06-04-2012, 02:56 PM | #1 | ||
previously SMIKXR6
Hi guys i have a 2002 au falcon and i want to know how to remove the dash spear above the pasangers airbag cheers travis.
06-04-2012, 04:37 PM | #2 | ||
previously SMIKXR6
Anyone i need help asap cheers.
06-04-2012, 07:16 PM | #3 | ||
Found this for you.
Hope it helps. 1. Remove the airbag panel (will break the clips behind) 2. Undo the 4 10mm bolts to remove airbag 3. Remove the passenger dash vent 4. Feel behind the spear to locate and undo the 5x 10mm nuts Dash spear removed The plastic clips you have to break to get the airbag panel out are available from Ford for around $20.00 I think.
We salute those brave souls that enter the DARK side |
06-04-2012, 07:31 PM | #4 | ||
previously SMIKXR6
Thanks heaps mate i couldent find any info lol...
07-04-2012, 12:15 AM | #5 | ||
there should also be one screw on the right behind the climate control if you have a fairmont version that is
08-04-2012, 01:05 PM | #6 | ||
5.6L x 2 pilot
PM FAT245. I believe he has done this to his Lane.
08-04-2012, 01:58 PM | #7 | ||
previously SMIKXR6
Thanks guys but its a falcon no digital climate contol its anilog.
