Old 03-04-2012, 09:23 PM   #1
topdec
Default Headlights on LW
Hi
I have a 2011 LW Focus Trend which I purchased early this year and I find that the headlights are below par. It does not have the seeing range on the highway, especially the right headlight.
I had an old Commodore before and the lights on that were brilliant compared to the Focus.
Has anyone have similar feelings with their Focus?
topdec is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2012, 09:47 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Re: Headlights on LW
Check that they are aligned correctly first. The right light I think needs to shine a little lower from memory to reduce glare for oncoming traffic.
Actually, can they be adjusted? I don't think my LV has adjustment now that I think of it.
___________________________
Old 03-04-2012, 10:54 PM   #3
rand0mn00b
Correct - the headlight closest to oncoming traffic is meant to be dipped slightly for the sake of other drivers
Can't speak for the LW but if your LV is anything like my LT's headlight assembly then yes, they can be adjusted
A couple of big plastic hex sockets that can be turned (1 for each axis) on each headlight
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2012, 11:22 PM   #4
Smoke Pursuit
Cant they be remotely adjusted from inside the car? The centre button you press it in and it pops out allowing you to adjust them.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2024.50 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA Jan 25.
Old 04-04-2012, 06:17 AM   #5
WILDB
WILDB's Avatar
Correct. The adjustment knob is in the middle of the headlight switch, press it in and it will pop out.
WILDB is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2012, 12:31 PM   #6
topdec
Thanks for the replies, but I have already used the the adjustment in the headlight switch. I can understand that the lights have to be fixed so there is no glare to oncoming traffic, that is why there is a low beam. I am talking high beam where the lights should give you a better range.
Mine are that bad that if I forget to dim them the oncoming traffic do not even flash me. The Ford service guys have said that they are adjusted properly. Not happy with the lights at all/ I think my first car (Holden FJ) were better than these.
Old 04-04-2012, 02:16 PM   #7
boss-man
boss-man's Avatar
Have a look here...
http://www.fordforums.com.au/showthread.php?t=11360341
Moondust silver LW Ford Focus Sport manual with darkest legal tint...
boss-man is offline   Reply With Quote Multi-Quote with this Post
