05-05-2018, 01:15 PM | #1 | ||
I jumped in the car today an noticed a light on ..I've never seen it before an don't know what it means,it's like a box with a fan in it??
It's on the left side third from the top...in the rows of lights left an right of the Speedo. I don't think it's low on water light ..that's the water spray looking light down the bottom
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B] |
05-05-2018, 01:59 PM | #2 | |||
Next upgraded Mk1 Leopard
low engine coolant level warning light so check the coolant level uk
06-05-2018, 01:43 PM | #3 | ||
I topped up the coolant so it's full...I started the car an let it circulate put cap back on an took it for a run....damn things still on...is there a reset button or something
06-05-2018, 05:32 PM | #5 | ||
common fault was the coolant sensor at bottom of overflow bottle - pull plug and bridge connection and recheck light....
06-05-2018, 06:55 PM | #6 | ||
Will do thanks man...hope that's all it is
07-05-2018, 10:21 PM | #7 | ||
Yer walked out today an checked to see if that light was still on ...yep sure was
So I unplugged the lead ..wiped it a bit an plugged back together an BAM...problem was fixed ..no more light..
