Old 08-04-2022, 03:04 PM   #1
Gus69
Default Engine hard to strat
Ford farilane 11.97 v8
I have an issue with it I buy the car from Melbourne and had it delivered to me because my legs are no good to travel .now I have replace all the ingition parts
Pick coil .. spark plugs cam sensor in side the did. And air flow meter ..hight tention leads . .. injectors. Did cup
rotor button .. and still hard to strat the engine I need a bit help out here thank you god bless all
Gus69 is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2022, 04:53 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Engine hard to strat
what Seriously AU is it? Sounds like the wrong years
Old 14-04-2022, 07:23 PM   #3
falconnut
i keep having fuel pump issues so start there spesifically with priming
2001 Falcon Fairmont AU2
Big turbo coming
Lsd
falconnut is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2022, 07:39 PM   #4
mad2
Regular...with metamusal
sounds like it's a NL not NU
