Old 04-08-2010, 11:46 PM   #1
honda99ex
Default Passenger Air Bag
My Falcon doesn't have a passenger airbag. At least I don't think it does. How can I tell?
Assuming it doesn't have one, I was thinking about prying off the cover (which I think is easy) and using the space behind it for storage. Does anyone know where to pry or how many tabs hold it in place? How big is the actual space? Worth it?
honda99ex is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 12:19 AM   #2
bartsau
bartsau's Avatar
Tap the 'Cover' if it sounds hollow then you don't have an airbag.
As for if you don't you can pry it off easily as there are 4 clips that hold the cover in place. These break off when a certain force is applied. There is 1 towards each corner of the cover. In the pic of the dash in the following link you can see in the top right hand corner where there is the white base of the clip in the top right hand corner of the cover. Hope this all makes sense. If you would like a better photo i should be able to post one up later tomorrow.
Cheers, Rhys
Photo of dash
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 05-08-2010, 12:40 AM   #3
honda99ex
Thanks for the reply. It's not such a big deal if the tabs will break but it's always easier to know where to pry so if it's no bother a pic would be nice. If just to see how big the potential space is. Cheers.
Old 05-08-2010, 09:33 AM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
It was always my understanding that if there is no cover then there is no airbag so conversely, if there is a cover then there should be an airbag. If you have a cover and no airbag behind it then I'd expect the airbag light in the dash cluster to be on. It would also mean the car has been in a prang and the airbag deployed and not replaced; very naughty. Following that line of thought to it's conclusion, if there's a cover but no bag and no light then someone has pulled the fuse to extinguish the light which is also very naughty ( read, illegal and defective).
Bushbasher
MINE- AUII Forte
Old 05-08-2010, 09:59 PM   #5
au adam
au adam's Avatar
If you have an air bag on the passenger side the the words "airbag" will be on the cover.On my two AUs the cover doesnt have the writing so it means i only have drivers side airbag.
I have been thinking of using the empty space for storage as well,i might go to my friends wrecking yard and have a look around.
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2010, 11:20 PM   #6
fourl6
AU Falcon Man
fourl6's Avatar
Correct...
All AUs either have a airbag or a blanking cover, if it has the word "airbag" on it you have one, same with BAs (BA Utes have a blanking plate) it was ELs that either have a airbag or a solid dash (no hole to fit a airbag)
i think all the wiring is behind the dash to plug a passenger airbag in, not sure if it would work?
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 01:02 PM   #7
superroo
You can't stop the signal
superroo's Avatar
The "blank covers" (no airbag) has some wiring attached it it. This wiring has a resistor in it so that the BEM thinks there is an airbag connected.
As for space, check here. Not much room at all
http://www.fordforums.com.au/showthread.php?t=11194818
Old 06-08-2010, 01:13 PM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
How can I tell?
crash it. j/k.
au adam is correct, it'll say on the cover is the easy way of telling
Old 06-08-2010, 09:51 PM   #9
honda99ex
Did you end up doing anything with the space?
It looks like a decent size to put a phone or some change. Not a head unit or cd cahnge. I'm not sure you mentioned the depth or I just can't understand it... I'm sure it'll make sense when I see it.
Old 07-08-2010, 07:15 AM   #10
Bushbasher
Bushbasher's Avatar
Originally Posted by fourl6
Correct...
I stand corrected. I guess I must have been thinking of my old EL wagons then.
Bushbasher
MINE- AUII Forte
