hello all just wondering if anyone can help me out with the thermo fans on the radiator of my au1 xr8 as the one on the drivers side was not working i swapped over the under bonnet fuses and relays everything to do with fans however now that doing this has fixed the problem and the thermo fan is now working i need to isolate which fan it is as there were fuses and relays for 3 fans so its the fan on the drivers side of the radiator im not sure if its considered fan 1,2 or 3
thanx in advance gra |
if the fans working why do u need to isolate which one it was? and wait till both fans are running then take out the relays one by one till the fan u want stops spinning thats the number fan you want
