16-06-2010, 08:42 AM | #31 | |||
16-06-2010, 09:03 AM | #32 | |||
as in chopped
They've gone quiet while they get the evidence to void the warranty. Asking for some "inside" info sounds like you are worried.
-> Reading this signature was pointless <- |
16-06-2010, 09:20 AM | #33 | ||
Snooping around behind the dealers back isn't going to help your cause, the fact that they're taking it seriously and fully investigating your concerns should be reassurance enough at this stage.
I understand you're curious but leave the dealings with the dealer at this stage. Give the dealer some respect by allowing him to deal with it properly, if he doesn't know what's wrong then probably he simply doesn't know however i'm sure what ever the issue is it will be explained to you when its diagnosed/resolved. To be perfectly honest my main concern would be that i was given another car till its resolved. This is what new car warranties are for, simply give it back and say "FIX". Its not your problem, that is unless you've done something to void your warranty like a flash tune.....
335 S/C GT: The new KING of Australian made performance cars.. |
16-06-2010, 11:19 AM | #34 | ||
This wouldn't be the first or last time Ford put a dud engine into a car.
My BF had an engine fail at just under 3000km. New engine was sourced from the production line and stamped to match my car. Problem was excessive endplay in the crank causing the crank to sieze in the tunnel. To the point where it couldnt be turned by hand. Took over a month to resolve and get the new engine in. Subsequently had the turbo and ZF auto fail as well, and were replaced with new ones. I don't think the original owner knew exactly what was happening either. She was kept completely in the dark for the month. "Here's your loaner car, go forth and come back when we call you"... I found out from researching the history after I bought it. I remember reading (I think it was here) about a bloke driving his G6ET home from the dealer, and 10km from the dealer it shot a rod out the side of the block. So all the best, and keep on them. |
16-06-2010, 11:40 AM | #35 | |||
I am not worried that it won't be warranted, I am worried that no one will talk to me about it ( while I wrote this, the service manager has called me and explained what they have been asked to do. Check the valve caps are up to tension, and apart from that, the engine plant has requested the PCM )
The only issue with our new FG XR6T is that no one has told me how to prevent the stains on my shorts that happen ever time i mash the accelerator pedal : and now the lil dint in the rear bumber http://www.fordforums.com.au/showthr...30#post4142130 My speed limiter is set to 120 - anything over that and she punches me in the arm. |
16-06-2010, 11:46 AM | #36 | |||
16-06-2010, 02:32 PM | #37 | ||
Custom FG XR6!
looking forward to an outcome from this whatever the result.
2009 FG XR6 BUILT BY FORD, TWEAKED BY ME!
16-06-2010, 04:04 PM | #38 | |||
Lucky, lucky bastard!
Etc, etc, etc To the Op, open up the channels of communication...put the phone away, turn off the computer and go down there, face to face and speak to them about it.
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue 2012 FPV GT-P 6spd Auto, Lightning Strike |
16-06-2010, 06:55 PM | #39 | |||
All modern Fords do, even says so in the handbook. The Police can even use it if they get appropiate warrants etc. |
16-06-2010, 06:57 PM | #40 | ||
Got some more Information this evening, a complete long motor is being plucked from the production line, being stamped with our engine no. And being shipped up for delivery on Friday hopefully. PCM is already on the way back apparently. The service manager still hasn't been informed on what the cause was, and is absolutley gob smacked that we have a replacement long motor. He hasn't heard of anyone getting one, but he has sent one down for repair though
either way, problem sorted, and no one is any the wiser to the cause
16-06-2010, 07:01 PM | #41 | ||
^ Err no, the ECU has no logging facility. Only thing they can see is whether its been flashed, and how many times its been done.
16-06-2010, 07:15 PM | #42 | |||
To be honest you cant blame Ford for wanting to keep a lid on their Findings.. The line they'll probably play is "defective engine was replaced".
16-06-2010, 07:35 PM | #43 | ||
Rob
maybe Ford want to be certain before they open their mouth. they'll probably pull the old motor down and see if they can pinpoint the issue.
i'd be pretty frustrated at being kept in the dark though. alls well that ends well i guess |
16-06-2010, 07:49 PM | #44 | |||
16-06-2010, 07:52 PM | #45 | ||
@QIK006, Well thats good news. So thanks to you for finally telling us the problem and what is being done to fix it.
Would be great if you could post the final results of what exactly happened and why..if Ford tell you all of it that is. Now if anyone else has a similar problem they'll know what to do and expect.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
16-06-2010, 07:54 PM | #46 | ||
71Mach1
It makes you angry doesn't it. You just gave them a big wad of money for one of their products, and they still treat you like the opposition.
