Old 03-04-2023, 05:04 PM   #1
xkxlxm
Default 2005 Focus: how to turn on hi beam ... and oil filter ?
My friend's mum has a 2005 Focus 2.0 auto; I think it's a base model; my friend says that the owner's manual does not say how to turn the lights onto hi beam ... can someone tell me how it is done?
Also: is the oil filter a 'normal' spin-on (by hand), spin-off filter? Or is it inside a cover that has to be unscrewed first, with the filter then being detached from inside the cover?
(They live in the country, so I can't just go and have a look at it.)
xkxlxm is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2023, 08:36 PM   #2
GTLEGEND
Default Re: 2005 Focus: how to turn on hi beam ... and oil filter ?
High beam is turned on by pulling the left hand lever on the column (the blinker is on the left on these, wipers on the right) towards you and again to turn off.
Normal oil filter on these, not the element that sits inside a plastic housing. I have a 2006 LT Focus 2.0 Petrol Auto.
Old 04-04-2023, 08:24 PM   #3
xkxlxm
GTLEGEND - thank you. I will let him know.
Old 30-04-2023, 02:05 PM   #4
xkxlxm
Another question: what sort of washer goes on the sump plug for the Focus? Would it be an aluminium crush washer? Something else? Something that can be reused? I am trying to get him prepared for when he changes the oil and filter. Thanks in advance ...
Old 30-04-2023, 09:05 PM   #5
GTLEGEND
Correct washer has part number F5TZ6734BA.
Old 01-05-2023, 12:07 PM   #6
xkxlxm
Thanks.
Old 08-05-2023, 07:37 PM   #7
xkxlxm
When I search that part number, I am not clear if the correct part is the black rubber one with a thick outside edge to it, or an aluminium crush washer. (At Burson's today: their part number is for an aluminium crush washer.)
Old 09-05-2023, 01:30 PM   #8
xkxlxm
Solved. I had the bright idea of going to Bayford in Greensborough. The parts man gave me one, which was nice of him. (the rubber type) Will post it to my friend today.
