEW PEARCE
#36 | ||
GT-P With An Ego
I'll have to do some checking on the weekend regarding clearance. As I have a set of 18's with semi's on them I'd like to be able to keep using.
So the calliper doesn't move inboard our outboard any? just 12.5mm further from the hub? Also swept area, do the pads cover the whole face of the rotor? I've seen upgrade kits before where the pads only cover X% (say 75%) of the rotor surface resulting in very weird wear. As for the ~$2400 initial price, sounds a little steep, but I understand custom brackets and hats won't come cheap - what would replacement rotors cost (if that's reasonable I don't have a problem with a higher initial price). Sorry to be picky, but I like to be properly informed. Thanks
#37 | ||
Has V8 envy
Matt, I will also take some measurements this weekend. I will still like to be able to fit my factory rims if possible. I noticed that CAT600 had a 380mm brembo setup put under some 18" rims on his latest FG project. There was JUST enough room in the barrell even with wheel weights in place.
#38 | ||
he also had 8 piston callipers!
2015 Toyota Landcruiser 79 V8 SC |
#39 | ||
Has V8 envy
^^^ correct.
#40 | |||
I miss my wheelbarrow
![]() Join Date: Jan 2005
I feel that 19"ers are going to be the minimum if using an OEM rim. Daniel |
#41 | |||
Race Brakes Sydney
1.The calipers will only move roughly about 12.5mm further from the hub. 2.The swept area is larger than the pad surface area - reason is we are not making custom rotors to fit the calipers/pads but using what is available on the market at hopefully affordable prices. 3.Replacement rotors at the moment for this kit would be under $400 each. 4.To have brackets and aluminium hats custom made is expensive on small qty's. Pad swept area answer. On the current rotor we are thinking of using there is 8 -10mm of left over surface area from the pad and the pad has about a 55mm surface area.The pad depth on the rotor is about 64mm which is the most common size as we also have to make sure the brake pad backing plate does not foul on the hat when the pads wear out and also the bottom of the caliper clears. Any more questions please ask away and hopefully i can help before this goes ahead
MATTHEW PEARCE
#42 | ||
GT-P With An Ego
Grabbed my 18"s (Speedy Cobalt - listed as Brembo compatible), chucked one on the front and did some unscientific measuring - with my finger which just happens to be 12.5mm thick just past the nail.
Looks like it may be possible (for these wheels). Matt I'd be happy to test a BA/F bracket for you.
#43 | |||
Race Brakes Sydney
MATTHEW PEARCE
#44 | ||
Nizpro Enhanced F6 Ute
i have a BF tornado with 6 pots front / pbr rear.
how much for just the 380mm front rotors/hubs and brackets, i want the brembos to stay where they are. and what are the factory brembo brake pads going to cost as an extra?
BF F6 TORNADO NIZPRO 2 + ENHANCED!
All the Nizpro Goodies! Big power and low boost! FORD FAIRLANE AU MILLENIUM The Highway Cruiser! 2006 YAMAHA YZ 250 2T My Relaxation method! |
#45 | |||
Race Brakes Sydney
$2500 with slotted discs and i have a set of factory brembo pads here but 1 pad has a small piece of pad material broken off about half pad thickness deep at the bottom of the pad and you can have these for $200
MATTHEW PEARCE
#46 | ||
Has V8 envy
Matt, I have decided that I want to be able to retain my stock rims, these 380mm rotors will not fit - so I am out.
I am now considering the AP Racing 6pot 362mm fronts vs. 6pot brembos. AS I already have teh 4pot brembos on teh rear, do the AP callipers come in red or are they only in black? If so, I will probably opt for the 6pot brembos to maintain consistency
#47 | |||
Race Brakes Sydney
MATTHEW PEARCE
#48 | ||
That is a great price for the front i have been waiting for year for this kit .
Would have been good if it was 4 spot 355 for the rear |
#49 | |||
Race Brakes Sydney
MATTHEW PEARCE
#50 | ||
I hope so;)
#51 | ||
I hope so i would be keen for that kind of kit
#52 | ||
Would there be any chance of putting a photo up of the brakes mate
2006 BF F6 ute 710rwkw Built at Diesel Gas tuned by FPT Interior by Leather FX, PM vegabass for all your interior needs |
#53 | |||
Race Brakes Sydney
MATTHEW PEARCE
#54 | ||
Ok mate
When u have a firm price on the brakes pm plz just for the front BF F6 Trav
#55 | |||
Race Brakes Sydney
MATTHEW PEARCE
#56 | ||
With thanks
#57 | |||
Race Brakes Sydney
If you went with FG brembo's then the 378mm front set up is about $3500 and we put the crossover pipe adaptor in to get them correct as we have a good price on FG 6 pots atm OR If you went with the original BA brembo's and the 378mm set up about $3800 as the calipers are dearer than the FG ones.( this is depending on stock at the time ) The prices are a guide because often the suppliers are stocked up 1 minute and no stock the next which results in them changing prices for us.
MATTHEW PEARCE
#58 | ||
Ok thanks with the FG 1 will the brake still be in the 9 oclock?
#59 | |||
Race Brakes Sydney
MATTHEW PEARCE
#60 | ||
Pro Street Au Ute
Has this idea gone any further at all? sounds good.
Daily. AU XR8 s2 ute auto Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker. |