I know it commercial confidentiality... but it's this lack of customer service which they're famous for ... They act like they're doing you a favour by selling you a car and that they don't need your business... They couldn't be more wrong...
roses are #FF0000 violets are #0000FF all my base are belong to you |
16-06-2010, 07:59 PM | #47 | |||
16-06-2010, 08:07 PM | #48 | ||
I took the advice and ditched the ph & CPU and talked directly to the service manager, instead of the the service guy that was assigned our car, the level of service changed phenominally, and although I wasn't informed of the problem, I think I was kept in the loop as much as the dealership were.
16-06-2010, 08:10 PM | #49 | ||
I can feel the frustration of the OP. I had my car fail at less than 200km on the clock, I'd had it for 2days, It came down to the a/c belt not being put on/tensioned properly causing it to fray, damaging the cam belt and in turn the pistons(?). Ford had it for a month while the rebuilt the engine. It ruined my first new car experience ><
Tenille
2010 Zetec Fiesta: 1.4l auto To date: Phillips H1 & H7 Bluevision bulbs, K&N Panel filter,Centre console, clicon system for gps To Do: 17" wheels and possibly lowering |
16-06-2010, 08:15 PM | #50 | |||
16-06-2010, 08:26 PM | #51 | ||||
16-06-2010, 08:39 PM | #52 | ||
Mechanics just like medicine is not an absolute exact science, things can & do go wrong with human interaction, the end result is the issue is being resolved, all should turn out rosy
I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle. - Winston Churchill |
16-06-2010, 08:54 PM | #53 | |||
Rob
given the limited info the OP is prepared to share(and fair enough too) i'd say the car has had a pretty normal life in the first 6000km. |
16-06-2010, 09:46 PM | #54 | ||
Peter Car
I don't see why people are jumping to such stupid conclusions.
I work for Ford and can tell you exactly what happens if an engine fails in the field, it needs to be thouroughly checked over and the problem found, to make sure the problem can be isolated and steps taken to make sure it doesn't happen again. Its called quality control FFS. The one guy as you say has full responsibility for finding and fixing the problem. The ECU would have been pulled to check for fault codes, what number ECU program it was running etc. This is all part of the investigative process. Ford do not keep check of the way the owner drives by way of how many times its red lined etc. If they want to see how certain owners drive they plug a special electrical box to the ECU and log all the info. They asked my father to do it a few years ago when they were doing investigations into how the customers actually drove the cars in the real world. The standard ECU cannot do this. The engine would now be in the engine plant and it would be in pieces. If its a problem caused by human error or some type of machining or casting fault the workers involved will be informed of what has happened and what to look out for so the issue won't happen again. Its standard practice. The dealer was only doing what the company would have told them to do. Obviously the problem is terminal if a new long motor had to be built. It may be some type of cam timing issue if the engine was pinging on 98. |
16-06-2010, 10:02 PM | #55 | ||
@Bossxr8,well said and given the complexity of todays engines and their management systems it probably would'nt take much if something is just out of tolerance etc.
16-06-2010, 10:09 PM | #56 | |||
Obviously the factory dont trust a dealer to report any fault codes, so they waste more time mailing PCM's around Should be as simple as "engine rooted, get new one or rebuild exisiting" so the customer knows the deal. I personally spent way too much time waiting in the dark for things to happen with my car because of Fords crappy procedures. QIK006 hasn't said how long he's been waiting. But I know my car spend 5.5 weeks at the dealer waiting for its new engine under the same circumstances. |
16-06-2010, 10:11 PM | #57 | |||
At the end of the day the customer doesnt need to know how or why, in this particular case the cause may still be being investigated many links from the dealer, all they need to know is its been fixed properly...
16-06-2010, 10:13 PM | #58 | |||
QIK006, my advice to you, having been in a similar position, is find out EXACTLY what went wrong... Then monitor any components around the damaged part, as more things may/will fail because of the original problem. |
16-06-2010, 10:17 PM | #59 | |||
Its under warranty so anything else that goes wrong will be covered just like the engine was.....
16-06-2010, 10:18 PM | #60 | ||
There are two issues here, Ford investigating a problem with the vehicles' power train
and how the problem with the customer's car is being dealt with. Imagine yourself for a minute with a 6,000 klm XR6T with a terminal problem, an owner has the right to have his car repaired in a timely manner. It shouldn't take that long to rule out owner neglect/abuse.... This is a case where good will and speedy replacement are the best ambassadors... |
