Old 21-12-2023, 06:16 PM   #361
HIPO
Al
HIPO's Avatar
Default Re: Radio control
The footage from this video was what sucked me in.....
https://www.bing.com/videos/rivervie...2&&FORM=VRDGAR
HIPO is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2023, 04:53 PM   #362
HIPO
Al
HIPO's Avatar
The steering servo could do with upgrading, down the track. Don't consider it as strong enough.
When i figure out the characteristics better, am looking forward to shock & diff maintenance & tuning.
Having 3 adjustable LSD's makes it interesting. (rear one on the EXB as well)
Old 23-12-2023, 04:04 PM   #363
DJM83
Barra Turbo > V8
DJM83's Avatar
Fitted a new shell to me Baja Rey.
Who in their right mind at Losi thought 22 tiny easily rounded out screws to attach a 4 part shell which is only replaceable as a whole not in parts was a good idea.
I think with this one i might trim a little behind the front wheels as these tyres are a little wider than the standard ones and chewed the old shell.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2023, 05:37 PM   #364
HIPO
Al
HIPO's Avatar
Glad i got curious about the "droop" settings.... rear was set to allow full shock extension, so have shortened by about 5mm.
Seems to have put the drive shafts into the diff end cup slightly too.... can understand why some peeps have them pop out.
Old 24-12-2023, 05:44 PM   #365
DJM83
Barra Turbo > V8
DJM83's Avatar
Took my Mojave out today, behind the local rc track is a motorbike track kinda, but theres some roads leading into it.
Was able to stretch its legs (only 75% throttle) was a hoot. I got a rock stuck between suspension and wheel, its scored the inside of the wheel, not badly though.
Really need the net thing to stop junk getting into the chassis and important parts!
Old 24-12-2023, 05:55 PM   #366
HIPO
Al
HIPO's Avatar
Good stuff! yeah almost every drive, i've ended up with a stone either stopping the ESC fan or right down in it.
Also need some bitumen tyres, have been back in that carpark & its taking its toll on tread levels.... have already front to backed them.
Old 24-12-2023, 09:26 PM   #367
HIPO
Al
HIPO's Avatar
Curiosity & lack of faith, will see me pulling all 3 diffs shortly. Want to check oil levels & as they supply diff shims, will see about that too.
Will leave the "friction plates" in the rear LSD as is, but centre & front will be rearranged for less slip. Will use stock weight oils for now. Front & rear run 10,000 & centre 100,000.
This is proving to be a good distraction!
Old 24-12-2023, 11:07 PM   #368
roddy1960
roddy1960's Avatar
G'day... Looks like a great thread...Been off AFF for a fair while unfortunately due to other stuff and health matters ..
First up and it's not R/C but I love my HO Scale 1:87 model railway mostly in DCC now but I have also been doing radio control with construction /earthmoving models .
Been doing it about 18 months I guess now , It's not actually hobby grade although my most recent purchase is pretty good . Sticking with Huina as it's an affordable entry into this type of radio control hobbying .
I have three excavators all 1:14 scale . They are the 1592, 1593 and the notably more expensive 1594 with full metal undercarriage ..Two dump trucks also Huina also 14th scale and I dabbled with a dozer 1:16th but it isn't. It's more like 1:20th at best , Heavily modified it though and is okay ..
In Europe especially this style of R/C is humungous ..It' s really expensive as well with the serious enthusiasts spending big bikkies .. Somer of the ScaleArt suff is exquisite and many use real hydraulic systems to function ..
Its lots of fun but way out of my league .. I don't regret probably spending $30,000 over the past 15-16 years on my rail nor do I regret spending maybe $1500 getting into base level construction radio control .. I know I;d really regret not doing it because you only live once ..
Just a taste of the real stuff in Europe...think this is Germany or Austria ..
https://www.youtube.com/watch?v=ff4o3BpaYtU&t=1303s
roddy1960 is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2023, 07:26 AM   #369
HIPO
Al
HIPO's Avatar
Have watched some of those vids & yes theres some amazing machines.
Have seen & played around with some rail set-ups, some yrs back. All beautiful German products !
Also becoming interested in scale rock climbers.
Old 25-12-2023, 08:02 AM   #370
HIPO
Al
HIPO's Avatar
You need this body!
https://es.aliexpress.com/item/40011...d=VvBc6W9pty2o
Old 25-12-2023, 01:04 PM   #371
HIPO
Al
HIPO's Avatar
Front droop was the same....fixed. Good way to break them!
Old 26-12-2023, 08:09 AM   #372
DJM83
Barra Turbo > V8
DJM83's Avatar
Originally Posted by HIPO View Post
Yeah id rock that, but doesnt look like it'll fit. Looks to be for a traxxas UDR.
