Old 18-08-2013, 01:31 PM   #1
ben131185
Default coil spacers to lift rear
my rear sl king springs have sagged a bit with the lgp tank.
rather than get new sl's and have them sag again or goto low's and have it sit too high i was thinking that maybe i could get some coil spacers about 15mm thick to bring the height back to where it should be.
is this as simple as it sounds or am i missing something here?
ben131185 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 02:13 PM   #2
mik
mik's Avatar
Default Re: coil spacers to lift rear
i don't see why it would not work, but if it were me , i think i fork out for some more suitable springs, perhaps a bit heavier to make up for the added weight of the lpg tank.
Old 18-08-2013, 03:03 PM   #3
ben131185
a bit heavier would be nice, but then what springs would i go for? and it would be a bit of a gamble getting the height right.
Old 18-08-2013, 05:23 PM   #4
mik
mik's Avatar
sorry i wouldn't have a clue mate, a suspension place should be able to give you a heads up.
Old 18-08-2013, 05:44 PM   #5
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
If it helps you, I have a dual fuel set up on an AU III. Have king lows on all round.
From hub to guard.
Front - 355mm
Rear - 345mm.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 07:44 PM   #6
ben131185
yeah, mine are 335mm front and 320mm rear. i just put a jack under the towbar and lifted it upto 345mm, it still looked pretty good so it might be a good compromise.
Old 18-08-2013, 09:28 PM   #7
Bossxr8
Peter Car
Bossxr8's Avatar
I used Whiteline 10mm coil spacers in the rear of my Fairlane.
