28-06-2015, 03:46 PM | #1 | ||
Right laugh if you want but this is serious, I cannot get the back seat of my ford escort back in. Very funny I know. Please help as I need it done by Tuesday.
Everyone has bad days. The cure is to drop it down a gear, put the foot to the floor and flick out the tail end. |
29-06-2015, 06:21 AM | #2 | ||
Which model Escort? The earlier ones had a horrible 'C' shaped clip that you had to rotate them around.
Cheers Russ
29-06-2015, 06:48 AM | #3 | ||
It's a mark 2 ghia
29-06-2015, 11:57 AM | #4 | ||
The back section is held in at the top by fastening in over the parcel shelf with two nuts fitted from inside the boot. One on each side. lock under tabs on the inside of the car at the bottom. The trick is to fit it on the inside and strech it over the parcel shelf. The bottom section then is fitted under the back section and pushed back and down. the tabs then sit outside and a self tapping screw in each to hold it there.
