so guys my auto died and i got a second hand box off a mate who owns a wreckers for $300. what i need to know is how much should i expect to pay to have it installed, including fluids and seals if needed?
"Insert witty signature here" |
Just another mock-up..
250-300 would be a very good price..
All depends on where you go... I used to do them for 300-350inc fluid.. If seals are needed it'll take it above 400.. Also add a bit more If you want it serviced/flushed.. Cheers kris
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
cheers mate... i'm told that an EL auto will go into an AU as long as the AU bellhousing is used, can you shed any light on this?
Will go in fine using the AU bellhousing..
Has your mate given you a warranty on the box..?
if its broke i bring it back, its all good. but i still have to wear the install costs :(
Yeah, that's what I was getting at....
Good luck with it mate!!
i would be makeing sure they flush out your lines and cooler before fitting a good second hand unit.
Spot on mik...
forgot to mention that!!
awesome will do guys thanks for that... ps. one of the staff at the wreckers used to work for an auto gearbox mechanic so he is going to install it for $270 inc fluid and gaskets... so $570 all up
Good price mate...!!
and yes the lines are getting flushed, i asked when i dropped it off. so i'm pretty happy with the price. and another car is getting done before mine its auto is slipping and it was purchased from the same wrecker 3 months ago so that answers the warranty question as my mate said hes fixing it for free.
#12 | ||
woohoo i got my car back and the gearbox is great. feels firm shifts fast very nice... so i got the old box taken out, lines flushed, new box installed, new front and rear seals, and new fluid, and 3 month warranty. but hes a mate so 3months is flexible, all for $270 not bad me thinks.
but now there is an annoying squeak coming from the front passenger side wheel when moving, it doesn't sound like your typical brake squeak but more like what it would sound like if the wheel were made of wood and it just sat on a metal axle (if that makes sense.) this is the first the car has moved in 2 months so i'm hoping its just a bit of rust on the brake disk. any ideas?
#13 | ||
Good to hear you got it sorted mate!!
did well with the price!
