How do i wire a pair of driving lights (the ones in front bars) to the hi beams ? So when the hi beam is activated they come on.
AUII Forte 4.0L - AUSOM3 Audio Visual Incar Entertainment |
#2 | |||
Cuban... nothing like it
Easy
Pay someone to do it for you!
Boost Addict
piece of cake
#4 | |||
LIFELONG DJR SUPPORTER
where he shows + input from the light( hi beam +) to the relay, you would need to pass thru a switch and then to the relay. Otherwise, spoton
Boost Addict
hehe details :p, but yes technically correct
Miami Pilot
![]() Join Date: Jan 2005
Actually you can have the switch anywhere in the circuit. Easiest way is to have the switch between high beam feed and relay.
Boost Addict
i would say it doesnt really matter on which line you put it, i personally just dont like the idea of running a cable from headlighst back into cabin and back to relay. If it should shorten out there goes your high beams, if put on battery positive and it shortens you loose a fuse and the foggys wont works but at least the high beams will
#8 | |||
Miami Pilot
