Old 14-03-2006, 11:27 AM   #1
XTC 190
Subtle,sleek & Surprising
XTC 190's Avatar
Talking New intake
Morning all, yesterday I went and got the new intake pipe from air box to throttle body measured up and made and at the moment it is being HPC coated to reduce heat inside pipe, had a hell of a time finding someone to do it in Brissie but finally got it so far its looking good and should give a definite gain a I am inserting a pod air filter inside the box as well, also running new pipiing and scoops from the driving light areas in the front to a new hole on the air box should help I will try and post some photos once done does this sound good, my brother who is a quite a achieved mechanic said the set up is as good or better than the ss induction kit but this has only cost me around 250 max but alot of time best advice investigate and research any improvements as you may find a better way or cheaper with better results
XTC 190 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 11:29 AM   #2
agony
BLOWN 383 CHEV OWNER
sounds like you did your homework there falcon73.
agony is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 11:35 AM   #3
Des
V8 Rock'n'Roll....
Des's Avatar
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
Sounds great, you must show us the results. I'm actually looking into this for the XR8.
1 owner 03 BA XR8 Manual Sedan
208.8 rwkw stock, update soon
20x8.5 fr 20x10 rr
Rumble thanks to:
Sureflo Exhaust - Stainless Cat's & 3.5in single catback system
"Tell 'em the guy with the Blue Mohawk sent Ya"
Des is offline   Reply With Quote Multi-Quote with this Post
