#121 | |||
Look at picture below, notice timing cover and water pump length Going by online sources, the Godzilla tapes up very close to a traditional small-block Ford at 730mm long (timing cover to rear of block), 585mm wide (across valve covers) and 635mm high. It’s roughly an inch narrower than a 351W and close to four inches narrower than a Coyote…. https://fordauthority.com/wp-content...nifold-001.png Last edited by jpd80; 13-12-2022 at 07:48 PM. |
#122 | |||
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
#123 | |||
#124 | ||
But then the Godzilla is a full skirted block so that would move the crank centre line up in the block (compared to the 351) so that would make it sit lower in the chassis........interesting
#125 | |||
The engine was designed to be compact so it could fit in all perceived applications, it and the LS are reasonably close. |
#126 | ||
Oh well he would know.......I was just going off the measurements?
#127 | |||
Peter Car
Hardly worth worrying about, but the dimensions are hard to nail down when you don't know if the 2 measurements you are comparing use the same points of reference. Any they rarely tell you what points they measured from either. Fact is it fits very easily in a Foxbody, with dimensions close to a SBF, which means fitting in a Falcon won't be hard. That XA that was running one with the harrop blower that ran 8's fitted it all under the hood very easily. |
#128 | ||||
#129 | ||
I'd like to see a project putting Godzilla into a BA. I wonder how the would handle the transmission. I like the idea of a stock one for low down torque. I'm guessing if BA can fit a 3v then Goszilla would fit. The 3v is a wide motor.
#130 | |||
Peter Car
The blown XA uses a TH400. |
#131 | |||
30 years ago now but HG Monaro 383 ‘glide vs SLR Torana off the lights, 70 mph in 1st, Torana tried his best but fell back every gear change…. |
#132 | ||
Basically if it could fit the 302, 4.6, 5.4, Coyote… it can fit the Godzilla.
#133 | ||
Mad Scientist!
