Old 01-02-2013, 09:14 PM   #1
imbhvn
Default series 2 au wagon want turn over????
hey guys my friend has a series 2 au wagon i6 it over heated on him last weekend due to the Welsh plugs letting go so i replaced them for him went to start it and nothing just the clicking of a relay when turned to start position. (the car started fine after it had over heated) and i have checked the starter motor to see if it turns over which it does, all fuses are fine and ie tried switching relays but nothing! can anyone suggest anything?
imbhvn is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2013, 10:46 PM   #2
needaXYGT
AU II XR8
needaXYGT's Avatar
Default Re: series 2 au wagon want turn over????
When you tested the started motor, did you bipass the solenoid? Was the battery disconnected at all, and I'm assuming the battery has enough charge as well?
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2013, 10:52 PM   #3
imbhvn
when i tested the starter motor i ran a wire from positive to the solinoid and the engine turned over but wouldnt fire up, i have tried the battery out of my car in it and still the same...
Old 01-02-2013, 10:57 PM   #4
imbhvn
although when i finished the welsch plugs and filled the radiator and went to start it it made a clicking noise as if the battery was flat so swapped battery with my car and since that nothing! everything else works just wont turn over. racv has had a look at it and they have no idea.
Old 01-02-2013, 11:20 PM   #5
mik
mik's Avatar
have you checked battery,terminals cables/earth`s, particularly the one on the engine block, maybe you disturbed something while doing walsh plugs.
Old 02-02-2013, 12:21 AM   #6
imbhvn
yeah mate checked terminals checked earth on the block. if it wasnt farthing then the starter wouldnt have engaged either.
Old 02-02-2013, 11:38 AM   #7
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Check your fuses under the dash. I seem to remember there's one under there that if blown will stop the starter from activating but I can't remember which one.
MINE- AUII Forte
Old 02-02-2013, 12:02 PM   #8
needaXYGT
AU II XR8
needaXYGT's Avatar
When you turn the key to accessories, can you hear the fuel pump? If you don't, then turn the key to accessories, wait for one minute, turn the off and try and start the car. As these cars are getting older, the wires insulation get old and brittle and can break without even realizing, so keep an eye out for that.
You could also loosen the fuel supply line, see if any fuel spills out and also check for power at the ignition coil.
Let us know how that goes.
AU XR8 II ute
Old 03-02-2013, 02:16 AM   #9
imbhvn
no blown fuses check all relays and fuses, fuel pump primes havnt check power at coil yet.
