Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
cast iron is real steel!
G,day all,
In a footbrake application, only concerned with maximum holding power on the start line, so relatively cold brakes, what is the best type and brand of disc pads? Thanks! Paul |
I am not sure on the best pads I just use a Race brake pad from Race Brakes Sydney he is a site sponsor and know his brakes. Also I found braided brakelines a great upgrade for holding consistent pressure and a good superdot 4 or 5 brake fluid.
G,day,
Thanks very much for the reply! Cheers Paul |
You dont want to use too low grade a pad thats going to fade super quick if breaking from 120+mph ( unsure of the application your requiring ) .
1 Reason i went soltted rotors up front ... Can stop from 200km/h without and issue . Just using a Lucas Pad supplied with myy RDA slotted rotors .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
Cold braking - you want stock pads. Hot braking you want racing pads. Take your pick
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car BA GT-P for the shed Mustang GT for the other half E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it. BA XR6T for a daily NT Pajero for the bush XB 4 door project- swallows a BF xr6 turbo My dad is a generous bloke. He gave away his dead car batteries free of charge.... |
Don't forget the rear pads probably warm up pretty quick on the burnout...
FG XR6T GU Patrol Duramax |
I am using DBA Slotted Rotors on all 4.
G,day,
Thanks for the replies, stopping at the other end is no probs, am going to go with some std trw pads, supposedly good in this application? Stopping from 130+ mph, going to rebuild rear calipers as well. Cheers |
Hey Paul did you find much difference using other pads?
Hi. When I last engineered a car the engineer advised standard type pads as metal king type pads would fail the first 2 or 3 stops while cold but the drop off in performance on the 5th test with standard pads would still pass. Cheers MD
