Old 27-05-2006, 07:29 PM   #1
jonbays
TL40 Wagon?
Default getting the lardarse wagon off the line
I have been running the wagon a bit now and know the limitations of the weight and power I have but i am finding its off the line performance its worst feature.
How do i imporve it? I am tempted to go for the Jim Mock histall as i run theri cam successfully but how streetable will it be for me a wagon dad if i am honest who is still playing at drag racing.
My best three times so far in 28 degrees with all the mods in the sig.
Name60'330'660'MPH1000'ETMPHjonbays2.34406.570010.009071.450012.963015.464090.2400jonbays2.33406.56809.990072.160012.961015.474091.8400jonbays2.37806.657010.110070.970013.058015.549090.5000
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2006, 07:32 PM   #2
jonbays
TL40 Wagon?
that didnt work hows this
60' 330' 660' MPH 1000' ET MPH
2.3440 6.5700 10.0090 71.4500 12.9630 15.4640 90.2400
2.3340 6.5680 9.9900 72.1600 12.9610 15.4740 91.8400
2.3780 6.6570 10.1100 70.9700 13.0580 15.5490 90.5000
Old 27-05-2006, 07:34 PM   #3
CAMS290
trying to get a leg over
CAMS290's Avatar
A Hi stall converter is your friend, even a 3500 or there abouts are still streetable.
Just make sure you install a trans cooler if you put a Hi stall in as they tend to heat up the fluid in stop start traffic......oh and forget about towing anything too !!!
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2006, 09:20 PM   #4
Craig
RIP Craig - 13/11/08
Craig's Avatar
What Cam said. The I6 really need a nice stall convertor. You seem to have all the other mods youre just missing out on a real important piece of the puzzle.
Cheers CC
Craig is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2006, 11:13 AM   #5
Tri Power 289
Back in the Game!
Tri Power 289's Avatar
Before edit, CAI, LSD and 3000 stall convertor, my best 60' was a pathetic 2.5 on a 15.9 run. It is now 2.08. i would be suprised if you didn't go very close to a 14 straight away, although with a single spinner diff, traction might become a problem.
As far as streetability goes jonbays, I guarantee anyone not totally familiar with the car would not even know it was in there if they drove it.
But you will......! :dr_Evil:
2016 Focus RS MK3
XHII XR8 Falcon Ute S/C 5.0 Manual
'66 Mustang coupe 289 Auto
70 Mustang Mach1 351 4V/Shaker Auto
Previous forum rides:
XH Falcon Ute 4.0 Auto
BF XR8 5.4 Manual
'88 60 Series Landcruiser Turbo Diesel.
Komatsu 830E Haul Pac- 2500hp, 165tonnes.
AUIII XR6 HP: Prepared by Aussie Car Enhancements & Custom Tuned by Blue Power to a record setting 14.22@96mph.
BA Fairmont Ghia 5.4 3V :Unfinished business.
Tri Power 289 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2006, 05:48 PM   #6
jonbays
TL40 Wagon?
OK you're convincing me. my car stalls now at 1800-2000 odd and at 1800 takes off sharply but at 2000 sort of limps off a bit worse. so from 0-45kmh its slow then at 2500rpm it sort of almost switches on and goes well.
So for a stally do i want to go for a 2500rpm 3500rpm stall or what?
Jim Mock do them and I can get one of their easy as but what other choices are there?
And yes i will put a trans cooler on for sure if i do the hi stall
Old 28-05-2006, 06:14 PM   #7
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Yep, stall is the way to go,the only other easy thing is to get as much weight out of it as you reasonably can,the more weight you can get out of it the better it will 60.
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2006, 06:26 PM   #8
jonbays
TL40 Wagon?
Weight is the eneemy but this is my family wagon and its not really that sort of car as i do drive it daily for my job. So weight wise i run it as i drive it every day and at WSID scrutineering it weighs in at 1650kg without me so its not awfully heavy just not a lightweight.
Old 28-05-2006, 07:10 PM   #9
mik
mik's Avatar
what about turboing the beast, i might do mine down the track , my brother has donated 2 turbos off supras he`s wrecked 2x3 litre , they are also cheap too buy i think,...... that would get the wagon boogeying
Old 29-05-2006, 02:16 PM   #10
jonbays
TL40 Wagon?
Well of course that would be nice BUT... ... . It is my daily driven family wagon and the wagon chassis dynamics wouldn't really handle that sort of power without lots of work to get it to handle and brake better and then what about the engineers certificate for rego then insurance etc.
I might as well sell it and buy an XR6T it would be cheaper and easier.
You can make a high 16 car into a low 15 but what I want here is the red light 0-60 performance increase not to pull 100MPH plus throught the quarter.
Old 29-05-2006, 06:13 PM   #11
mik
mik's Avatar
yep point taken.
Old 29-05-2006, 06:19 PM   #12
mik
mik's Avatar
what about diff change?
Old 29-05-2006, 08:01 PM   #13
jonbays
TL40 Wagon?
Already gone from stock 3.23 to 3.45 XR6 ratio.
Could go lower but the wagon tailshaft is long and the speed limiter becomes stupidly low like 140k if you go too far. It's easy to fix the limiter but not the carnage if it lets go! Also the trans fluid gets foamed up by spinning the ts too fast.
I considered 3.73 but kept it at lowest stock ratio as I don't want to put a two piece tailshaft in that would be too much trouble.
Old 29-05-2006, 08:28 PM   #14
nugget378
Weezland
nugget378's Avatar
I didnt mean go silly,just what you can easily take out, spare/jack/etc: then maybe just what you could unbolt in ten or so minutes,something easy,even 40 or so kg will make a difference
Old 29-05-2006, 08:40 PM   #15
mik
mik's Avatar
ahaaa just had a brain wave prolly cost prohibitive, but have you seen the gear vendors site, bolt on overdrives basicly another tranny on the end of a tranny, worth a read anyway, i just mentioned this on another thread, gives a split gear between gears and taller overdrive ....who needs a zf.....http://www.gearvendors.com/hrford4s.html
Old 29-05-2006, 09:12 PM   #16
vino3o2
owning V8=having no $$$
vino3o2's Avatar
I also have no stall in my car and found that my 60' time was slightly better when I just stood on the go pedal rather than stall it up then flatten it...I cant explain it, maybe the converter streches a little more by say 100-200 rpm by just standing on it....anyway, thought id share my experience
Weekends - 1965 XP 302 sedan... :
Weekdays - 1980 323 Mazdabator complete with cheese cutters & FF sticker :dr_Evil:
The Reality: 13.1 @ 106mph.... The Goal: somehow get into the 12s!!! :sm_headba
www.qldsuperkart.org
vino3o2 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2006, 10:08 PM   #17
jonbays
TL40 Wagon?
Can't say I can prove this with a slip actually and I have over 50 of them but mine feels the same. Stall it hard up on the brake and it feels worse. Lightly stall it feels OK no stall and try to surprise the converter and grab a few extra rpm and wellit it feels like a better launch for the first milsec then the same as a light stall.
Its not all about launch technique though as i have done this so many times now and even by accident you would think i would have fluked a better technique by now.
No its about modding the drivetrain engine ecu or wahtever to improve the 0-40KMh or 60' time not just for a once off PB but for daily driving traffic light launch stuff not really drag strip launches as such.
Old 29-05-2006, 10:42 PM   #18
seXCmont
EcoBoostin
seXCmont's Avatar
yeh same problem with the pannie.
seXCmont is offline   Reply With Quote Multi-Quote with this Post