I did get a cpl vouchers for hobbies direct so i might do some shopping this week!
Old 26-12-2023, 08:32 AM   #373
HIPO
Al
HIPO's Avatar
Derr! yep..... they do a CF body for $500+ too...lol
Old 26-12-2023, 08:42 AM   #374
HIPO
Al
HIPO's Avatar
Man these are cheap now.... hows the amount of easy tuning with my Hobbywing ESC!
https://www.ebay.com.au/itm/29608249...Bk9SR7CP166UYw
Old 28-12-2023, 01:26 PM   #375
HIPO
Al
HIPO's Avatar
Picked up a PowerHD 30kg servo & some cheap hex drivers... have been fiddling with those tiny supplied keys.
Speaking with the Hobby shop guy & he recommends upping the diff oils rather than changing friction plates around.
Old 28-12-2023, 01:31 PM   #376
You will be better off spending the extra on 1 of these
https://www.ebay.com.au/itm/40446871...mis&media=COPY
My kid has the old school one, i have the newer one. You can plug it into a pc and be fancy, plus its also a balance checker for your batteries.
Old 28-12-2023, 01:38 PM   #377
HIPO
Al
HIPO's Avatar
Agree, thanks. Watched a couple of vids on them last night.
Old 28-12-2023, 06:00 PM   #378
HIPO
Al
HIPO's Avatar
The debris net thingy arrived & some beautiful cnc alloy suspension arms ..... measured up perfect & ran a pin through them & alignment, fit is all good.
Reckon for all 6 arms, about 40gms heavier.
Old 28-12-2023, 06:35 PM   #379
DJM83
Barra Turbo > V8
DJM83's Avatar
Keen to see some pics of the net
Old 28-12-2023, 06:57 PM   #380
HIPO
Al
HIPO's Avatar
Got it here from "lovesister" lol, but payed $28.... quick delivery!
https://www.ebay.com.au/itm/354992941116
Also picked up shock & diff oil (expensive) Jap stuff. Rear will stay 10,000... Centre 300,000 up from 100,000 & Front 50,000 up from 10,000.
Should give it a lot more zip & tighten up , on power out of turns.
Old 28-12-2023, 07:58 PM   #381
Centre and rear diffs? If its selleys it works. Front diffs i perfer them a bit looser because turning.
Yes, by selleys i do mean roofers silicone. Its way cheaper.
Old 28-12-2023, 08:18 PM   #382
HIPO
Al
HIPO's Avatar
I see silicone ear-plugs in the centre are a thing too.
Old 28-12-2023, 08:33 PM   #383
Yeah, but theres a bunnings on every other corner, and roofers spooge can be also used for more practical purposes.
Old 29-12-2023, 05:48 AM   #384
HIPO
Al
HIPO's Avatar
Atm want known weights, so i know which way to go to dial in for my style.... part of the fun. Tons of initial turn in now, will be interesting just how much changes.
Old 29-12-2023, 06:43 AM   #385
DJM83
Barra Turbo > V8
DJM83's Avatar
Bloody hell you blokes get into it, i cant be bothered although id like to but i dont know enough about it.
Also will order a net today, wish hobby shops had em only cause i got a cpl vouchers
Old 29-12-2023, 07:14 AM   #386
HIPO
Al
HIPO's Avatar
So much has changed since i used to do this.
Tons of info & vids on Youtube covering the different aspects.... i've been serving my apprenticeship on there to try & get up to speed.
Have just realised this new servo is programable too.... cant see myself delving into that though.
Old 29-12-2023, 01:09 PM   #387
DJM83
Barra Turbo > V8
DJM83's Avatar
Ordered one of those nets from the same seller, says breathable i hope it is. Wonder how it does banging on a hot motor also.
Test and confirm HIPO, if yours catches fire i wont use mine
Old 29-12-2023, 02:21 PM   #388
HIPO
Al
HIPO's Avatar
Haha! definitely breathable. Yep will update, trust me! ...............wish the fan set-up would arrive, really want that on before netting it.
Old 30-12-2023, 11:31 AM   #389
HIPO
Al
HIPO's Avatar
Alternate , dedicated Mojave shell..... haven't searched prices elsewhere.
https://www.prolineracing.com/produc...PRO361818.html
Old 30-12-2023, 01:39 PM   #390
DJM83
Barra Turbo > V8
DJM83's Avatar
I seen that one.
Im awaiting this one to come into stock
https://hobbiesdirect.com.au/Pro-lin...lear-PRO361817
I wont be faffing painting different colours, it'll get painted just one colour.
