Old 28-04-2005, 03:24 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default AUII Wheel Offset
As stated in the thread title, what is the wheel offset for an AUII?
Thanks in advance.
EDIT - Nevermind. I found out. 5 stud. 114.3mm PCD +35 offset
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 03:38 PM   #2
JC
Miami Pilot
JC's Avatar
Yep that's it - you can go +/- 5mm on the offset without too many dramas.
Ford Performance Club ACT
Old 28-04-2005, 04:01 PM   #3
TheSneakiness
Adapt or perish...
So I can go in between +30 and +40 and it should still be OK?
Anyone know what the wheel offset on a EL was?
Carless
Old 28-04-2005, 04:08 PM   #4
Perana
Perana's Avatar
EL was 0 offset
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 05:34 PM   #5
TheSneakiness
Adapt or perish...
Oh sh*t.
Ummm, how much damage can a 0 offset do to an AU?
Carless
Old 28-04-2005, 06:35 PM   #6
JC
Miami Pilot
JC's Avatar
It should just about be rubbing on your guards. I know my old AU XR6 did when I fitted 17X8s on the back. Don't think I actually managed to fit them to the front as they hit the guard anyway. But if you have EL 16 x 7s, then you may be OK - would look funny though, as the rims would be sitting outside the guards.
Old 29-04-2005, 09:57 AM   #7
TheSneakiness
Adapt or perish...
The rims do sit outside the guards. If you look at it head-on, it looks real aggressive. I'm still gonna need to replace them otherwise, cause it isn't helping steering, and I've had them re-aligned.
I'm still not happy with the guy who sold it to me though, lying scumbag.
Carless
Old 29-04-2005, 01:26 PM   #8
12
Silhouette AU1 TS50.
12's Avatar
Just remeber that as part of RWC requirements, it state that your rims/tyres have to be inside, or level with the guard edge. These rims would make your car unroadworthy.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2005, 01:55 PM   #9
TheSneakiness
Adapt or perish...
Yeah, but how different is roadworthy requirements in VIC compared to QLD?
Carless
Old 15-01-2014, 06:33 PM   #10
chad0170
Default Re: AUII Wheel Offset
can anyone tell me quickly if +45 offset will fit AUII without dramas?
It's 9mm over the listed offset
chad0170 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2014, 07:47 PM   #11
Ride
Stay Classy ™
Ride's Avatar
+45 means it will go further inside the guard. Hit and miss whether it will cause you issues because of brake caliper thickness. I wouldn't have gone any bigger than +35 to be honest
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2014, 08:02 PM   #12
chad0170
hmm, these are 20' rims & new tyres REALLY cheap under half price but they are off a Mitsubishi 380.
a tyre site i cooked up has AUII offset at 36 & the 380 at 45, i was thinking it'll be close, was more concerned about the clearance for the suspension, but i guess +45 means it sits further out.
Old 15-01-2014, 08:02 PM   #13
chad0170
looked up*
Old 15-01-2014, 08:27 PM   #14
Ride
Stay Classy ™
Ride's Avatar
Actually it doesn't, +45 sits further INSIDE the guard, and could cause issues with either the suspension OR rubbing on the guard. If it were a 17" rim you could probably get away with it, wouldn't do it with a 20". If you can trial fit and test before buying then OK, but wouldn't do it on a hunch.
Old 19-01-2014, 02:32 AM   #15
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Mitsubishi 380 will have the same stud pattern and offset, but I'm pretty sure that the centre hole will be too small so you'd need to get them modified to fit onto the AU's larger hub centre.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2014, 07:00 PM   #16
JC
Miami Pilot
JC's Avatar
20s would be an aftermarket wheel, and most aftermarket wheels come with a 73.1 centre bore.
It will also depend on what width the rims are, since the offset and width will dictate how close the inner part of the rims will be to the suspension. For a 45P offset, if it's a 6" rim, then no problems; an 8" may also be OK, but a 9" or more will probably hit.
With 35P offset and 8" wide rim, there's about 15mm gap between inside of tyre and the suspension on my BF, which is pretty much the same setup as an AU.
So, like Ride said, fit them up before paying, and if they fit, pay, if not, walk (or drive on standard wheels) away.....
Old 22-01-2014, 07:58 PM   #17
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
45 offset probably would be illegal in some states. It will reduce your track width by 20mm. Whilst some states allow 25-26mm increase or decrease, some states it's illegal for any decrease.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
