Old 23-08-2011, 09:25 PM   #1
R0BD0G
R0BD0G's Avatar
Default will this work?
sorry that was probably one of the titles i couldve used. FREE BEER was the other one.. but anyway.
trying to sort out my filtering and catch can stuff and this diagram is what i have for you to work with... 2 options with the third being.. filter at the rocker cover breather and filter at the catch can but can someone tell me whats gonna work?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 04:07 PM   #2
SBRacing80
Default Re: will this work?
Your engine will run cleaner without a breather recirculating back into the intake.....
SBRacing80 is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 05:41 PM   #3
caprispecial
PCV valve wont work unless its a totaly sealed system with no breathers to atmosphere.
So Pcv valve piped to catch can, catch can to inlet manifold.
Inlet manifold provides the vaccuum necessary to open the PCV.
I havnt done this (yet) but how else do you get a pcv valve to work?
caprispecial is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 10:39 PM   #4
SBRacing80
that will make the pcv work, but you will still get crankcase gasses into the inlet which will carbon up the motor more quickly.
all a pcv valve does is stop oil being sucked into the inlet when the engine is under full throttle.
the cleanest way to run the motor would be to run both rocker cover breather and pcv into the catch can and plug off the air filter fitting.
if its done this way you dont need the pcv so you can cut the end of the valve off and remove the plunger if you like.
if you do this tho, make sure you mount the catch can as high as possible and run a large diameter hose (say 3/4 inch) from the pcv to catch can as high revs and high speed cornering can push oil up into catch can and it can overflow.
